paulinbna
Bad Quality And Bad Motiv
Sun Apr 24, 2005 8:37 am
Tried to upload something different and got bad quality and bad motiv.
Any advise why??
http://www.airliners.net/procphotos/...hoto.main?filename=N502MJ_4178.jpg
Paul
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
A346Dude
RE: Bad Quality And Bad Motiv
Sun Apr 24, 2005 8:44 am
Paul,
Neat idea and cool result.
I would think the badmotiv is because the landing gear is not seperate from the building in the background. As for the badquality, it is harder to pinpoint, but it seems that in the brighter area of the plane (right around where the sun is) just isn't quite "right". Unfortunately, I would guess the landing gear issue would prevent it from being accepted.
Try it again though, I think this type of shot has some potential.
A346Dude
You know the gear is up and locked when it takes full throttle to taxi to the terminal.
LHSebi
Sun Apr 24, 2005 8:49 am
Hi Paul,
Nice shot! However, I agree with badmotiv: You can not really immediately distinguish the bottom of the aircraft from the houses (if you understand what I mean). If you could have made that shot while the plane was higher up in the sky, you would have had more of a chance, I think.
As for the badquality, it looks like you have a lens flare. I think if you would have bumped up the aperture a bit, it could have worked.
Good luck!
Sebastian
I guess that's what happens in the end, you start thinking about the beginning.
Users browsing this forum: dvincent and 2 guests
