gladave
Some Help From The Experts
Fri May 27, 2005 7:27 pm
Hey folks,
ok im determind to get some pictures on a.net one of these days, so instead of uploading them n waiting for failing (wasting the screeners time) i am going to ask for help and advice in here.
I want to learn how to do all the editing needed (sharpening etc) so any pointers would go down very well.
how would the following do?
what do i need to do to get the db (if they good enough)
even advice on taking better shots etc..
Using Kinica Monita Diamage Z1
David
NO URLS in signature
WhyWhyZed
RE: Some Help From The Experts
Fri May 27, 2005 7:33 pm
http://rockymountainavphotos.com/Eric/faq.html
but I don't think photo #3 has a chance by the time you level the horizon. Also 4 is questionable, but I do believe 1 and 2 could get on, if of course you got room to work with (crop), and the quality is there in the large version.
- Jason DePodesta
INNflight
Fri May 27, 2005 8:15 pm
David,
First of all, if you can, link ( note: link, not post - they make the thread slower to load on slow connections ) some photos with size 1024 pixels or wider, so we can judge the quality. You can't see wether one photo is good enough quality on the small photos in the original post.
The workflow Jason linked above is a good way to start editing.
Florian
Jet Visuals
gladave
Sat May 28, 2005 1:52 am
heya
ok here are the full unedited pictures, they bout 1.5mb+ each so pretty big.
anyone able to help me edit them (if they r good enough to attempt a shot in the db)
http://planepics.info/temp/aa1.jpg
http://planepics.info/temp/ba1.jpg
http://planepics.info/temp/babp1.jpg
http://planepics.info/temp/easy1.jpg
http://planepics.info/temp/easy2.jpg
http://planepics.info/temp/ba2.jpg
David
bubbles
Crew
Sat May 28, 2005 3:20 am
Hi, David,
I did a quick edit for easy1.jpg. Can I send it to you by email?
_Hongyin_
gladave
Sat May 28, 2005 3:48 am
yep, david@dwscomputers.com
please put in a name, will add it in the comments bit incase it gets in
 Smile
cheers
bubbles
Crew
Sat May 28, 2005 4:10 am
Quoting Gladave (Reply 3):
For ba1.jpg, I see some serious impacts by heat haze which I couldn't fix. That probably won't be accepted by A.Net. Others look good, just need to put some editing efforts.  Smile
_Hongyin_
WhyWhyZed
Sat May 28, 2005 5:23 am
I opened up the easyjet photo and did a quick post-process on it. Here's what I got... a bit grainy though.  Confused
http://www.wwspotters.com/airliners/bigouforgladave.jpg
- Jason DePodesta
bubbles
Crew
Sat May 28, 2005 5:54 am
Quoting WhyWhyZed (Reply 7):
Hi, Jason,
I also edited this one for David, and sent it to him. Obviously yours looks better than mine.  blush
_Hongyin_
WhyWhyZed
Sat May 28, 2005 5:58 am
Here's Hongyin modified photo of the BA...
http://www.wwspotters.com/airliners/ba2.jpg
- Jason DePodesta
[Edited 2005-05-27 23:22:19]
bubbles
Crew
Sat May 28, 2005 6:22 am
Quoting WhyWhyZed (Reply 9):
If you want you can email them here and i'll upload them for ya, so other can see what you've turned the originals into.
Jason,
I've sent one to your gmail box. You may check it up.
_Hongyin_
gladave
Sat May 28, 2005 6:28 am
- Jason DePodesta
is that the quality a.net would be looking for?
David
bubbles
Crew
Sat May 28, 2005 6:37 am
Quoting Gladave (Reply 11):
This is a really rash edit. Even I myself could see jaggies out there. To be honest, I'm not that optimistic.
_Hongyin_
European
Sat May 28, 2005 6:59 am
Hello
I havn't spent much time on this, as have to go soon, But here is my attempt
http://img.photobucket.com/albums/v623/Euroav/BADavids03.jpg
I'll have a few go's tommorow for you.
Good Luck David!
cya
Jimmi
[Edited 2005-05-28 00:03:19]
Come on Ryanair! Come on BOH! BASE BASE BASE! Flying high in the skies...........
Airplanepics
Sat May 28, 2005 7:03 am
Jimmi,
What did you actually do to that photo? All i can see if that you've now made it un-level.....  Confused
Simon.
Simon - London-Aviation.com
European
Sat May 28, 2005 7:04 am
Hello Simon
I said I would have a go tommorow. I changed the colour, sharpened it,and NOW leveled it out. I don't actually think the 1st one needs much editing, just a good crop.
cya
Jimmi
European
Sat May 28, 2005 7:06 am
Or there is just one that is leveled and cropped
http://img.photobucket.com/albums/v623/Euroav/David.jpg
Simon, U know I'm only a begginer myself, I just though I'd try, no harm in that.
Jimmi
gladave
Sat May 28, 2005 5:23 pm
cheers for all the editing guys, they are looking good
cant belive the difference in them
David
