PUnmuth@VIE
Screener Request On Categories
Tue May 24, 2005 10:36 pm
Hi all!
Lately the badcategory rejections get overhand because people not reading and/or following the help-text on the upload page.
So please check the correct category when uploading.
Some examples:
Hybrid/Special Marking
The help text on the category "Hybrid/Special marking" is the following
Hybrid / special marking
This includes all kinds of unusual paint schemes that doesn't fit into the Special Paint Schemes category. Examples are mixtures of two airlines paint schemes (hybrids) or special markings that are limited to one or a few aircraft. Airliners without paint scheme or in an all white paint scheme should also be included here. Note that this is ONLY for airliners! Not for helicopters, blimps, props etc.
So this planes for example should be uploaded under that category:
Photo © Georg Noack
Very common for missing the category are the transavia planes in all white or the one leased from Sun Country
Photo © MartinV
Photo © Sergio Domingos
and of course the Air Canada hybrids
Photo © John smitherman
Photo © Peter Tsagaris - CYOW Airport Watch
Government
Many Universities in the USA seem to own planes. Some of them come up with the government category selected. This should per definition for the database not be the case!!!!
Single engine prop
don't forget to select this category if its a single engine prop!!!! Sounds easy but happens quite frequently.
Just to name the most common errors.
Note that screeners have no checkboxes to change the wrong categories in a easy way. If we change it we have to type a lengthy text for each category in a field separated by commas. This is simply too time consuming. So all the wrong categories get rejected. Which doesn't really reduce the Q size because they come up again this time hopefully with the correct ones selected.
So please take your time to RTFM  Wink (Note the smiley) that's why Johan did those help text links on the upload pages.
Thanks for reading this and reading the help text links!
Help us to help you.
Peter
javibi
RE: Screener Request On Categories
Tue May 24, 2005 10:42 pm
Thanks for your work, Peter.
Quoting PUnmuth@VIE (Thread starter):
Could this be solved, so we all save some time? Mistakes will keep happening for sure.
j
PUnmuth@VIE
Tue May 24, 2005 10:53 pm
Quoting Javibi (Reply 1):
Unfortunately not. The screening page has one of the lower priorities in the To Do List  Wink
I agree that errors happen to everyone. I was just trying to point out the most common ones currently happening and how easy it is to avoid them.
PUnmuth@VIE
Tue May 24, 2005 11:57 pm
Some more common erroros.
We have categories for Cargo planes and Helicopters. Please use them!!!!!
TZ
Wed May 25, 2005 12:29 am
I would not wish Johan to waste time on that when all that's needed is for photographers to read the help sections properly.
Tamsin
TZ Aviation - Aeropuerto de los Banditos Team Images
jfktowerfan
Editor
Wed May 25, 2005 12:46 am
Just a few other points on categories that I see as common mistakes.
Single engine props should be listed as "Single engine prop" not "Airliner or other"
Most non-airline jets(BBJ, Global Express, Challengers, Citations, etc.) should be list as "Business" not "Private"
"Tail / Winglet" and "Nose" apply only to airliners not Military, props, business etc.
Corey
C'mon Man
