rootsair
How Was This Picture Taken?
Mon Apr 18, 2005 5:39 am
Hi I came up with this picture in the most popular photo section . As the thread topic states, how was it taken? To my belief it must have been from a helicopter. However are helicopters allowed to fly that close to aircrafts?
If the picture WAS NOT taken by a helicopter , then how was it taken ?
BM
Photo © Sam Chui
A man without the knowledge of his past history,culture and origins is like a tree without roots
Newark777
RE: How Was This Picture Taken?
Mon Apr 18, 2005 5:41 am
Probably from a Cessna, or some other small plane. He probably got clearance through the airspace, and used a nice telephoto to get the shot.
Harry
LHSebi
Mon Apr 18, 2005 6:05 am
Search for oh too many threads that start something like "this is a fake!" or "Is this real?". In LAX you have a corridor going over the airport at (I believe) 3000ft. where you are allowed to fly through with clearance. LAX departing aircraft level off 1500 feet below you until they are above the water, then continue the climb (once out of the corridor). Search for the LAX most popular photos, you will find several made this way (Daniel Werner and others by Sam Chui come to mind).
Hope this helps,
Sebastian
I guess that's what happens in the end, you start thinking about the beginning.
timz
RE: LAX VFR Corridor
Mon Apr 18, 2005 7:33 am
Looking at the plane's shadow, your eye assumes the sun is at the 737's 9-o'clock position-- but looking at the shadows of the streetlights you see that it isn't. In other words, the camera is not pointed down as steeply as your eye tends to think, and the camera plane could be passing over the middle of LAX rather than the runway end.
timz
RE: More LAX Pics
Mon Apr 18, 2005 9:28 am
If you haven't seen the other similar pics, use the photo search for pics at LAX in the Air-to-Air category. There's about 20 of them now.
Newark777
Mon Apr 18, 2005 9:37 am
Quoting Timz (Reply 4):
Or you could just click on the link to the most popular of the past year on the homepage, one of them is the second to show up.
Photo © Daniel Werner
Harry
N178UA
Mon Apr 18, 2005 10:18 am
Yes Timz got it right, we're passing midfield instead of shoreline.
Unfortunatly angles like Daniel's shot is no longer possible, the new shoreline arrangement is restricted at min 5500 feet and subject to approval (not always available in busy hours)
Sam
Rotate
Mon Apr 18, 2005 12:14 pm
OMG!
how it was taken?
It was taken with a Nikon DSLR by Sam chui, sitting in a small prop comuter , surfing down LAX.
I know why I have been off from the Forum so long .....
Robin
PS: Try in in LAX, coast, passing by, etc>
ABC
concord977
Mon Apr 18, 2005 3:14 pm
Sam,
I know that a strong zoom will compress the background and sometimes flatten an image.
But I am still amazed at the sharp angle of climb by this 744 in Daniel's shot. Is there some other factor that exaggerates the way it looks?
(I KNOW THE PHOTO IS REAL, I am just trying to understand how the effect was created)
Curt
No info
DLKAPA
Mon Apr 18, 2005 3:18 pm
Nope, looks like just normal zoom compression.
timz
Tue Apr 19, 2005 2:51 am
"But I am still amazed at the sharp angle of climb by this 744 in Daniel's shot."
Your eye sees the near-parallel runway edges and concludes that the camera is pointed almost straight down at the runway. But with the very long lens the runway edges will be near parallel even tho the camera is only pointed maybe 20 degrees below horizontal.
