johndm1957
Baffled By Badcatagory...........
Thu Aug 11, 2005 12:46 am
Looking for some help here guys,
I took some shots at the USS Midway Museum, and had the first few accepted. Example here..
Click Here
to view the photo
Now had three rejections for Badinfobadcatagory using the same catagorys, ie Private, Preserved
here,
http://www.airliners.net/addphotos/rejections/big/IMG_jm768211.jpg
http://www.airliners.net/addphotos/rejections/big/IMG_jm765111.jpg
http://www.airliners.net/addphotos/rejections/big/IMG_jm769711.jpg
I'm guessing they might have been rejected for not being 'Military'?, but they are now privately owned.
Any ideas?
[Edited 2005-08-10 17:48:37]
Canon 550D, 18-55, 50 1.8, 100-400L
jfktowerfan
Crew
RE: Baffled By Badcatagory...........
Thu Aug 11, 2005 1:12 am
I would be willing to say it was the military category. The first one you used military but not the others. But if the are privately owned as you say then PRIVATE.PRESERVED would be correct. Could you provide the details on the aircraft so it could be researched to give you a better answer?
Corey
C'mon Man
LeanOfPeak
Thu Aug 11, 2005 1:48 am
The only way an aircraft in military colors is anything other than MILITARY is if it bears a civil registration, and then it is a WARBIRD, rather than PRIVATE.
There are, of course, exceptions, but it is not uncommon for museum aircraft to bear solely the military registration. In such a case, the category for a preserved aircraft is MILITARY,PRESERVED, and the Registration is the military one.
If a preserved aircraft is in military colors but bears a civil registration, it is WARBIRD,PRESERVED, the Registration is the civil one, and the military registration is placed in the code field (if it is present on the aircraft) or in the remarks field (if it is not present on the aircraft).
johndm1957
Thu Aug 11, 2005 2:02 am
JFKTOWERFAN
The museum site here.. http://www.midway.org/site/pp.asp?c=coIMKTMCF&b=81432
There are already pictures of some of the exibits in the DB.
LeanOfPeak
I disagree. Military applies to a current flying Military example.
Warbird applies to a flying private or civil aircraft with Military markings but civil registered.
A restored non flying Military jet owned by a Museum not the Military is Private
regards
clickhappy
Thu Aug 11, 2005 2:22 am
This thread does a good job of summing up the attitudes around here lately.
You have a photographer, Johndm1957, telling two Airliners.net database editors, JFKTOWERFAN and LeanOfPeak, that they are wrong, and that he has it right.
There might be some inconsitency in some of the database entries (hence why we pay attention to this stuff and reject things as badinfo) but I am guessing that the two db editors know more about what is going on with regards to categories and how to correctly upload a photo here.
johndm1957
Thu Aug 11, 2005 3:47 am
Clickhappy
I'm not telling anyone anything, am I not allowed to disagree?
No big deal really, should I pull my queued pictures from the museum and resubmit with 'military'?
I have read the upload readmes again, and the 'Military' clearly says an aircraft owned by the military. If privately owned in military colours choose 'Warbird' instead.
Warbird states 'flying' example which it is not, which leaves 'private'.
Guideance appreciated
regards
jfktowerfan
Crew
Thu Aug 11, 2005 4:27 am
Quoting JFKTOWERFAN (Reply 1):
If you would do this we could help you. The link you provided does not give me the reg info on your aircraft.
Corey
C'mon Man
johndm1957
Thu Aug 11, 2005 4:37 am
Hi Corey,
is Reg: 153880, Cn: 2466, McDonnell Douglas F-4 Phantom II
is Reg: 158978, Cn: 39, Grumman F-14 Tomcat
is Reg: 153030, Cn: 1557, McDonnell Douglas F-4 Phantom II
John
[Edited 2005-08-10 21:44:07]
[Edited 2005-08-10 21:47:13]
jfktowerfan
Crew
Thu Aug 11, 2005 5:12 am
Ok heres what I come up with:
153880:
Generic: McDonnell F-4 Phantom II
Version: McDonnell F-4S Phantom II
USA - Navy
Category: MILITARY,PRESERVED
158978:
Generic: Grumman F-14 Tomcat
Version: Grumman F-14A Tomcat
USA - Navy
153030:
Version: McDonnell F-4N Phantom II
USA - Navy
Corey
C'mon Man
TZ
Thu Aug 11, 2005 5:17 am
The upload help text could be better, and we're discussing how to improve that for those categories.
In the meantime, as has already been stated, the airliners.net definitions are as follows:
MILITARY: Aircraft (genuine ex-military examples) in full military markings, which are NOT currently on the civil register. Examples include aircraft flown by a military air force, aircraft retired from military service as a gate-guard, (non-flying) aircraft in museums, etc. Some times the aircraft will have been flown in civil hands, on the civil register after it retired from the military. However if it later gets taken off the register and is preserved in non-flying condition, then it reverts back to MILITARY. Only if the aircraft actually carries visible civil markings should be be PRIVATE. All MILITARY should be listed with their respective air force name in the "Airline" field.
WARBIRD: Civil-owned airworthy aircraft in military markings, although not necessarily ex-military aircraft.
PRIVATE: No military-painted aircraft (active or inactive) should appear in this category.
Quoting Johndm1957 (Reply 5):
Yes please. You should also change all your "Airline" fields from "Untitled" to the correct air force (eg "USA - Navy"). From a quick check, it looks like the existing accepted entries are correct.
Tamsin
TZ Aviation - Aeropuerto de los Banditos Team Images
johndm1957
Thu Aug 11, 2005 5:52 am
Corey, LeanOfPeak and Tasmin,
Yes the upload help text is confusing!
Thanks to you all for your time spent in clarifying the catagories for me in such a prompt and courteous manner
Looks like I've got a busy evening now!
regards
John
Skymonster
Thu Aug 11, 2005 6:45 am
Quoting Tamsin (Reply 9):
OK, so [for example] the civil-operated fire bombing C-130s still in USAF colours are warbirds now then?  sarcastic
There are old pilots and there are bold pilots, but there are no old bold pilots
TZ
Thu Aug 11, 2005 7:08 am
Quoting Skymonster (Reply 11):
For the purposes of airlners.net, then quite probably. Our definition is simply military-painted aircraft flying in non-mlitary hands on the civil register. So yes, that means the Cessna 172 below is a "Warbird" in airliners.net terminology. Ours is NOT the classic definition of the term.
Photo © TZ Aviation
Do you have an image to illustrate your question? That would sure help.
Tamsin
Skymonster
Thu Aug 11, 2005 7:28 am
Quoting Tamsin (Reply 12):
Photo © Gerard Helmer
Whatever a.net's definition of the term warbird is, I think the fundamental problem is that contributors have a perception of what a warbird is, and Cessnas and Hercules don't usually fall within the common perception. The help text as it is doesn't really help, so the result is likely to be photographer frustration when a picture is rejected due badcategory. The ideal would be for there to be a little lattitude in applying the rules, or alternatively for the screeners to actually enter the word WARBIRD into the category list if it really had to be there - this latter action would take less time than rejecting and rescreening at a later date anyway.
A
Skymonster
Thu Aug 11, 2005 7:30 am
I guess that C-130 could actually be PRIVATE too, given its civil registration is visible?
Or given it is owned by a company, is it "Untitled" or "Untitled (Hawkins and Powers)"??? Or an untitled, private, warbird???  Wink
Not trying to bash anyone here, just seeking some logical clarification.
Andy
TZ
Thu Aug 11, 2005 7:38 am
Andy
Yes, looks like that's a WARBIRD to me, in the airliners.net definition, of course.
Quoting Skymonster (Reply 13):
I conceeded above that the help text is poor and needs to be better. Within minutes of this topic coming up here, the editors and screeners started working together to make that better. A great team makes a great website.
Disagree, the ideal would be a perfectly accurate database and no photographers ever getting badcategory rejections. That's what we strive for.
We're now moving away from the original poster's question, which regarded some preserved military aircraft and the need to put them into the MILITARY category. Nobody was quoting a "warbird" which got rejected for badcategory, but anyhow... I relentlessly amend categories at screening time, as I'm sure you did yourself Andy. If the uploader is a large-volume uploader, then I may reject with a little explanation to assist them, so things can be more aligned with airliners.net standards for future uploads.
Nobody but nobody but nobody should run away with the idea that we would EVER reject a rare shot for badcategory. We love aircraft and spend countless hours screening. We have a passion for the hobby and try to reflect that in accepting great shots. Our passion is not rejecting good images.
Tamsin
TZ
Thu Aug 11, 2005 7:43 am
Quoting Skymonster (Reply 14):
Is it in full military markings? Yes See my explanation above.
It's not military, we're agreed, Does it have any titles? No Then it's "Untitled".
Maybe I need to go to bed, but these issues don't seem to be as complicated as nuclear fusion?
At the end of the day, it's a database full of numerical rules. Wherever you draw the lines, they have got to be drawn somewhere. People in Key West don't complain that their postal address is not "Canada".
Tamsin
USAFHummer
Thu Aug 11, 2005 7:48 am
Quoting Tamsin (Reply 16):
Just to point out that the example cited by Andy in reply 13 does carry numerous military titles on the tail..."AFRES", "USAF" and a 5 digit # which I can't fully make out but almost certainly dealt with the aircraft's service in military life before it was civilianized, along with numerous emblems on the fuselage...IMO, its a very interesting aircraft for sure, never seen anything quite like it before!
Greg
[Edited 2005-08-11 00:52:56]
TZ
Thu Aug 11, 2005 8:01 am
Quoting USAFHummer (Reply 17):
Yes, I saw those. However, if it does not fit in the airliners.net MILITARY category (for active serving military aircraft or preserved non-flying aircraft) then it should be listed as "Untitled" and WARBIRD.
It would not make sense to list it as "USA - Air Force" if it's being flown by a civil operator. The same is true of all the traditional Spitfire warbirds in the UK.
On that point, I'm sure we certainly all do agree!
TZ
Invader
Thu Aug 11, 2005 8:10 am
Do not confuse "military colours" with "military markings". The colours are a paint scheme, the markings are military nationality markings like roundels or star-and-bar, or, for US Army aircraft, the text "United States Army". Aircraft with a civil registration which are painted in "military colours" but without "military markings", are, in general, never warbirds.
So this aircraft, which has military colours and a civil registration, is NOT a warbird, because it has NO military markings:
Photo © AirNikon
But these aircraft, which also have military colours and a civil registration, ARE warbirds, because they HAVE military markings.
Photo © Terry Shepherd
Photo © Snorre - VIP Vienna International Planespotters
However, aircraft which are ferried from a former military operator to a new civil operator with a civil registration but where they "forgot" to overpaint the military markings for the ferry flight, shall also NOT be listed as warbirds as there is no intention to continue flying in those markings as commemorative aircraft.
So, these two aircraft which have a civil registration and military markings (star-and-bar) are NOT warbirds, because they only flew like this on their ferry flights and are not actively flying as such. So these aircraft will not be listed as military nor as warbird.
Photo © Ralph M. Pettersen
When these two aircraft would however continue to fly with those military markings after their ferryflights, then they would have to be classified as warbird (like the C-123 above).
I hope you see the logic for all this?
Peter Vercruijsse
Chief Database Editor
johndm1957
Thu Aug 11, 2005 8:15 am
Its nice to see my point has been taken 'on board' by the team, excellent attitude.
Any small improvements to ease Photogs uploading will result in hopefully far fewer frustrating rejections.
As I said earlier, 'no big deal really', just a couple of hours re-submitting.
John
TomTurner
Thu Aug 11, 2005 11:30 am
It is rather confusing. At least when type and owner become confused on the upload page -
Airliners (apart from the BBJ I suppose) and helicopters are really not Biz Jets, which is sporadically enforced in screening.
Photo © Pedro Becken - Porto Spotter
Photo © Bill Shull
Also, searches pull up a good number of simultaneous Preserved *and* Warbirds..but as the original poster pointed out, I believe Warbirds are flying and Preserved are not.
Photo © TZ Aviation
Any clarification is good though..
LeanOfPeak
Thu Aug 11, 2005 12:30 pm
Corporate jets, regardless of whether they are of a type that would generally be considered bizjets or of a type that would generally be considered an airliner, go under BUSINESS. Propeller-driven aircraft never do.
HELICOPTER and BUSINESS are never coincident. I've fixed that one and I'm sure there are more that are wrong, but I can't deal with it right at this moment.
WARBIRD means an aircraft bearing military roundels or titles that is actively civilly registered. PRESERVED is a separate category, and warbirds can be in it or not, just as can aircraft in any other category. "Actively flying" should not be part of the WARBIRD helpfile as there are exceptions (Though in most cases, the civil registration of an aircraft intended for permanent static display will be allowed to lapse and painted over, there are exceptions to this and there are numerous aircraft which are part-time displayed in museum static displays and part-time maintained as flyable), and we're working on that now. Again, there likely are some errors here.
[Edited 2005-08-11 05:31:39]
TomTurner
Thu Aug 11, 2005 1:19 pm
Thank you for your response LeanOfPeak.
I cite the helicopters only because I learned after several years - via a rejection - that helicopters do not go in the Business section.
That section of the upload page refers to "Owner" rather than "type" - at least the heading anyway.. [later the help was amended to read - this includes just about any kind of "aircraft" to any kind of "business jet" - note here - "business jet" which implies the type...rather than "Corporate" ownership. If someone can sort it all out, and it does not cause an issue with how the database has already been organized, perhaps the Headings of the categories might be improved as well?
Of course, from a logic standpoint, I still don't understand the connection between Ownership and Type - and why they're being mixed here. Why for instance a fractional ownership Sikorsky S-76 would go under "private". These are essentially "corporate aircraft" in most cases, no different than a business jet.
The Warbird not only indicates flying (yes, it does indicate "actively flying" - but most warbirds are on a limited schedule). The Preserved section - in a different category further down indicates "non-flying". In my last post I only meant to reference airworthy vs non airworthy. But the difference between "actively flying" and "non flying" would seem to be clear.
Not trying to give you a hard time Lean -- its great that you guys are overhaulding things - and its understood you can't please everyone. From an uploader prospective though, The Bad Category can be a tough rejection
- so its all to the best when the help section is as good as it can be.  Smile Again - not bashing... Keep up the good work!
- Tom
