cv63
Help With Badcameraangle Rejection....
Sun Mar 13, 2005 8:40 am
I am just trying to understand badcameraangle...
Should this shot be rotated based on the horizon, which in this case I used the hanger or should be rotated by strip of grass behind the F-15 eagle or some other guide?
Ken
http://www.airliners.net/addphotos/rejections/big/81-022_F-15.jpg
[Edited 2005-03-13 00:45:00]
Bobster2
RE: Help With Badcameraangle Rejection....
Sun Mar 13, 2005 10:13 am
I looks level based on the vertical lines in the building.
There may be some problems with clipping shadows and highlights. Does anybody else notice that?
"I tell you this, no eternal reward will forgive us now for wasting the dawn." Jim Morrison
aeroweanie
Sun Mar 13, 2005 10:43 am
I'd level it by the strip of grass. About 1 deg CCW should do it.
paulinbna
Sun Mar 13, 2005 2:05 pm
But what is normally level a hanger or a grass strip?
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
aeroweanie
Sun Mar 13, 2005 2:26 pm
Perspective has tilted everything, but the grass strip seems to run through the vanishing point, so its the closest to a horizontal or vertical line. As a side note, you put clothes on a hanger and airplanes in a hangar.
LeanOfPeak
Sun Mar 13, 2005 5:21 pm
Looking at the columns on the hangars, I get about .6-.7 degrees CCW. It's a small angle, but it did definitely look off as soon as I opened it, and .6-.7 degrees CCW makes it look about right to me.
Very nice shot otherwise.  Smile
Granite
Sun Mar 13, 2005 6:42 pm
Ken
Image needs small rotation anti-clockwise.
Also a little soft on the nose.
Gary
cv63
Mon Mar 14, 2005 12:33 am
Thanks for all your inputs. The consensus seems to be the hangar should be the guide for the horizon. I was just incorrect on the rotation.
Ken
