B777Cptn
Where Is The Dirt On This Shot?
Tue Oct 18, 2005 8:46 am
G'day,
This shot of mine was recently rejected for NOA_dirty:
http://www.airliners.net/addphotos/rejections/big/25SEP05_VHOJE_BNE_IMG_3140.JPG
Ive played around with the contrast and brightness a bit to see if it will show up any dust spots or other dirt on the photo, but i cant find a thing.
Hoping a fresh set of eyes might be able to find something i couldnt.
timdegroot
RE: Where Is The Dirt On This Shot?
Tue Oct 18, 2005 8:49 am
About 10cm under the reg.
Tim
Alderman Exit
CallMeCapt
Tue Oct 18, 2005 1:33 pm
Looks like a cloning spot. I could be wrong though.
Sorry to say, but I can see it even without opening the reduced size photo.
If you want to see the spots in pre-post, equalise the photo and they'll pop up.
Goran
Without struggle, there is no progress. (Frederick Douglass)
mikephotos
Tue Oct 18, 2005 1:54 pm
This should help. Used "Equalize"
http://www.rampslides.com/equalize.jpg
Mike
dendrobatid
Tue Oct 18, 2005 3:11 pm
Quoting CallMeCapt (Reply 2):
Rather than equalising the whole image, I use the magic wand to select the sky and then equalise that. You can't usually miss them then.
Mick Bajcar
fergulmcc
Tue Oct 18, 2005 4:12 pm
Quoting B777Cptn (Thread starter):
I can see it without opening your photo. The best way, and there are many, is to simply equalize and it will show up like a sore thumb. My only problem is that you have to get out of equalize to clone them out, pity there wasn't an un-equalize button, it would make things a lot handier. The spot healing tool in CS2 works brilliantly, just set the size of the circle and click on the spot, no pre-settings invloved like the clone tool.
Take care
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
mygind66
Tue Oct 18, 2005 6:53 pm
Hi Brian...
What a pity because is a nice photo. Clean it and upload it again.
Try to shoot the sky with an aperture like f22 and you'll see all the dirt your camera has.
Enrique
timdegroot
Tue Oct 18, 2005 7:18 pm
Quoting Fergulmcc (Reply 5):
Just add a new equalized layer, and clone out the spots in the background layer.
Tim
Alderman Exit
Q330
Tue Oct 18, 2005 7:57 pm
One click in the history palette will do the trick.
-Q
Long live the A330!
fergulmcc
Tue Oct 18, 2005 9:00 pm
Quoting Q330 (Reply 8):
I'm aware of that method, thanks Tim and Q but what I was trying to say instead of doing that, going back and instead of creating a new layer.
Thanks anyway,
cheers
Fergul  sun
