TACAA320
About The Canon 350D SRL. 8 M Pixels
Sun Apr 24, 2005 3:27 pm
Hi,
Does anyone have the Canon 350?
How does it performed? Too much difference with the 300?
As a simple amateur, I'm undecided between 6,3 and 8 mega pixels.
Comments welcome.
Thanks in advance to all.
Psych
RE: About The Canon 350D SRL. 8 M Pixels
Sun Apr 24, 2005 3:53 pm
Hi,
I'm no expert, but I think you'll find that the difference between 3 and 6 megapixels is huge in terms of quality. Even if you are a 'simple' amateur, that difference will be obvious in your photographs and, given the huge price reductions in the area of 6 megapixels, I would go for that at the minimum without thinking twice.
Obviously, the more pixels the better but, having looked at a lot of photos from the 20D (same pixels as the 350D), I don't think the improvement in quality is of the same order as the jump from, say, 3 to 6 megapixels.
I have a 300D and am very happy with the picture quality. But that's not to say I wouldn't like to 'upgrade'  biggrin . There are aspects of the 350D that I think, as a 300D user, would be very beneficial, but the price difference will be a key factor for some time to come, as the 300D is now getting so much cheaper. I'm planning on further introductions which will result in the 20D price eventually dropping in the way the 300D recently has done  wink .
Paul
OD720
Sun Apr 24, 2005 4:10 pm
You shouldn't be fooled by the MPs of the camera. This doesn't mean that it's not too important, I think Paul explains it quite well.
Here are a few things you should worry about between the 300D and 350 D.
350D has a bigger buffer meaning that you can take more consecutive shots at a time.
350D has AI Servo which most consider important in sports photography.
350D starts up almost instantly, 300D takes between 3-4 seconds and some think that they may miss a shot.
A disadvantage of the 350D is that it's too small and large lenses may feel a little disbalanced when attached to it. But since you are getting the 75-300, you shouldn't worry about it.
Hope this helps.
G-CIVP
Sun Apr 24, 2005 6:03 pm
If anything, the 350D is much easier to handle than some of the earlier, heavier digital SLR models. I think there's a bit of a myth, of the bigger the camera, the better! (now, now, no smirking)
As an aside, one of the things which put me off the 10D is seeing a photographers with great big battery packs strapped on them; it all looked a bit too cumbersome.
350D does RAW, which I don't think the 300D does.
GOT
Sun Apr 24, 2005 6:51 pm
Quoting G-CIVP (Reply 3):
Wrong. The 300D takes RAW-pictures.
/Robert
Just like birdwatching - without having to be so damned quiet!
sulman
Sun Apr 24, 2005 7:24 pm
Now that I've seen the 350 a few times, I don't think much on the size issue. What I would say is get a 300D and a decent lens - you can get very good results with it.
James
TACAA320
Sun Apr 24, 2005 10:25 pm
Sincere thanks to all folks!  Smile
TACAA320
Sun Apr 24, 2005 11:36 pm
Quoting GOT (Reply 4):
once again sorry for my ignorance. What's a RAW picture?
sulman
Sun Apr 24, 2005 11:58 pm
Quoting TACAA320 (Reply 7):
When you shoot jpeg, the camera actually converts the image to .jpg format with certain defined parameters, such as colour tone, contrast, exposure compensation, sharpness, and white balance.
Example:
It's a nice sunny day, and you're shooting a white painted aircraft. You know the 300D will probably blow the exposure on the fuselage, so you set -0.6 so that the camera underexposes a little. You also set the white balance to 'sunny' or 'auto' so that the appropriate colour temperature is applied.
A straight conversion to jpeg will give a nice image, but you might get something a little dull with a blue colour cast because the camera's borked the colour temperature. but if you record it as RAW you can alter these things with no loss in quality, before you convert it. It means editing takes a little longer, but you've much greater control, and get the scene looking how it did on the day.
All this is before you start fooling around with levels, curves, and sharpening etc in photoshop. Since using raw my PS workflow is a bit quicker, because you have a much nicer image to start off with.
James
TACAA320
Mon Apr 25, 2005 12:07 am
Thanks James.
Understood.
United_fan
Mon Apr 25, 2005 2:59 am
I just got one and I love it! I also bought a 70-300mm lense. What an improvement from the Sony 717 it replaced. I love that it takes shots as fast as you can push the button . It doesn't have the delay like the Sony did.
Here's a shot I got accepted with it...
Photo © Scott Kerhaert
Scott.
Champagne For My Real Friends,and Real Pain For My Sham Friends
G-CIVP
Mon Apr 25, 2005 3:41 am
Robert - Noted. Thanks for the correction. Tim.
b757300
Mon Apr 25, 2005 8:06 am
Well, I don't post much in this forum as I haven't uploaded anything to Airliners.net in 3 years but the 350D is something I can actually talk about.
Having used the 350D twice now, once at IAH and once at DFW, I can say the camera itself produces excellent pictures. The 350D's only *possible* drawback (at least that I've found so far) would be its smaller size but of course this won't bother everyone. I haven't found it to be a problem but then again it isn't much smaller than the film SLR I was using before. The quality of the pictures has been far better than anything I ever had with a slide scanner. As of right now I don't think I have any pictures that would get accepted here, not because of quality, but simply because they're too plain and "common". (I might try uploading one of the water cannon salute for SWA's last IAH flight.)
Just as a side note, the 350D's RAW files can't be opened in Photoshop Elements (and I'm assuming most other photo editing programs) right now. Adobe hasn't released an update for the 350D and the one that they released for the 20D doesn't work for the 350D.
"There is no victory at bargain basement prices."
