seachaz
Is The Reflection On This Going To Be An Issue?
Sat Jul 02, 2005 3:50 am
Is the reflection/glare of the sun off the window and fuselage going to be an issue on this image? Aside from that issue, I thought it was a good picture but the more I look there is something else that bugs me about it but I can't put my finger on it - Thoughts?
Large
waketurbulence
RE: Is The Reflection On This Going To Be An Issue?
Sat Jul 02, 2005 5:00 am
No, the reflection itself should not get a rejection, but it is overexposed, you can see in the reg. Hope this helps.
-Matt
seachaz
Sat Jul 02, 2005 5:03 am
I'll check the RAW see, if I can pull the exposure down some.
-Charles
DLKAPA
Sat Jul 02, 2005 5:13 am
Also a touch noisy, and a bit contrasty though not too much.
PUnmuth@VIE
Sat Jul 02, 2005 5:18 am
A bit counterclockwise rotation would help  Wink
Good luck
Peter
seachaz
Sat Jul 02, 2005 7:48 am
Leveling this photo has been a pain because of the perspective I was shooting at and the river banks in the background - I have no clear level/vertical reference to go off of. I'll give it another go when I get off work as this will be the 2nd time I've pulled it before screening, hopefully third times a charm (guess the queue limits are having the desired affect).
Users browsing this forum: javier and 6 guests
