jumbojim747
Would This Be Rejected For Bad Personal.?
Fri Mar 25, 2005 2:08 pm
I don't want to waste screeners time as i only load what i think has a chance.
But im not sure if i should try with this shot .
Any advice would be appreciated .
On a wing and a prayer
Q330
RE: Would This Be Rejected For Bad Personal.?
Fri Mar 25, 2005 3:51 pm
Quoting JumboJim747 (Thread starter):
Only if the screener decides to write you a personal message. Wink If you mean badpeople, I really can't tell because the photo is so small. Looking at that crop though, I think it could get baddistance.
-Q
Long live the A330!
Psych
Fri Mar 25, 2005 5:09 pm
Hi Alan,
I can't see what the problem would be from a bad personal point of view. Were you thinking it may be an issue being able to see a private pilot?
I would agree with Q that a tighter crop may be advantageous.
Enjoy the weekend.
All the best.
Paul
TZ
Fri Mar 25, 2005 6:31 pm
As the others have already said, badpersonal is a special rejection criteria which allows us to write a personal-message to the photographer. Its purpose is to allow us to explain a rejection to a photographer if something is not obvious - an example would be "Please list airport according to standards" or "CMOS dust above wing".
badpeople is highly unlikely to be the rejection reason here - the flight crew and passengers are not reasons for a badpeople rejection if they are going about their normal business while flying the aircraft, if observed from the outside and not dominant in the photograph. An image like yours would not be badpeople.
It does need a tighter crop, and may perhaps be slightly blurry, but without seeing the full-size version it's hard to say. Certainly looks quite nice in other regards.
Tamsin (a.net screening crew)
TZ Aviation - Aeropuerto de los Banditos Team Images
jumbojim747
Fri Mar 25, 2005 7:40 pm
First of all thanks for the quick replies guys
Q330 , Psych, tamsin.
Second i got my wires crossed here because i was referring to the peoples faces in the chopper being seen now i know its called bad people not bad personal.
Thanks guys for clearing it up
Quoting Psych (Reply 2):
Quoting Q330 (Reply 1):
If you think it has a chance i will try another crop and see what happens thanks psych.and Q330
Quoting Tamsin (Reply 3):
Tamsin here is the link to the full size pic if you also think it may have a chance i will recrop and try with it thanks again guys for all the help.
http://img.photobucket.com/albums/v337/alan747/helicopterridejpg.jpg
Psych
Fri Mar 25, 2005 11:20 pm
Something looks wrong there Alan. I followed that link you posted, but the photo looks the same size as the one here.
Anyway, as we now know the people are not a problem, I think a tight crop will make it look better, assuming you have the quality. Is the photo already edited? For me the one thing to watch out for on the basis of what I can see would be the tail, which looks like it may need to be sharper.
Good luck with it.
Paul
jumbojim747
Sat Mar 26, 2005 11:08 am
Paul
That is the maximum size photobucket will let me upload
Im not sure if there is another way to do it.
Anyway ill see what happens and thank you and everyone else for the help
LeanOfPeak
Sat Mar 26, 2005 2:31 pm
What are the dimensions of the original image?
jumbojim747
Sat Mar 26, 2005 3:14 pm
LeanOfPeak
3054x2336 thats the uncropped size
LeanOfPeak
Sun Mar 27, 2005 12:02 pm
Then, assuming the quality is there (It's difficult to tell from the smaller image), I see no trouble whatsoever with an acceptable 1024x*** full-frame crop.
jumbojim747
Sun Mar 27, 2005 5:30 pm
I've done it to 1024 and have submitted it see how i go.
Thank you once again for your assistance and everyone else cheers
Users browsing this forum: Google Adsense [Bot], PanAm_DC10 and 1 guest
