boeingfan71
I Need Help On How To Edit These Photos
Fri Aug 12, 2005 7:34 am
Ok all you photogrraphers i need your help i took these photos today and i just adjusted the size to 1600 by 1200 i need your help. i was wondering if i should leave them at this size or change the size. and if i need to touch it up and i have photoshop so i can do some on that program. but please reply and any tips are accepted the links are below. thanks drake.
http://www.airliners.net/addphotos/middle/ready/picturesaratog.jpg
http://www.airliners.net/addphotos/middle/ready/headon.jpg
JeffM
RE: I Need Help On How To Edit These Photos
Fri Aug 12, 2005 8:02 am
Sorry Drake,
Got lots of blownout areas on this monitor. Looks like they were taken at 12 noon? Or very close to it. Bad light to shoot from, very flat looking (no contrast) Re-sixe to 1024-XXX, 1600 is way to big for you, and the photos appear soft.
If you can, try to compose the image so you can see the full registration, in other words, get lower or higher, or change the angle.
-Jeff
AIHTOURS
Fri Aug 12, 2005 8:09 am
Drake,
They are too big (in this case), and re-sizing them to this size is not really that necessary as they need to be high quality to re-size them this big. (I think that is a factor anyway).
If you re-sized them to 1024 that would make them look a lot better. Your kind of making it harder than it needs be uploading them at this size.
Also, when you show us them, show the full size versions, as it is quite hard to make judgements on middle/ready Photos.
Make sure the Photos are big/ready in the link.   I changed the link anyway  Wink
I hope this helps. Sorry if I sound a bit harsh, I just don't like to see good Photos spoilt by something as simple as size.
Keep at it, you'll be on your way in no time!
Ryan  bigthumbsup
[Edited 2005-08-12 01:11:01]
Panasonic Lumix DMC-FZ5 User
boeingfan71
Fri Aug 12, 2005 8:15 am
hey AIHTOURS below is the link for large if this helps and everyone who responds thanks a lot from Drake F.
http://www.airliners.net/addphotos/big/readypicturesaratog.jpg
Thanks again,
Drake
boeingfan71
Fri Aug 12, 2005 8:33 am
NIKV69
Fri Aug 12, 2005 11:12 am
Yea the lighting is bad. Sorry Drake but you should discard those. Got to have that sun right behind you so your subject is lit up nicely. Also I would experiment with some different angles and get even more closer. I like being able to see the entire Regi.
Hey that guy with the private jet can bail us out! Why? HE CAN AFFORD IT!
boeingfan71
Sat Aug 13, 2005 1:33 am
thanks i'm going to another small airport today and i will expirement with the photos but thanks for all your help and i took it right at one' clock so the sun was bad but i will post more up here thanks for the help. Drake F.
