blue747
Newbie Help
Fri May 27, 2005 2:01 am
Do any these stand a chance of getting in? Which ones should i delete
from the queue? Any advice would be greatly appreciated? After 40+ rejections, I think i need some help? I am using a Canon 300d & 75-300mm III
Thanks in advance! Pat
http://www.airliners.net/addphotos/s...=blue747@gmail.com&date=2005-05-22
Fly747
RE: Newbie Help
Fri May 27, 2005 2:18 am
Hi Pat,
I think your sunset shots were somewhat low on light and you played with the levels too much thus giving them a hazy-milky look. Your shots number 2 and 3 need a little CCW rotation. Shots 4 and 5 look pretty good, however it is the same plane, same angle which could give you a baddouble rejection.
I am no expert, just my
Keep shooting and don't give up.
Ivan
[Edited 2005-05-26 19:19:57]
bubbles
Crew
RE: Newbie Help
Fri May 27, 2005 2:20 am
Hi,
I'm also a newbie here. If anything I said is wrong, please forgive me. I think some of your shots are pretty grainy, e.g., the two Continental ones, that may result in badquality rejection.
Hongyin.
Fly747
RE: Newbie Help
Fri May 27, 2005 2:22 am
Yeah, and the grain too  thumbsup
[Edited 2005-05-26 19:22:41]
blue747
RE: Newbie Help
Fri May 27, 2005 5:20 am
Thanks for your help!!! I will try to pay more
attention to grain in future editing. thanks! pat
WhyWhyZed
RE: Newbie Help
Fri May 27, 2005 5:55 am
May I suggest you use Neat Image for some of your grain...
Check it out...
http://www.neatimage.com/
- Jason DePodesta
DLKAPA
RE: Newbie Help
Fri May 27, 2005 6:04 am
The two conti 757's look sick (and I mean that in a good way).
senorcarnival
RE: Newbie Help
Fri May 27, 2005 6:07 am
Quoting WhyWhyZed (Reply 5):
Check it out...
In using NeatImage, would it be recommended to apply it before or after a PhotoShop workflow?
Oh no, she's getting impatient! Take a stab at it!
WhyWhyZed
RE: Newbie Help
Fri May 27, 2005 6:53 am
Quoting Senorcarnival (Reply 7):
Check it out...
Before your photoshop workflow.
- Jason DePodesta
DLKAPA
RE: Newbie Help
Fri May 27, 2005 6:54 am
Make it the very first thing you do with a photo.
bubbles
Crew
RE: Newbie Help
Fri May 27, 2005 7:11 am
Quoting WhyWhyZed (Reply 8):
Jason,
As before Photoshop workflow, could Photoshop also generate some grains later on whilst processing the photo? Just out of my curiosity, one more question - will this tool somewhat impact the photo quality?
Hongyin.
DLKAPA
RE: Newbie Help
Fri May 27, 2005 7:26 am
Quoting Bubbles (Reply 10):
Usually no, it only brings out the grain that is already present.
senorcarnival
RE: Newbie Help
Fri May 27, 2005 7:44 am
Quoting DLKAPA (Reply 11):
Doesn't too much USM create grainyness though, or is that also just bringing out existing noise?
WhyWhyZed
RE: Newbie Help
Fri May 27, 2005 8:06 am
Quoting Senorcarnival (Reply 12):
It's bringing out the existing grain. What USM does is sharpen the closest pixels around it, so if you got a grain spot, the USM will sharpen the pixels around it and make it stand out more. That's why it's suggested that you try and avoid sharpening unnecessary parts of the photo...such as the sky.
- Jason DePodesta
ita350
RE: Newbie Help
Fri May 27, 2005 8:48 am
I hope you dont mind but ive found a few dust spots in you photo.
waketurbulence
RE: Newbie Help
Fri May 27, 2005 8:52 am
ITA350 I seriously hope you are joking. If you are I am getting the humor, if not those are not spots. Those are marks from the jetway.
-Matt
Users browsing this forum: solro and 1 guest
