MarkusB
Editor
Teleconverter: Camera Body's Or Lense's Brand?
Thu May 26, 2005 10:49 pm
Hi all,
When you have, say, a Canon D300/Rebel with a Sigma lens and you intend to get a teleconverter: Is it (generally speaking) advisable to buy a converter of the same brand as the camera body or do you match the converter brand with that of the lens?
Thanks for taking the time to reply,
Markus.
fergulmcc
RE: Teleconverter: Camera Body's Or Lense's Brand?
Fri May 27, 2005 12:10 am
Markus
Personaly, I would stick with a Canon converter, than go for the cheaper alternative. When I was getting my lenses I was advised to stick with the Canon as I was getting Canon L lenses. Fitting a converter will cause your lens to loose a stop or two, depending which one you get, 1.4 = -1 stop and x2 = -2 stops. However you may need to check whether the Canon converter will fit onto the Sigma lens. My Sigma 24-70 f2.8 DG EX won't fit onto my Canon 1.4 converter, not that I wanted to but I was just messing around the other day and found that it won't go. As for the other larger Sigma lenses you may have to get that checked out.
Take care
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
Staffan
Fri May 27, 2005 12:56 am
I would get a converter that maches the lens i.e Sigma converter for Sigma lens and Canon converter for Canon lens.
Staffan
MarkusB
Editor
Fri May 27, 2005 1:25 am
Thanks guys.
2 replies, 2 differing opinions. - This is going to be interesting...
I realize that in the 1st place it's most probably a matter of which converter has the better technical specifications, but could one have (for example) a greater likelihood of causing the dreaded "error 99" or passing incorrect readings to the cam's display or other technical/electronic issues?
Looking forward to finding out which opinion wins.
Markus.
fergulmcc
Fri May 27, 2005 8:26 am
Quoting Staffan (Reply 2):
Staffan is probably right here, as I said in my first reply, you will have to check which converter fits your lens before buying. I have a feeling that the Canon converter won't fit the Sigma lens.
Take care
Fergul  sun
MarkusB
Editor
Fri May 27, 2005 6:29 pm
I see. I had never thought that chances are that it could not fit simply because it can not be mounted.
Well thanks for your help, guys, I'll see a local store tomorrow to get one.
Markus.
chris78cpr
Fri May 27, 2005 6:39 pm
With convertors you can only use a prime lens with a focal length of 135mm or greater. Any lens with focal below this will not work as the element sits too far back and will hit the convertor.
For zooms it is possible to use a convertor with a focal length as short as 70mm at the wide end of a zoom. Lenses such as 70-200's will work but a 24-70 will not.
In terms of what to get. I have a sigma 120-300 and it works great with my canon 1.4xII. I would reccomend canon's.
However with some of the third party convertors you can get AF to work with lenses with apertures of F5.6 or more.
An example of this is the tamron pro 1.4x and the kenko 1.4x which both reportedly AF with the 100-400 on a 1.6 crop body.
This is specualtion however, i have only used the canon myself and i will stick with them as they seem to be the best.
Any more questions, feel free to email me.
Chris
5D2/7D/1D2(soon to be a 1Dx) 17-40L/24-105L/70-200F2.8L/100-400L/24F1.4LII/50F1.2L/85F1.2LII
oly720man
Fri May 27, 2005 6:40 pm
Beware Sigmas. You could lose AF and some camera functions. If I could afford it (at the moment, having recently got a 300D) I'd get the genuine article, but I've just ebayed a cheaper one (Jessops) to have a go with my 400mm (Tokina) and see how it goes.
Jan Mogren
Fri May 27, 2005 6:46 pm
The EF 80-200 2,8 L will not fit on a Canon converter.
/JM
AeroPresentation - Airline DVD's filmed in High Definition
chris78cpr
Fri May 27, 2005 7:10 pm
Quoting Jan Mogren (Reply 8):
/JM
Really? I have heard of several people on FM.com using it successfully with one. Maybe it is one from a tamron or sigma though.
Chris
Jan Mogren
Fri May 27, 2005 7:16 pm
Yes, that old one has rear elements too far rear to fit.
/JM
chris78cpr
Fri May 27, 2005 7:40 pm
Ok, my bad! Didnt know about that one. Thanks for pointing it out.
Chris
Woody001
Fri May 27, 2005 10:25 pm
The Canon converters (1.4x & 2x) will not work with the Sigma 70-200mm f2.8 lens either, they physically won't fit.
Ian.
If I could just get the afterburner working...
MarkusB
Editor
Sat May 28, 2005 3:26 am
Guys,
thanks to all for your opinions, that was some interesting reading. I'll surely bug the salesman some more tomorrow and I'll also ask if I can try both before making the decision.
Markus.
