airkas1
Crew
Another Badcommon Issue
Mon Mar 21, 2005 4:28 am
Hey everyone  wave  ,
As most of you probably saw on the pictures from AMS, we had a lot of snow early March. So.. Naturally I went out for some spotting, and I took this shot:
http://img.photobucket.com/albums/v1.../KL_772_PH-BQA_03-03-05kj_edit.jpg
I submitted it and it was rejected for Badcommon. So, I searched the DB. At the time there were 125 shots of PH-BQA in the database, and only one of those was taken from an angle almost similar to mine:
Photo © David Unsworth
I appealed it, thinking I'd have a good chance, given the circumstances (lots of snow) and the fact that there was only one picture similar to mine.
Guess what.. I was wrong. Still badcommon.
I assume this is due to the fact that there are already 125 photos of this aircraft in the DB. But isn't more shots better? To get a bigger database? With different angles/views?
I vote that badcommon should be scrapped  white
I'll probably get  flamed  now, so go ahead if you can't resist..
Kas
Airliners.net Crew - Head Photo Screener
mygind66
RE: Another Badcommon Issue
Mon Mar 21, 2005 4:53 am
125 is a large number actually and this is a database basically..
Nice photo Kas anyway...
Good luck next time
Enrique
SA006
Mon Mar 21, 2005 5:09 am
Kas
Hows about showing us the full size photo? 125 is alot of photos for one aircraft , as Enrique pointed out. For you to get a shot accepted of that particular plane it has to be of either A) A completely original angle , B) Supreme quality or C) Taken in a different location(eg , Not AMS)
Thats my take on badcommon.
Keep shooting Kasje!
-SA006  wave
Proudly South African
Newark777
Mon Mar 21, 2005 5:10 am
What I don't understand is the consistency of it. Yours gets rejected, but this one was accepted just on March 13. No offense to photog, as it is a very nice photo, just using it as an example. If anything, yours is a more unique angle, and this one is the usual AMS departure angle.
Photo © Jeffrey groeneweg
Harry
airkas1
Crew
Mon Mar 21, 2005 5:34 am
Quoting Mygind66 (Reply 1):
I know. That's what must've caused the badcommon rejection without a doubt. But what harm can more pictures do?
Quoting SA006 (Reply 2):
Zak, As I said... This is only the 2nd shot of this aircraft from this angle. The screeners can't be that picky, can they...?
Kas
SA006
Mon Mar 21, 2005 5:39 am
Quoting AirKas1 (Reply 4):
 crazy
-SA006
airkas1
Crew
Mon Mar 21, 2005 5:42 am
No need to say more Zakje  point
wietse
Mon Mar 21, 2005 5:54 am
Kas, what is the quality on the full size image like? If it is acceptable you will have a hard time. It should be supreme to those already in the DB. Wether or not there is only 1 other shot of a same angle is not important. The fact that there are 125 photos in total is.
Wietse de Graaf
airkas1
Crew
Mon Mar 21, 2005 6:22 am
I guess I would take the dive then. I assume it's not really superior, it's more normal, or acceptable as you say. So I guess this will be a lost case  white
Thanks for the thoughts.
Kas
