9v-svc
Reject Help!
Sat Aug 13, 2005 3:29 pm
Hi guys, I have a couple of shots rejected for bad quality. I would like to start from the original photo . How can I improve these shots ?
Charles
N808NW
DC10
Airliners is the wings of my life.
Psych
RE: Reject Help!
Sat Aug 13, 2005 4:38 pm
Hi Charles.
There are quality issues with both photos.
If you take a close look at the Airbus shot you can see what looks like jpeg compression - 'something' around the edge of the aircraft, particularly noticeable around the tail section and the titling. The red tail of the Airbus shows that 'compression-type' of appearance. I recall seeing a similar effect with the use of Neat Image - did you use this by any chance? There is a similar - though slightly less obvious - effect on the DC-10 photo.
Also both photos look like they could benefit from being a bit sharper. The DC-10 has some notable jaggies on top of the nose section, where it joins the fuselage, which I reckon you should be able to get rid of.
If you want a second attempt at an edit of the originals just let me know and I would be happy to help out.
All the best.
Paul
9v-svc
RE: Reject Help!
Sun Aug 14, 2005 2:49 am
Hi Paul
Thanks for your tips. I have re-worked on the photo . This is better ?
N808NW
Charles
Psych
RE: Reject Help!
Sun Aug 14, 2005 3:26 am
Hi Charles,
Not really, I am afraid. Some compression is still evident, particularly around the tail, and now there are some seriously noticeable jaggies on a lot of straight edges.
This won't get past the screeners as it stands.
The offer is still there for you if you want to get in touch.
Paul
9v-svc
RE: Reject Help!
Sun Aug 14, 2005 3:36 am
Hi Paul
I may need your help afterall , do you mind sending me pm of your email address so that I can send the original pic to you ?
Charles
Psych
RE: Reject Help!
Sun Aug 14, 2005 6:43 am
Charles,
Original received and the edit has been sent back to you.
Let me know what you think.
Paul
9v-svc
RE: Reject Help!
Sun Aug 14, 2005 10:12 am
Paul :
I saw your edited version, looks great. Thank you.
Charles
