ltena
Is This Photo Worth For A.net Standars?
Wed Jun 15, 2005 3:30 pm
Hello guys.
I took this photo in a short visit to Toluca Mex. airport, Fedex its bringing his DC-10 instead of the A300 but I took it with not the optimal light conditions, with the sun hiding in my back, after a few post-processing it came out the final photo, do you think it has a chance here in a.net???
Ill apreciate the comments.
http://www.luistena.com.mx/varios/CRW_7333_N310FE_NI.jpg
Luis Tena Orozco. Why drink and drive when you can smoke and fly
CallMeCapt
RE: Is This Photo Worth For A.net Standars?
Wed Jun 15, 2005 3:40 pm
Too sharp. Less sharpening and it may have a chance.
I think it would get badlevel as well.
A bit of CCW rotation.
[Edited 2005-06-15 08:43:42]
Without struggle, there is no progress. (Frederick Douglass)
ltena
Wed Jun 15, 2005 3:51 pm
Hmm not much to do with high ISO... some times you dont have second chances hehehe, well next time will be
Thanx again pal's
Airplanepics
Nice picture!
Just a bit to much sharpening.
Quoting CallMeCapt (Reply 1):
Look fine to me, look at the lamp post to the left of the picture.
Simon Nicholls
Simon - London-Aviation.com
javibi
Wed Jun 15, 2005 4:08 pm
I think you could save it for A.net if you remove the jaggies from the stabilizer and around the Fedex titles, did you sharpen via duplicate layer? Did you use any noise reduction program?
And I don't understand why you complain about the light, it is beautiful!  Smile
j
ltena
Wed Jun 15, 2005 4:11 pm
Yeap looking at the post its straight ok the sharpenning its the deal here hmmm ok Ill try to lower the sharp thanx guys, Its because the stabilizer?
ltena
Wed Jun 15, 2005 4:13 pm
I used neat image for removing the noise and intellisharpen for the final touch
AKAU
Wed Jun 15, 2005 4:25 pm
Javibi
Quoting Javibi (Reply 4):
How does this work, and what is the advantage of sharpening via duplicate layer?
Andreas
javibi
Wed Jun 15, 2005 4:35 pm
Quoting AKau (Reply 7):
When you are finished with your level, etc. adjustments and have made the final crop, create a new layer via duplicate the background layer and apply the USM sharpening to this new layer. That way you can fine tune the sharpening via changing the opacity of the "background copy" layer and remove the jaggies (if any) using the eraser tool on that layer. Did I make sense?
j
AKAU
Wed Jun 15, 2005 4:54 pm
Javibi
Thank you, i'll try it.
Andreas
Users browsing this forum: Radra77w and 3 guests
