beechcraft
Taking Pictures In Cockpits....
Wed Aug 24, 2005 8:28 pm
Hi all,
now, this one is a special questions for all the pilots and frequent jump seat users:
I´d like to hear your comments on two kinds of shots:
First, what are your preferences for nightime, inflight Cockpit shots?
Like: shutter speed, ISO, do you use a tripod, flash....
Second: How do you shoot through the cockpit glass?
How do you get rid of reflections,white balance, use of filters, etc...
Have you noticed any difference in glass quality on different aircraft types...?
My little CRJswindows actually suck and i´m having quite a hard time to get
good quality for any shot above 70mm... banghead
Please share your Thoughts,
TIA
Denis
That's it! You people have stood in my way long enough. I'm going to clown college!
Ander
RE: Taking Pictures In Cockpits....
Wed Aug 24, 2005 9:05 pm
Hi Denis,
I've tried both on night shots, high ISO and flash.
I believe the flash with a steady hand gives a better result.
I have a have a 580ex speedlite which I can point backwards and get the panels lit up by the bouncing light (direct flash is too strong). I wish I could take my tripod, but for now it is too heavy and bulky so I use the head rest on my seat or try to work out something else. I've heard Manfrotto have a "magic arm" which can be folded and think that should be a good idea.
Shooting at high ISO gives a more realistic view, but the shot always appears a bit grainy.
As for the cockpit windows..... WHAT A NIGHTMARE!!!!. Shooting good quality at 400mm is virtually impossible. You always need to reduce the focal length.
I wonder how Bailey does it....?:-l
Ander
Born to tri.
IL76
Wed Aug 24, 2005 9:11 pm
I had a jumpseat ride recently, my first one with a camera. Unfortunately I didn't have any practice time as you don't get to do this very often (or ever). The pilots kindly asked me not to use flash, so that ruled out any fill-flash.   So most my pictures were taken with 1/20s at ISO200 or 400 and you can imagine most coming out blurry/grainy. Pictures during taxi, takoff roll or turbulence were out of the question. And outside was almost always overexposed (obviously).
Screwing on the 100-400mm and shooting "Bailey/Tripiet"-like shots is bloody difficult. Not only do you have to be lucky to see any traffic at all, they also go very fast and if you're not in the captain's or FO's seat (=close to the window) the glass will prevent you to take any sharp shots. Autofocus is also not working properly... It's get confused all the time. So manual focus and very close to the window if you can.
Good luck.
Eduard
Edit: Denis, I only just realise you are a pilot... That should take away some of the barriers I described above. You can flash as much as you want! (unless you have an annoyed colleague)  Smile
[Edited 2005-08-24 14:18:30]
beechcraft
Wed Aug 24, 2005 9:18 pm
Ander,
interesting to hear that the A340s windows are bad as well...
You´re flying 340, right?
I just bought a Manfrotto 190PROB with Joystick Head and i´m pretty happy about it, but in a CRJ cockpit everything is bulky...
I´m wondering about Baileys (and other Photogs) shot, too,
I mean, i was absolutely shocked by this one from Ismael Jorda:
Photo © Ismael Jorda
That quality is absolutly amazing and impossible to reach for me.
Unless i am doing something wrong...
PS:
Do you have your settings for this one present?
Photo © Ander Aguirre
best regards, Denis
mario340
Wed Aug 24, 2005 9:50 pm
Hi Denis,
we all ("pilots and frequent jump seat users"  Smile) know that it is very difficult to take pictures inside the cockpit. Indeed, it's kind of tricky. If you don't have too much luggage with you take a tripod or at least a monopod with you.
For these shots I was using a monopod:
Photo © Mario Aurich
It can help you a lot and it's not as heavy as a tripod.
shutter speed: just try it. Sometimes it comes out well with 1/2, sometimes with 3 seconds during the night. For shots during the day it's not difficult. It really depends on the light conditions, the ISO and even on the color of the interior.
ISO: not more then 400.
flash: I never use a flash for cockpit shots.
For shots through the window there's just one thing you can do: take a lot of pictures and hope that one is good enough.  Wink
It is possible to get good results. This one I took with my 100-400.
Denis, I hope I will meet you in the next future finally. I'm the guy with the heavy camera bag and the tri-/monopod.  Wink See you at our FOC,
Mario
Lufthansa, there's no better way to fly.
Ander
Wed Aug 24, 2005 9:59 pm
Nice picture of BIO (my hometown) by Ismael.
Denis, the settings for that pic are:
ISO 400
F 4.0
1/4 sec exp.
exp comp -1/3
580ex flash (I can't find the settings for the flash
but I recall I set it to minimum output)
Handheld
Canon 17-85 lens
IS ON
Good luck.
Ander
Born to tri.
beechcraft
Wed Aug 24, 2005 10:47 pm
Quoting Mario340 (Reply 4):
Well, Mario, so am i....
Yeah, hope to meet you sometime... We should work something out.
BTW: Do you carry your Tri/Monopod in your handluggage?
I used to carry a small one with me, until i had some very annoying situations at the security check in STR...An on duty First Officer apparently can´t be trusted....
Denis
[Edited 2005-08-24 15:47:58]
ASalo
Thu Aug 25, 2005 4:42 am
I'm really not a big fan of using flash when it comes to cockpit photos. Why?
- When shooting in-flight, it can disturb the pilots.
- Unless you bounce it off the ceiling (which isn't possible if you don't have an external flash), it can cause those annoying reflections off panels/screens.
- In a glass cockpit, unless you use a slow shutter speed, the screens will end up dark or totally black. To me, a cockpit photo with blackened screens is kind of like a sideshot with the plane's nose cut off.
- Even if reflections and black screens are avoided, flash can sometimes spoil the whole feeling of a cockpit photo. Mainly when shooting at dark. An airliner cockpit at dark is simply one of the most beautiful environments I know of, and in my opinion it just needs to be shot in ambient light.
So I'm not really scared of lifting the ISO number if needed. If possible, a monopod or tripod is really helpful. Sometimes you'll just have trouble with getting one of those past security.
And I'm not totally against using flash. In some cases, for example if you want to get something relevant outside the aircraft exposed, flash can work just fine. For example:
Photo © Serge Bailleul - AirTeamImages
Antti
P.S.
Mario, that N.Y. Apporach shot of yours is just fabulous. One of my favourite cockpit photos on this site!
gmidy
Thu Aug 25, 2005 2:47 pm
Could someone tell me how-to get a jumpseat ride then i'll tell you how to do it. :p
Lawrence
mario340
Thu Aug 25, 2005 11:35 pm
@ Denis
Quoting Beechcraft (Reply 6):
I have a special tripod bag. No problems with it abroad. Just one day I had to go through passenger security check in MUC. I was wearing my uniform. The Lady there told me that the tripod is not allowed as hand luggage. I have to check it in. I said it doesn't make any sense because I wanna use it during the flight. I told her that there are a lot of things in an aircraft which looks more dangerous then my tripod. And I know where they are located.  Wink
Well, I had my tripod with me during this flight.  Smile
@ Antti
Thank you very much for the kind words.  Smile
N178UA
Fri Aug 26, 2005 8:54 am
Hi Denis
Get a SB800 (i think thats the model of the latest fill flash from nikon, the most powerful one too!). It is auto and very easy to use. I never read the menus. You get perfectly exposed inside and outside pic.
I didn't have a fill flash on a recent trip onboard a L1011 jumpseat, try to meter the "semi" area, near the window between light and dark, you may get a good reading can compensate both of the light outside and dark inside area...I've learned this from Peter Fagerstorm FAP. You may want to email him as he is an expert. (he use fill flash). Also not to forget using the highlight/shadow tool in CS when editing. It will bring a lot of details back!
Sam
beechcraft
Fri Aug 26, 2005 5:35 pm
Mario,
I was checked at the Crew Security "Container" in STR (maybe you know it).
I had a 45 min discussion with the guys there resulting in nothing but BS...
Anyway, you can read about it here:
http://www.airliners.net/discussions...ation_photography/read.main/160411
Back to Topic:
Thanks for the input so far:
Sam, i have the SB 600 from Nikon, it´s not quite as powerful, but i should work for the cockpit.
Also i´m able to control it wireless, which is a pretty nice feature and i will try it out one my next night flights.
I´ll tell the Cpt. to wear his sunglasses.... Smile
I´m pretty sure, however, that i won´t be able to get a sharp picture at 1/4s handheld without a tripod or IS/VR, so i guess i will try to set up my tripod in our small cockpit...
let´s see how that works.
On the shooting through cockpit windows issue, do you think a polarized filter would help to get better results?
I´m thinking that a lot of the distortion i get, comes from the multiple layer window glass itself. On some aircraft you can see the Approach lighting system almost twice! I gues i´ll just take that filter from a friend and play around with it as well, next time...
BTW, this the reflection, i´m talking about:
http://www.leveloff.de/franight.JPG
i think there is some "normal" lens reflection in it as well, but the double Runway light e.g. can be seen without a camera...
regards,
Denis
dcrusafon
Sat Aug 27, 2005 4:39 am
Hello Denis,
I sometimes have some jumpseat ride and I really love the night shots...I use to use a Manfrotto Magic Arm from another a.net member  Wink and the results are really good!
Photo © Dario Crusafon - Iberian Spotters
In these shot, I use to use a higher ISO (around 1250) and try to have the aperture around F8 so you don't get the overhead panel blurry.
From the cockpit glass, I have no idea...I remember last december I got a christmas gift  Wink A Disney Air Europa plane....I think I shot him 50 times...and the "trick" was to have the lense perpendicular to the cockpit glass.
For day shots, I have no idea as I still don't understand how to use the flash Big grin
ABout the tripood in STR, I also had the same problem with the security: I had to check it!!!! I remember I told you that a few monthes ago (DEC04)
Good luck  Smile
DARIO
beechcraft
Sat Aug 27, 2005 5:52 am
Dario,
Quoting Dcrusafon (Reply 12):
This might be a stupid question, but how exactly do you use the magic arm, what is it´s advantage? Isn´t it just a differnet kind of tripod head?
Is it better for stabilizing?
Thanks for clarification,
Denis
ake0404ar
Sat Aug 27, 2005 6:04 am
Denis,
the reflection you are talking about it is more than normal. Colin K. Work had a very good and detailed explanation for it. Maybe you'll find it somewhere. It should be under archieved threads.
I am no expert in jump seat or night shots, but I do have a very steady hand......
Back in the old days, I was able to get shots like these even without a digital camera shot at ISO 100. It sure is not the same quality as a Canon at ISO 1600 but for the time it was good enough for me. Handheld with a 17-35mm lens and Nikon F100.
Photo © Vasco Garcia
Mario, those flight deck shots of yours are getting better and better. Seems that your are getting the hang of it. The other shots displayed are very nice as well.
I normally shot A prio and sometimes even full manual to play around with the exposure.
Denis you have to look at it like this:
By the time you have turned 40 you probably have mastered shooting inside the cockpit and thru the windows. Trial and error.............................
Vasco G.
dcrusafon
Sat Aug 27, 2005 7:36 am
Denis,
You can hold the camera in any place in the cockpit...In the back of your seat, next to the jumpseat...
Here is a link to one page with a pic from the magic arm http://www.foto-mueller.at/shop/pd1523335406.html?categoryId=88
Send me an email using the interface and I will so you a pic with the magic arm installed  Wink
Bgrds,
DARIO
beechcraft
Tue Aug 30, 2005 5:26 pm
Thank you guys for all the comments,
i´ll keep them in mind and will try get some good shots.
Quoting AKE0404AR (Reply 14):
...great Vasco, only 14 more years to go... Smile
...and with with my current rejection rate i´m beginning to think that the trial and error method was especially invented for me! Nevertheless, i´ll stick to it.
Oh, by the way, i´m thinking about buying that 12-24mm Nikkor lens, any thoughts on that?
best regards,
Denis
ChrisH
Tue Aug 30, 2005 6:35 pm
Quoting Beechcraft (Reply 16):
Go for it! Lovely lens.
what seems to be the officer, problem?
javibi
Wed Aug 31, 2005 9:44 pm
Quoting Beechcraft (Reply 11):
I�m pretty sure, however, that i won�t be able to get a sharp picture at 1/4s handheld without a tripod or IS/VR
I do have a steady hand but I also shoot a burst of frames to give myself more chances, I am surprised nobody mentioned this "trick"...
j
beechcraft
Thu Sep 01, 2005 5:31 pm
Javier,
that is the trick, i am using as well, most of the time. however the best results i came up with (shooting approaches at night) are these two:
i know they are far away from being perfect, anyway: what do you think?
i took this one during an overhead crossing of FRA, moving to the left, which didn´t make things easier...
http://www.airliners.net/addphotos/big/ready/franight1denis.jpg
This is an approach into AMS RWY 06 at night
http://www.airliners.net/addphotos/big/ready/ams06denis2.jpg
ChrisH
Thu Sep 01, 2005 5:38 pm
I'm loving that AMS approach shot!
javibi
Thu Sep 01, 2005 5:42 pm
Quoting Beechcraft (Reply 19):
what do you think?
You are trying to accomplish the (almost) impossible!!  Smile
FRA looks too dark and too blurry, sorry! AMS on the other hand is pretty sharp, I like the composition, I think it stands a good chance (but do not forget I am no screener), it looks awesome IMHO!!
And BTW, when I mentioned a burst of frames I was referring to inside cockpit shots  Wink
j
beechcraft
Thu Sep 01, 2005 6:02 pm
Hm, yes you´re right about the FRA photo, but i just couldn´t resist...
I think you´re probably right to call it almost impossible, as we were moving 90* away from the airport, at something around 250 knots GS, it was a amazing view,though and i just tried it)
It´s waiting to be screened by Johan or the Head Screeners right now, let´s see how that turns out..(although i already can guess...)  brokenheart
However i´ll keep on trying these kind of shots during the wintertime.
Denis
beechcraft
Thu Sep 08, 2005 2:44 am
Wohoo!
The AMS photo made it! Thanks to the screeners!!
Self plug, watch out:
Photo © Denis Roschlau
Denis
IL76
Thu Sep 08, 2005 2:54 am
Denis...
That will be top of the day. Mark my words.  Smile
Eduard
fl350
Thu Sep 08, 2005 3:03 am
Congrats Denis superb shot  bigthumbsup
By the way can you share the info on the AMS shot (Iso, f/, 1/..., focal length) and did you use tripod or Magic arm?
Thanx
Fabrice
Fabrice Sanchez - Brussels Aviation Photography
beechcraft
Thu Sep 08, 2005 3:42 am
Thank you Eduard and Fabrice,
I´m not at home right now, Fabrice, but the shot was taken with my 70-200mm lens with f2.8 and a 1/15s, if i remember correctly. I didn´t use a tripod just my hands and that VR mode...
Denis
ChrisH
Thu Sep 08, 2005 3:48 am
Screeners did the right thing! Did you shoot from the jumpseat? Or were you at the controls and shooting at the same time? =)
INNflight
Thu Sep 08, 2005 4:57 am
Excellent photo Denis! Very sharp, congratulations!
Please keep these kind of shots coming! Just superb.
Jet Visuals
beechcraft
Sat Sep 10, 2005 5:59 pm
Chris,
This picture was taken from CM2 seat. I put a comment below the picture, that explains how...
regards,
Denis
