qfflyer
Which Lens?
Sun Sep 11, 2005 8:36 pm
I will be purchasing a Canon EOS 350D before I head o/s again. The offers Canon have here are either with a EF 75-300mm f/4-5.6 lens or a EF 55-200mm f/4.5-5.6 II USM lens. I would appreciate advise which lens would be the better one.
If I can finish my business early, I may be at LHR on the 25th Sept if anyones up for some spotting...
sulman
RE: Which Lens?
Sun Sep 11, 2005 9:24 pm
If that's your price bracket, go for the 75-300. Plenty of people use it here, and get good results.
If you save your pennies why not think about the 70-200 F4 L?
James
waketurbulence
RE: Which Lens?
Mon Sep 12, 2005 12:39 am
Even though the 75-300 is fairly soft at the long end, sometimes you need to be out at 300mm. I have the lens and almost all of my shots have been taken with it. I think you'll be able to use it in more situations than the 55-200. Ask yourself, how many times would you need to be down to 55 vs. 75, and out to 300 vs. 200. I think that question will help.
-Matt
DLKAPA
RE: Which Lens?
Mon Sep 12, 2005 12:46 am
Depending on how you shoot will your lens choice make. I've used the 75-300 no IS or USM in the past and have gotten fairly decent results with it, Canon's 70-200 f/4L is unbeatable in terms of quality and price. If it's the longer end you want, you might want to consider the Sigma 80-400 OS, 50-500 HSM, or Canon's 100-400L IS USM. The two sigmas run at USD 999.00, while Canon's 100-400 runs at around 1300 USD, all being superb lenses.
Basically at your early stage of DSLR ownership I'd say go with Canon's 75-300, and if you don't like it or want to upgrade, there's always E-bay.
Users browsing this forum: MarkusB and 1 guest
