flyfisher1976
Tried A New Crop With This One...opinions?
Tue Oct 18, 2005 10:21 am
Your opinions on this one please...
http://img421.imageshack.us/img421/6732/20051017img2188pvd0ju.jpg
This is my first time uploading with this type of crop. Any opinions are welcomed.
Will this one make it in the DB?
-JD
ua777222
RE: Tried A New Crop With This One...opinions?
Tue Oct 18, 2005 10:42 am
Photo © Danny Fritsche - Airplanespotters
Sorry for the plugs Danny, when I saw this shot I asked, TUL?
Though I think the undercarage there might be killed due to bad_dark...
My  twocents
Matt
"It wasn't raining when Noah built the ark."
F9Widebody
Tue Oct 18, 2005 11:43 am
Nice shot. But the bottom is too dark and the far wing is too sharp.
YES URLS in signature!!!
Q330
Tue Oct 18, 2005 12:01 pm
The crop is fine, it just needs a lot less contrast.
-Q
Long live the A330!
flyfisher1976
Wed Oct 19, 2005 4:56 am
Thanks for the input!
Consider this...
Quite a few of my shots came out like this, with the top of the aircraft well lit and the belly very (too) dark. I was rather disappointed because it was my first time out with my new 100-400L and 350D. Although the metering on the 350D IMO is much better than the 300D, I think my problem may have been time of day.
I purposefully went towards the end of the day because I figured that with the sun low in the sky it would light the entire side of the aircraft from the west (the A/c were landing South to North). However the result was what you see above on most of my photos (dark belly, bright top). The sun was bright and unobstructed.
1. Why did the bottom of the plane expose so dark and the top so vivid and bright when the sun was shining directly from the side?
2. Is this a known phenomenon?
I find that when there is snow on the ground the aircraft exposes perfectly on all sides because of the amount of reflected light from the ground.
Example:
Photo © Joseph A. Del Guidice
3. How do I achieve these results when I don't have that advantage (Summer/Fall)?
PS...I really don't want to start a metering woes thread here...just trying to get an explanation to the above question(s).
JD
[Edited 2005-10-18 21:57:10]
fergulmcc
Sat Oct 22, 2005 3:50 pm
Quoting Q330 (Reply 3):
Joseph
I agree with Q330, crop is fine but it is way too dark underneath, the saturation is a bit heavy too.
Take care
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
Jkw777
Sun Oct 23, 2005 2:09 am
Hey,
I had a quick fiddle with the contrast and saturation etc. I came to this:
http://www.justinwood.me.uk/anet/20051017img2188pvd0jujkw.jpg
Quoting Flyfisher1976 (Reply 4):
The equipment doesn't always make good photos. Spend a little bit more time in the post processing side of things.
Justin  Smile
jkw6210@btopenworld.com or +447751242989
spencer
Sun Oct 23, 2005 5:23 pm
Justin. Do you have CS2 mate? If so, then use the Shadow/highlight function. It's a Godsend!!!! Keep your values relatively low though, say below 20, to reduce the risk of noise/grain.
Spencer.
Jkw777
Sun Oct 23, 2005 5:26 pm
Quoting Spencer (Reply 7):
Spencer.
Spence,
Nope I don't! I'm still using PS7. I may have to source a copy of CS2 from someome!
Justin  Smile
spencer
Sun Oct 23, 2005 5:37 pm
Sorry Justin, I mistakenly addressed that to you when in fact it was meant for JD/Flyfisher1976! Oops!  blockhead
PS. I suppose that actually goes for anyone though. Shadow/highlight is an awesome tool.
Spencer.
Jkw777
Sun Oct 23, 2005 5:40 pm
Quoting Spencer (Reply 9):
Hehe, no worries mate!  laughing
Justin  Wink
flyfisher1976
Sun Oct 23, 2005 11:02 pm
Quoting Fergulmcc (Reply 5):
Thanks for the tip!
Quoting Jkw777 (Reply 6):
The equipment doesn't always make good photos.quote]
I don't believe I ever tried to blame the equipment:
[quote=Q330,reply=3]I think my problem may have been time of day.
I use Fergul's workflow for every photo that I process, so I'm not sure how much more time I'm supposed to spend. The problem with this photo could be corrected, I just needed some tips on how.
Awesome! Not sure what I did wrong here, but this looks so much better! Maybe you could clue me in, so I can apply this technique to the rest of my photos from that day. Thanks!
I'm going to remove the original from the queque and add the one that you "fiddled with" above.
Fiveholer
Sun Oct 23, 2005 11:40 pm
Quoting UA777222 (Reply 1):
Hahahaha! Thanks Matt. Those WN TUL shots need all the help they can get. Big grin
Danny
Bring back Bethune!
flyfisher1976
Mon Nov 07, 2005 12:15 pm
Justin,
Thanks for your assistance with the photo. The version you edited got accepted!
