paulinbna
Another Bad Category Rejection.
Fri Jun 03, 2005 3:30 pm
http://www.airliners.net/addphotos/rejections/big/Mustang_5608.jpg
I selected warbird as a category is that not right?
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
QantasA332
RE: Another Bad Category Rejection.
Fri Jun 03, 2005 3:43 pm
Did you also select "single engine prop"?
-Gabriel
PUnmuth@VIE
Fri Jun 03, 2005 3:45 pm
Warbird is correct but. BUT, on the upload confirmation page there is a frame titled The most visible aircraft on this photo is a:
Helicopter, Blimp/Airship/balloon, Single engine Prop, Glider, Airliner or Other
The category PROP should have been checked also.
Exactly this unneccesary rejections because of obvious errors made me post this thread  Wow! Screener Request On Categories (by PUnmuth@VIE May 24 2005 in Aviation Photography)
Hope this helps
Peter
ua777222
Fri Jun 03, 2005 3:47 pm
Wouldn't it be preserved as well?
Matt
"It wasn't raining when Noah built the ark."
QantasA332
Fri Jun 03, 2005 3:48 pm
The "preserved" category only applies to non-flying aircraft...
Gabriel
paulinbna
Fri Jun 03, 2005 3:58 pm
Peter I did not even think about the single engine prop thing.
Paul
Bruce
Fri Jun 03, 2005 4:01 pm
single engine prop! Wow, I never thought of that!
bruce
PUnmuth@VIE
Fri Jun 03, 2005 4:07 pm
Quoting Paulinbna (Reply 5):
Quoting Bruce (Reply 6):
RTFM  Wink
TZ
Fri Jun 03, 2005 8:34 pm
Quoting QantasA332 (Reply 4):
Actually it also applied to airworthy aircraft which are located inside a museum. This is a frequent occurence at Duxford, where the maintenance hangars form part of the museum.
However, Warbirds which are outside the museum are not to be listed as "Preserved", like you said.
Tamsin
TZ Aviation - Aeropuerto de los Banditos Team Images
