Rotate
Bad Center Reject - Pls Help
Wed Aug 10, 2005 12:33 am
got this one rejected for badcenter. do I have to crop less on the left side?
http://www.airliners.net/procphotos/...ain?filename=F-GSTD-XFW-051105.jpg
thx vm for your help
Robin
ABC
fergulmcc
RE: Bad Center Reject - Pls Help
Wed Aug 10, 2005 12:37 am
Quoting Rotate (Thread starter):
Yes you have it, That is what I woluld have done as it's nice and tight on the right but you have too much space on the left. Or just move the a/c to the left so that there is the equal amount on both sides but keep it tight.
Take care
Fergul Big grin  sun
Zambian Airways, Where the Eagles fly free!!
Rotate
Wed Aug 10, 2005 12:42 am
ciao fergul,
Quoting Fergulmcc (Reply 1):
I asked, if I have to crop LESS on the left side  Smile if I crop MORE on the left side the plane (ex wing) is even more on the left side .... , do you get what I mean?
Robin
ABC
Gary2880
Wed Aug 10, 2005 12:47 am
nice photo, seams like you were really close!
myyy god its ugly...
Patriotism is the last refuge of the scoundrel :- Samuel Johnson
aitek
Wed Aug 10, 2005 12:49 am
yeah you gotta have the same amount of space on either side for it to be centered correctly in a.net standards, i have the same problem, i like to crop a little less in the direction the plane is flying because it gives the perspective of actual flight or speed, in any photography class they would prolly tell you to do the same, but not here.
fergulmcc
Hi Robin
Sorry I didn't m ake myself very clear but I do see your point. There is too much dead space in front of the nose. It's not contributing to the photo in any way. Therefore I would crop tighter to the nose and a little bit away from the wing tip on the right, as you are very tight there. If you do that the plane, whole plane that is, would be more centered.
Hope that helps
Take care
Fergul  {Sun}
Edit:
Quoting Aitek (Reply 4):
Bang on Chris, that is waht I learned too but as you said A.net doesn't want that.
[Edited 2005-08-09 17:51:54]
Rotate
Wed Aug 10, 2005 12:55 am
Quoting Fergulmcc (Reply 5):
okidok seems okay, if I just let a little more space on the right ... , as I dont want to crop it that tight on the left.
Guys, thx vm for your help ....  Smile
Robin
ABC
