skyline
Badquality, Your Comment Please
Mon Mar 21, 2005 1:02 am
Sorry for this topic again. Need your comment about how I can improve my skills (both photography and Photoshop) on these rejections. Surely I have a lot more been rejected but just list three examples here:
http://www.airliners.net/addphotos/rejections/big/DSC_1209a.jpg
Badquality
http://www.airliners.net/addphotos/rejections/big/DSC_1191_1000a.jpg
Badquality
http://www.airliners.net/addphotos/rejections/big/DSC_1109a.jpg
Badqualitybadsoft
I use an IBM laptop to process my pictures. Maybe I should really get a CRT monitor instead of any LCD? Thanks a lot for your comment and suggestion.
John
aviatortj
Mon Mar 21, 2005 1:20 am
Are you using Auto Levels? The first two photos look as if that is the case. Sometimes that tool works great, but most of the time it is garbage. The photos look oversharpened to me.
Especially with the first photo, look at it as if you are really there rather than just viewing a shot on your screen. The colors and sharpening from the post processing take that shot to a over processed level.
A LCD should be fine for your editing, I have actually had a tougher time with a CRT when given a choice. Hope I helped a little.
-TJ
skyline
Mon Mar 21, 2005 1:34 am
Quoting AviatorTJ (Reply 1):
Hi TJ
Thanks for the comment. But I'm not sure "as if you are really there" is an advantage or disadvantage.  Smile  Smile
John
mygind66
Mon Mar 21, 2005 1:43 am
Size in all the pics are down the normal 1024 x***
This should be a Badsize rejection in addition to the commented already.
All the best
Enrique
skyline
Mon Mar 21, 2005 1:53 am
Badsize? I used to submit 1024x *** but a photoG here suggested me to do it in 1000x*** because it's best for people with a 1024x768 screen resolution. Any thought?  Confused Confused
[Edited 2005-03-20 18:01:58]
wietse
Mon Mar 21, 2005 2:17 am
Quoting Mygind66 (Reply 3):
Not true. You can upload in 1024, as well as in 1000 wide. Not a problem for the screeners.
Wietse de Graaf
Granite
Mon Mar 21, 2005 3:35 am
Hi all
Minimum size for uploading is 1024 wide.
Gary
fergulmcc
Mon Mar 21, 2005 4:09 am
I'd agree with TJ here, I think you have over done the levels and the hue/saturation a bit.
I never use the auto levels, thats if you have. Be carefull when adjusting the hue as too much can look out of place. Usually around 10-15% is acceptable. You just want to bring the colors out a bit, but not too much. Also watch the jaggies on the logos as well. Do you use the duplicate layer technique and rub out the jaggies?
Also as Gary says, min size is 1024 x *** I use 1024 x 683 and try to keep the ratio 3:2.
The first and last shot are good and I like the third best, motive wise, if you want to you can send me one and I'll have a go at them and you can have a look at the process I use, but send me the original out of the camera.
Hope this helps
Fergul Big grin
Zambian Airways, Where the Eagles fly free!!
skyline
Mon Mar 21, 2005 4:17 am
Hi Fergul,
Thanks a lot. I'll send the file to you. Already sent an email to confirm where to send the file.  Smile
John
skyline
Mon Mar 21, 2005 4:26 am
Hi Gary,
I'm not going to argue about the minimum size of photos to be uploaded. I may send in 1240 x *** or even bigger. I was informed by a friend who is also a famous photographer on Anet, to send in 1000 x *** for best viewing. If you say 1024 is minimum, I'll follow it without question. Thanks for reminding me so that I won't get a badsize rejection in the future.  Silly
John
mygind66
Mon Mar 21, 2005 4:59 am
Quoting Wietse (Reply 5):
Not true
Ummm...I know a thing Wietse doesn't. That should give me 10 RR points Big grin
Quoting Skyline (Reply 9):
Go for 1024 wide....as a general rule unless the pic has enough detail to show..
Enrique
Granite
Mon Mar 21, 2005 5:43 am
John
You can upload at what size you want but have a read of the upload FAQ for the min/max sizes.
Gary
wietse
Mon Mar 21, 2005 5:52 am
ok, I stand corrected  Wink (even though I still upload at 1000 sometimes  Wink)
Gary, at what size limit do the screeners get a size warning when screening an image?
Wietse de Graaf
Granite
Mon Mar 21, 2005 6:13 am
Wietse
Anything lower than 1024  Smile
Gary
