gust
Is (image Stabilisator) Question
Fri Mar 25, 2005 4:33 am
Hi,
I use the canon 100-400 lens,works great with the IS on (mode2) for panning shots.
For photo's taken from behind or head on I have variable success with the IS on.(you not really panning)
What is the best for such photo's ,IS on or off.
I mean photo's like this
Photo © Magnus Trippler
Photo © Peter Unmuth - VAP
grt,
[Edited 2005-03-24 20:37:54]
chris78cpr
RE: Is (image Stabilisator) Question
Fri Mar 25, 2005 5:04 am
For stationary subjects mode 1 is the best mode however it is generally regarded that leaving it in Mode 2 has no negative effect on the image or the IS.
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
dc10tim
Fri Mar 25, 2005 5:34 am
Hi Gust,
I've only had my IS lens a couple of weeks so I'm a complete novice. For stationary shots I have it in mode 1 and mode 2 for panning shots. However, if the aircraft is moving very slightly and your only panning a very small amount, I have found that mode 1 seems to work just as well, if not better.
Tim.
Obviously missing something....
wietse
Fri Mar 25, 2005 6:12 am
I have had it for almost 2 years now, and I never switch IS modes.
Wietse de Graaf
sulman
Fri Mar 25, 2005 6:19 am
Because I'm a cynic and fond of jumping to conclusions, I thought IS had to be overrated.
Well, I was blown away when I tried a 100-400 for the first time recently; A real joy to use, and I was pleasantly surprised how much it helps at the long end, although the visual sensation can be quite odd as the IS 'snaps' the view occasionally.
I most definitely want one.
James
JAT74L
Fri Mar 25, 2005 7:13 am
I didn't realise how good it was on my 100-400L until I turned it off! I'm almost always on mode 2 although 1 is good for still or dead ahead approaching objects.
Wietse... you never switch modes. 1 or 2?
John
I like trains just as much as planes but trains don't like the Atlantic!
wietse
Fri Mar 25, 2005 7:14 am
I knew I should have added that  Wink Mode 2. Always. unless on a tripod, I switch IS off completely.
Wietse de Graaf
