MarkJBeckwith
Advice For A Newbie, Please...
Fri Aug 05, 2005 4:06 am
Hi all;
I have some pictures in the queue that are the results of some rejection feedback and reading a great deal on this board (including some of the workflows posted). I'd appreciate any comments on whether my photography and processing has reached a good enough level to produce images of ANet quality.
Here's some samples from the queue;
First
Second
Third
Fourth
As I said, I'm new at this and would like some advice on how to get better - plus I don't want to waste any more of the screener's time  pray
Thanks for all comments.
Mark.
One day, I might be good at this...
johndm1957
RE: Advice For A Newbie, Please...
Fri Aug 05, 2005 5:39 am
Well I'm no screener....but why the odd sizes. Are you using a widescreen monitor or something?
I'd make them 1024 wide
No.1 needs ccw rotation?
regards
[Edited 2005-08-04 22:45:11]
Canon 550D, 18-55, 50 1.8, 100-400L
fergulmcc
Fri Aug 05, 2005 5:54 am
As a newbie, these are very good shots. The only criticism I can find is that they are a tab bit over saturated, the colours are just that little bit over enhanced in my book. As for the level of No.1, I would have to disagree with John I think it looks ok. Your sizes are ok too as there a few photographers who upload at 1200*800 but I personaly prefer 1024*683. The larger the size you upload the greater the risk of a rejection for bad quality.
Hope that helps
Take care
Fergul Big grin  sun
Zambian Airways, Where the Eagles fly free!!
Psych
Fri Aug 05, 2005 7:14 am
Hi Mark - welcome to the Forum.
I would agree that these are all really good shots for someone new to this. I think they all have a good chance of success.
There are certainly no 'fatal' flaws with any of them that I can see. I would echo the view above that you will maximise you chances of reaching the high quality standards required by uploading at 1024 x 683 size. But even at the larger size, the quality looks good to me. Unlike Fergul, I generally like the level of colour saturation that you have in the photos.
I would be interested to know how you have sharpened the shots - for example, I think photo 4 might be improved at the smaller size, as this should enhance the sharpness of the image.
If you would like to discuss any issues further do feel free to email me.
All the best, and good luck with the uploads.
Paul
MarkJBeckwith
Fri Aug 05, 2005 8:35 am
Thanks for the words of encouragement guys.
Quoting Johndm1957 (Reply 1):
John;
Yes, I have a wide screen but I think I will reduce the size down to 1024 for future shots as I need all the advantage I can get!  Smile
Quoting Psych (Reply 3):
Psych:
I used this workflow; http://rockymountainavphotos.com/Eric/workflow.html pretty much to the letter. Thanks for your offer of correspondence - you don't know what you've let yourself in for.  Cool
Would you all say the pictures are worth leaving in the queue?
Mark.
Fly747
Fri Aug 05, 2005 9:09 am
Hi Mark,
Nice shots, they look ok to me as well. Out of curiosity, what kind of equipment do you use?
Ivan
MarkJBeckwith
Fri Aug 05, 2005 10:29 am
Thanks Ivan.
Quoting Fly747 (Reply 5):
I use a Rebel XT with a 75/300 III USM.
I see you're in Edmonton - I'm travelling there next week and was thinking about taking my camera. Are there good opportunities to shoot at YEG?
Cheers!
Mark.
ua777222
Fri Aug 05, 2005 10:34 am
I only use 1200*800 when I its next to impossible to make up the lost space when trying 1024*____.
Photo © Matthew Hom
Photo © Matthew Hom
Photo © Matthew Hom
Photo © Matthew Hom
Don't click if you don't want to. I'm not a big fan of plugging but I am also a big fan of 1200*800 when needed.
Take care and I hope that helps you,
Matt
"It wasn't raining when Noah built the ark."
bubbles
Crew
Fri Aug 05, 2005 10:37 am
Quoting MarkJBeckwith (Reply 6):
 cheerful  Same as my equipment!  cheerful  And very nice shots!  wave
_Hongyin_
Fly747
Fri Aug 05, 2005 11:59 am
Hi Mark,
Rebel XT rules Big grin There's a few good spots around YEG but there's not much variety. Mostly WJ 737s and AC Buses and small regional aircraft. There are weekly charters by Martinair and Air Transat to Europe. I try to make the most of it though. You can also shoot from the old terminal, I have a couple of shots from there in the database. I could show you around but I'll be out of town next week. If you want more info you can email me through my profile.
Ivan
Psych
Fri Aug 05, 2005 3:21 pm
Quoting MarkJBeckwith (Reply 4):
It was meant Mark - go for it.
As to your question - I think they are all worthy of leaving in the queue, though in your position I would re-edit the originals at 1024 size and just check that this doesn't lead to a notable increase in quality. If so I would then swap them. As I said, though I do not think any of the 4 are actually soft to a major degree, my hunch is that the same USM settings will make them appear just that bit sharper at the smaller size.
When I began uploading I started at 1600 pixels wide, because I misunderstood the upload advice and did not have much experience reading the Forum. No wonder getting acceptances was a bit challenging  wink . I then went down to 1200 wide, and now my standard upload is 1024 - partly because this is easier for so many to look at due to the size of most monitors.
Take care.
Paul
norfolkjohn
Fri Aug 05, 2005 5:45 pm
Mark,
First thing to say is - cracking shots - all of them  bigthumbsup
I would totally agree with Paul and the others about changing the size for uploading however. I made the same mistake originally of uploading at too large a size but fortunately one of the screeners was good enough to advise me fairly early on to reduce the size. I generally use 1024 wide by 768 high but in some cases, if I need a bit of extra width I just set the height to 768 and accept what ever width I'm left with provided it is no wider than 1100.
I really like vintage aircraft so I particularly like the B25, Hurricane and C47.
Just one small comment on the C47 shot - purely my personal taste - but I would crop in a little tighter on the right to cut out the wind sock as I find the way the top of it comes over the top of the wing a little distracting.
Like I say - lovely shots.
All the best,
John
One thorn of experience is worth a whole wilderness of warning.
CV747
Fri Aug 05, 2005 6:21 pm
Hi Marc,
Your pictures are really great.
You got a lot of advices in the messages before which are all good.
The screeners at airliners are nice guys and some have help me a lot with improving the processing.
But please keep your own creativity. The screeners are also people and honestly I do not agree at all with some comments, because I think that some screeners are going to deep into their own opinion on what a picture should look like. I personally like action pictures and close up details. A screener told me once that a perfect picture is taken 90° from the side, registration must be visible, etc. I don't agree, for me, your B-25 picture is close to be a perfect motive. I could not care less about a registration. It is my opinion.
I have reached most popular picture and most uploads of the day, sure, but I have not uploaded for a while because I simply don't want my pictures to be forced into someone elses idealised opinion. Today I only reduce the size to 1280px no more. The screens are growing and 800 or even 1024 will soon be "too small to enjoy".
Keep up the good work. An advice is some thing you can take up, but only if you agree with it.
Olafur
