dc10tim
Should I Appeal This Rejection?
Mon Jun 06, 2005 9:08 am
Hello everyone,
I just received this rejection earlier:
http://www.airliners.net/addphotos/rejections/big/mngpaxpmedit.jpg
The reason was 'badcameraangle'. I'm assuming this really means 'badlevel' due to the lamp pole on the left. Clearly this is on a massive slant when compared to the others.
I just wondered what people's thoughts were and if there's anything I've not picked up on, as I might consider appealing depending on what you all think.
Tim.
Obviously missing something....
bubbles
Crew
RE: Should I Appeal This Rejection?
Mon Jun 06, 2005 9:24 am
Quoting DC10Tim (Thread starter):
Tim,
You're right. I think you should appeal. I encountered a similar problem before. Fortunately I didn't get badcameraangle rejection.
_Hongyin_
ua777222
Mon Jun 06, 2005 9:58 am
Badcameraangle. I hate that rejection. Had one rejected for it too recently;
http://www.airliners.net/addphotos/rejections/big/N665UA_SFO_010105.jpg
Still debating what to do with that one. Oh well. I like your shot. I do think that it is appeal quality seeing as its more than just a 'slant'
Matt
"It wasn't raining when Noah built the ark."
Newark777
I agree that you should appeal, just make it crystal clear in your appeal explanation that the one pole is not a very good reference to the overall level of the photo.
EDIT: In regards to Matt's photo, I haven't measured anything, but the photo seems to be tilted a bit CCW. It might be level according to the vertical structures, but it just looks off.
Harry
[Edited 2005-06-06 03:00:40]
Knighty
Mon Jun 06, 2005 10:00 am
The left most red and white pole has a substantial lean on it - I'm guessing that is where the rejection came from.
Knighty
Ian Knight - Proud Canon shooter!
JeffM
Mon Jun 06, 2005 10:15 am
I've seen other "badcamerangle" rejections due to a less then an optimum angle that the shot was taken from. In other words it is an un-flattering position, you could have taken a more side on shot versus this oblique angle, or waited for the aircraft to pass by all of those distracting light poles.
ua777222
Mon Jun 06, 2005 10:21 am
Quoting Newark777 (Reply 3):
I think its a no go due to the fact that it's level based off of the things around it but that it was cranking pretty fast around that turn and in my opinion the actual aircraft is tilting due to the turn + speed.
Thanks.
Matt
Newark777
Mon Jun 06, 2005 10:29 am
Exactly why I hate leveling, it's such a pain in the ass.  crazy
Harry
dc10tim
Mon Jun 06, 2005 10:35 am
Thanks guys,
Here is one from that morning with the pole on the left levelled. This is wrong and the other poles would be leaning to the right, but they are obscured by the plane, so aren't noticable. This one has passed the first round.
http://www.airliners.net/addphotos/big/ready/airgreen757timed.jpg
Jeff, you're a bit damned at that spot, as you're beyond the fence at the end of the runway, looking at them as they are turning, so the poles are inevitable.
Anyway, it's past my bedtime.
Tim.
vbonina
Mon Jun 06, 2005 11:26 am
Hi Tim
I would apeal the rejection, although the shot does look a little too sharp to me.
I like the camera angle
Vince
vbonina
Mon Jun 06, 2005 11:27 am
I take that back, Not too sharp, the shot looks great... sorry
Vince
JeffM
Mon Jun 06, 2005 12:44 pm
Quoting DC10Tim (Reply 8):
I agree, not every location is a good one. Some you just have to pass up due to the problems they present.
DLKAPA
Mon Jun 06, 2005 12:59 pm
I believe the other light poles also have a slight lean to them as in they need rotation.
Quoting UA777222 (Reply 2):
BadCameraAngle and BadInfo are rejections I don't mind. Reason: Very easy to fix.
dendrobatid
Mon Jun 06, 2005 3:38 pm
Quoting DLKAPA (Reply 12):
I'm exactly the opposite as a bad level looks like slapdash work, which it is not. The levels are very subjective and Tim has encountered the problem in a big way on this one. A glance at his photo shows what is out of level, the red and white pole, rather than the photo.
Tim, the shot is a good one and I would appeal it as I think a screener has made a mistake, an easy one to make.
When verticals are all over the place as in this photo I have taken to telling the screener which reference I have used as I think this helps them to help us.
Mick Bajcar
Airplanepics
Mon Jun 06, 2005 4:27 pm
Tim,
Your MNG picture, needs 0.5 CW rotation. See the screenshot below:
I rotated the middle light pole, you could also use the light pole on the far left as a referernce point.
Simon
Simon - London-Aviation.com
dc10tim
Mon Jun 06, 2005 6:27 pm
Thanks again guys,
I'll have a closer look at this one when I get home this evening. I think the centre lamp pole is probably the best reference, so if it needs some CW rotation it will be one to rework.
Tim.
Users browsing this forum: No registered users and 4 guests
