oly720man
So, Which Photo Is "right"?
Fri Apr 01, 2005 3:52 am
2 photos taken at more or less the same time (2nd May 2004) at MAN, but with different outcomes, exposure wise.
Photo © James Rowson
Too dark?
Photo © Danny Hill - AirlinesOnPrint
Too pale? Though it was a misty morning.
clickhappy
RE: So, Which Photo Is "right"?
Fri Apr 01, 2005 4:27 am
I don't think either is right, although I wasn't there, so I can't be 100% certain.
To me the top shot looks like it has had Auto Levels applied, the second one no Levels at all. I think the 'correct' shot would be somewhere in between.
Both are nice shots. Good angle and well composed.
Nice result Big grin
DLKAPA
Fri Apr 01, 2005 4:43 am
Don't give up hope for these shots yet. Add a little bit of contrast to the second shot by using a brightness/contrast layer and get it to where it looks a bit less "misty" and send it in. This shot looks like it has some real good potential.
PUnmuth@VIE
Fri Apr 01, 2005 4:51 am
Quoting DLKAPA (Reply 2):
Good morning.  Big grin No need to send them in cause both shots are already in the database.
Granite
Fri Apr 01, 2005 5:02 am
Hi all
So what's the point here?
Two different shots from two different photographers and possibly two different cameras.
Andrew, do you have one to upload? We would like to see it.
Gary
sulman
Fri Apr 01, 2005 5:13 am
Not sure what the point of the post is, but it can be an interesting exercise, and one of the fun things about DSLR processing. Different photographers will usually get different results from their workflow.
The exception is when the conditions are so favourable that the camera achieves an ideal capture, and all that's left to do is crop and sharpen.
Personally, these sunny but slightly muggy days have really tested my post-processing ability, but it certainly makes it rewarding when you succesfully recreate what you saw through the viewfinder.
James
Edit: To answer the question, as Royal said, I think it's down to the levels. Different white & black points have been chosen, or simply a different interpretation with the curve tool.
[Edited 2005-03-31 21:15:08]
DLKAPA
Fri Apr 01, 2005 5:19 am
Quoting PUnmuth@VIE (Reply 3):
ok wow, I completely missed the point of that one...
apuneger
Fri Apr 01, 2005 7:13 am
Personally I like the first one more. The second photo is just way too bright in the dark areas and I think it takes away a lot of the 'depth' in the composition, certainly when comparing to the other one.
Maybe some might think that the first one is a bit too dark, but for me it has the best contrast of the two photos, by far. No offence to the photographer of the second photo of course.
Greets,
Ivan
Ivan Coninx - Brussels Aviation Photography
jrowson
Fri Apr 01, 2005 7:52 am
Good evening all,
The 1st photo was taken by myself in the days when i was using a 300D. To me the photo looks right, or I wouldn't have uploaded it. A number of different variables come into play though to cause the differences. Firstly Danny uses a different camera to me (10D I think?). Secondly, beacause the 300D has a tendency to blow out highlights, I was most likely under-exposing by 1/3, despite it being misty. I don't use auto levels to process. I would have used photoshop's level adjustment using the histogram. Monitor setup could cause the differences to.
I perceive my image to be right, as it looks right to me. I can't see how there is a definative answer to what is right. If it wasn't right it wouldn't be on Anet  Smile.
Thanks for plugging the shot anyway, it's much appreciated  Wink.
James.
James Rowson
jumbojim747
Fri Apr 01, 2005 8:51 am
Quoting DLKAPA (Reply 6):
Eric your not the only one .
Had us all going for a while .
I had both pictures open and was having a close look at which would look better when i realized they are already in the DB.
On a wing and a prayer
oly720man
Fri Apr 01, 2005 6:57 pm
OK, having left this to stew for a few hours, my question was really about how much a photo could have been adjusted or how much it can be adjusted (levels/contrast/brightness, etc, etc). What the eye sees and what the camera records are different and everyone has a different idea of what looks right. Do people try and reproduce the conditions (weather/light) on the day when postprocessing or try and get the plane looking its best?
Maybe I should have said that the photos were already in the DB, but I presumed that the layout would give this away.
Incidentally, it was interesting looking at the AP-BGL photos and just about all of them were at MAN with occasional others at LHR, JFK, Toronto and IAH.
