jdk
Rejection Photos Not Mine
Sun Aug 07, 2005 6:20 am
Hi all
Looking through my rejection list and to my surprise there is other photographers rejection photos there just the jpegs though with my description and reject reason.Anyone else experiencing this?
I could give the examples but i dont want to offend as they are rejections
cheers
jk
dk
tfsphoto
RE: Rejection Photos Not Mine
Sun Aug 07, 2005 6:27 am
Hi there,
If another photographer also has a "newer" rejection, of the same file name..
Example:
I upload IMG_0001.jpg and it gets rejected and goes into the "rejection" directory on a.net, and another photography later uploads the same, IMG_0001.jpg the image will be different, but if that is then rejected, it automatically goes into the place which had your filename. Your info will stay the same, because thats what you "wrote" on your "profile" when you uploaded..
I have a few myself in my rejection list.
Hope this helps,
Lew
Psych
Sun Aug 07, 2005 6:29 am
I saw this in my early days before I started using a bit more complicated upload ID's for my photos.
With hindsight, I think the issue was that I used to simply use the plane's registration as the filename for my upload and, if anyone else had the same ID for their file, they may get confused. Something like that anyway.
Would I be right in thinking that you label the files just with the registration? I now use the registration plus my initials and the date of the photo to try to minimise any problems with duplicate file names.
Paul
jdk
Sun Aug 07, 2005 6:40 am
Not the reg but the airline eg continental,continental2 or cont but one i have is big/2.jpeg and its bahrain airlines 747
jk
dk
tfsphoto
Sun Aug 07, 2005 6:51 am
Yep, someone has uploaded a photo with the same file name, and that has been rejected too.... so it pushes yours "out" the system and replaces it with the newer "rejection" image... which had the same filename when uploaded... eg continental2.jpg.
Lew
paulinbna
Sun Aug 07, 2005 10:09 am
I found this out when one time I had a rejected picture and I thought I had fixed it and it was rejected again and both rejections where the same picture.
 confused
Oh and I use this easy naming of file names. Reg_file name.
Examply
N123AA_1234
then if I get a reject, I just add _1 to the end.
Canon 50D user; 100-400 MM L IS 10-22 MM, 60MM Macro
rampkontroler
Mon Aug 08, 2005 2:27 am
I use a similar system, but slightly different. I have never had a file rejected for the same file name. A typical photo would be:
Registration_type_Location_photo number_Date. ie:
N12345_752_KCLE_1_07Aug05
Then I know at a glance what it is, when and where it was taken.
If I have more than one shot of the same plane on the same day, I simply change the "1" to a "2" and so on.
cboyes
Mon Aug 08, 2005 9:32 pm
It is quite a good idea to incorporate your user name into the file name. Then as long as no one else perversly uses your user name in their uploads (why would they?) you wont experience this problem.
CB
Paulianer
Mon Aug 08, 2005 9:53 pm
I use this kind of file name:
Registration_Airportcode_Date_Photographer Initials_Camera filenumber_1 etc.
Tobi
Tobias Rose - Hamburg (HAM/EDDH) & (XFW/EDHI) - Canon EOS D60 - ICQ: 235621277 - MSN: Tobias.Rose@gmx.de
