draigonair
Bad Color Help Please
Fri May 20, 2005 7:31 am
Hey guys,
I got this rejection for badcolor, and most will say yes looks very yellow. But in Singapore there are very very yellow flood lights causing this, hence it is the correct color. Anyway to get it on if i explain this to the screeners?
http://www.airliners.net/addphotos/rejections/big/HSPGOstand2nd.jpg
Nick
cheers
clickhappy
RE: Bad Color Help Please
Fri May 20, 2005 7:35 am
I believe it was also rejected for badquality?
Learn to use the white balance correctly and those orange lights will not be nearly as bad.
draigonair
Fri May 20, 2005 7:39 am
Yeh was badquality as wel...but for future pictures. I did try to make it more light but yellow is very strong in this picture. Ill, when home, try to fiddle around to make it less yellow.
cheers
clickhappy
Fri May 20, 2005 7:42 am
if you shoot in raw you might be able to alter the white balance, but my experiences in Photoshop tell me that trying to fix it there leads to blown out highlights...
xenon
Fri May 20, 2005 8:07 am
Clickhappy, Nick,
Try Capture One Pro!
Its a fantastic tool for RAW files. You can 'easily' correct the white-balans.
My experience to correct the WB in PS was the the same as you Clickhappy.
Capture One Pro was the solution.
Daniel
AirTeamImages -ATI-
draigonair
Sat May 21, 2005 8:03 am
Thanks guys,
but this wasn't in RAW, too bad. Ill try to correct it but aah oh well only a gate shot will get more opportunity's in the future! Thanks for the help
cheers
Nick
cheers
Users browsing this forum: zhaoruibo and 9 guests
