nirmalmakadia
How Do The Pros Shoot?
Fri Oct 28, 2005 8:06 pm
Hi everybody...
I don't know if this thing is discussed here in past or not, but I would like to know how do most of you shoot? Auto Focus or Manual Focus.
Nirmal
fergulmcc
RE: How Do The Pros Shoot?
Fri Oct 28, 2005 8:25 pm
Quoting Nirmalmakadia (Thread starter):
I am no pro!!!! but I do hope to take it up professionaly in the next year or so. From what I have read the general consensus is that we use Av mode, Aperture priority. This also is the method that most of the serious photographers in my camera club use as well. For aviation most will use around the f8-f11 mark but portrait photography I use f11. Landscape up to f22 so the my foreground is in focus as well.
Hope that helps
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
linco22
Fri Oct 28, 2005 8:37 pm
Quoting Fergulmcc (Reply 1):
Hi Ferg,
That answers a few questions! I usually use Av though sometimes 'M'. And thats the range I use too. And i'm not even close to bein an amateur never mind a pro! Cheers mate. How are things at DUB? Anything interesting going on? I'm still meaning to get down. I dont know why I dont take advantage of it only bein 2 hours away!
Colin
fergulmcc
Fri Oct 28, 2005 8:55 pm
Quoting Linco22 (Reply 2):
Glad to help Colin, The club I am with is very good and helpfull, you learn so much from photographers who have won international awards for Ireland and they will do anything to help. Each photographer has his own speciality, be it, Landscape or children or still life. I have brought a bit of aviation photography to the club and my shot of the Spitfire at Weston which I converted to B&W came second in the monochrome section, 1 point behind the winner, which I have to admit deservedly won. But they all seem to use Av mode on their cameras. When doing close up, Macro the aperture goes up quite considerably as your DOF is very shallow so close but you need a very stong Tripod when doing that as well as for landscape photography.
DUB is still busy Colin, especially on a Saturday. I am away this weekend but will be free next weekend, 5th Nov. Give me shout when you want to come down but check the weather first and I will meet up with you no problem.
Take care
Fergul  sun
jhribar
Fri Oct 28, 2005 8:57 pm
I'm also not a pro but use followings settings on my DSLR:
I mainly shoot in "M" (manual) mode. For monitoring the exposure I always use the histogram. Furthermore I mainly use f/8 as aperture setting. For props I use higher apertures. For focusing I use the Auto-Focus, which for my Canon L lenses is very fast and very accurate.
If you can, you should try to shoot RAW to capture as much information as possible.
For the processing I use 16-Bit Adobe RGB which I convert to 8 bit sRGB when I finished the processing.
Hope this helps you a little.
Jeroen Hribar
AirTeamImages
viv
Fri Oct 28, 2005 9:04 pm
Mostly aperture priority, with autofocus.
(Self-plug) for shots like this.
http://www.airliners.net/open.file/922485/M/
But for the shot below I used shutter priority (I/80th), to get the prop-blur effect.
http://www.airliners.net/open.file/920161/M/
fergulmcc
Fri Oct 28, 2005 9:31 pm
Dam nice shots Viv!! Love that prop blur
A very quick way to change your settings for prop blur is simply set your Tv mode to 1/125 or less, then when in normal Av shooting mode and a prop plane comes along just trun the dial to Tv mode and you're set up for you props, learnt that from Mick Bajcar.
Fergul
Edit: Sometimes you have to mess around with the shutter speed to get your required blur affect, but the most common speed is around the 1/125
[Edited 2005-10-28 14:33:34]
viv
Fri Oct 28, 2005 9:40 pm
Thanks, Fergul.
Quoting Fergulmcc (Reply 6):
Yes, it all depends on the situation. Get out there and shoot, shoot, shoot. A t least with digital it costs less (than film).
fergulmcc
Fri Oct 28, 2005 9:48 pm
Quoting Viv (Reply 7):
Exactly you can have a very quick check to see if you have the required blur affect and then change as required.
Thanks, Fergul.
You're welcome, dam that prop blur affect is good. here is another good one Viv.
Photo © Janne Laukkonen - FAP
Fergul
[Edited 2005-10-28 14:49:04]
viv
Fri Oct 28, 2005 9:54 pm
Quoting Fergulmcc (Reply 8):
My God, that Electra is beautiful!
INNflight
Fri Oct 28, 2005 9:58 pm
In my understanding your question is wether people FOCUS manually or automatically? You aren't talking about camera modes, are you?
I use autofocus, and I guess that's what most of us do. Way faster and more accurate than manual.
Quoting Jhribar (Reply 4):
F.8 is generally a good stop to shoot at in terms of aviation photography.
Of course it all depends what effect you want to achive. Depth of field is something very important to consider when shooting, especially non-av.
It can make shots with cluttered background a lot more pleasing to look at. Not wanting to teach you photography basics here, if you want to get more information and learn, google it, or get a good photography book.
Jet Visuals
linco22
Fri Oct 28, 2005 10:06 pm
Quoting Fergulmcc (Reply 3):
I know i've been meaning to get done since the summer. I keep putting it off but I will make it down this side of xmas and now I have 4 wheels its much handier. I'll let you know when Fergul cheers.
Also on the camera side of things, I was at BHD last Saturday. I was shooting at f10/f11 as it was very sunny, mid morning. A few of my shots turned out a little dark. The camera had used a high shutter speed of around 1/1000/1250th. I brighten a few up with levels/curves and they've turned out pretty nice but how would a cure the darkness in the first place? Shot is linked below. Its in the que now
http://www.airliners.net/addphotos/b...y/airwalesatr42knnyatbhd221005.jpg
Colin
timdegroot
Fri Oct 28, 2005 10:27 pm
Quoting Linco22 (Reply 11):
Overexpose? Just an idea Wink
it needs cw rotation btw.
Tim
Alderman Exit
linco22
Fri Oct 28, 2005 10:31 pm
Quoting TimdeGroot (Reply 12):
Tim
Hi Tim,
Thanks for your input! mmm true, I never think of these things when i'm out there. But I would have thought that because it was sunny overexposing would make it worse. So you think I needs cw rotation? I did, 0.3. I used the tanks in the background and posts that i've cropped out. Guess thats not gonna make it then because I quite like it! Awk well
Colin
fergulmcc
Fri Oct 28, 2005 10:43 pm
On sunny day with a white a/c, you're kidding. When it's sunny Colin I always underexpose my shots. Just stop down one notch.
Thought it looked good to me, level and all. If you rotate it Tim the building will slope!
Take care
Fergul  sun
PS: Colin, I am away from the 16th Dec, so it will have to be sometime in Nov or very early Dec.
JeffM
Fri Oct 28, 2005 10:55 pm
For moving things, Auto-focus is much easir these days, as most consumer level dslrs have very poor focusing screens that make manual focus a pain.
For stationary subjects (non-av) often I will get my initial focus from the camera, then fine tune the focus manually with AF set to off. This allows consistent focus over numerous shots without having to worry about selecting a focus zone shift.
Ferg, none of your clubs members use an incident meter? How serious can they be? A simple Sekonic 358 of Minolta IV blow away the inacurate built in camera meters, though a good understanding of when to use them an when to keep it in the bag helps. What are they shooting that nobody uses one? It is an absolute "Must Have" for portraits, I can't imagine setting up a five light set without one, how do you do it?.
Nirmal,
Try to think of your camera and all it's bells and whistles as a tool box. You don't use a hammer for everything, or a screwdriver do you? Learn to use all the functions and settings of course, but learn the difference between them and when to use one over the other and you will be ahead of the game. From reading the above remarks, it seems many just use the same one over and over.
linco22
Fri Oct 28, 2005 11:11 pm
Quoting JeffM (Reply 15):
Stop getting technical Jeff........
fergulmcc
Fri Oct 28, 2005 11:13 pm
They do Jeff!! and they are very serious, award winners. I just didn't include it in my post as I thought I had given enough info. I will order myself one like you posted in that other thread that you were involved in a while back, thanks for that info.
We do the same Jeff, we spend more time in setting up than just taking a shot. Your camera, is what I have learnt, is the last thing you touch. We would set up our lighting using a meter to get our desired f11.
You have some very good points Jeff, Cheers.
Like I said I'm no pro.
Take care
Fergul  sun
viv
Fri Oct 28, 2005 11:19 pm
Me, Ahh jes' pernt the dang thang at the ol' airplane, an' hope for the best.
Mos'ly, ahh leaves the lens cap on.
'f Ahh had my druthers, Ahh'd use a hammer ...
[Edited 2005-10-28 16:25:27]
JeffM
Fri Oct 28, 2005 11:25 pm
Quoting Fergulmcc (Reply 17):
That is good to hear! Nothing like being around people that know what they are doing, or at least fake it well.  Wink I figured someone probably used one.
BINGO! Exactly right, Though I do like to chimp the display to make sure I've set the ratios correctly, but I do that less, and less the more I do it. I usually do it more on outdoor portraits then indoor as it is harder for me to control the light outdoors. But indoors I trust the meter and it has not been wrong yet.
Lately, I've been enjoying the setup portion more then anything else. When you nail the setup with multiple lights it can be very satisfying.
Me either, I think if I had to do photography for a living, it would just become work. I enjoy taking assignments and projects that I want, when I want for now, having to take or find one to ensure I eat the next day wouldn't be as enjoyable.
-Jeff
linco22
Fri Oct 28, 2005 11:37 pm
Hi Jeff,
I have to confess that 90% of my photography(since i've really got into it over the last 6 months) is aviation. I've only taught myself so much and most of the advice, in all of it, has come from people on here and other sites like dpreview and the like. I'm sure I come across an amateur but thats what I am. And i'm pretty sure that compared to the majority of people on here, my knowlegde of photography is very small!
* gonna crawl back into my box now......*
Colin
fergulmcc
Fri Oct 28, 2005 11:51 pm
Quoting JeffM (Reply 19):
Sure, but I simply love photography. I don't mind the weddings, in fact I quite like them, but once you have a name for yourself you can afford to be a bit choosy. I am moving to a new part of the country next Jan, well Tina's home town, of Enniscorthy, and there are very few photographers around there, so I hope to make a name for myself. I want to do this for a living. The house we have just bought has a double story garage which I intend to turn into a studio downstairs and then have all my computers and worktops upstairs. Hopefully I will get it working by next summer. I have no intention of using it for my car  just put a big window where the door is and let all that natural light in
It is Jeff, simply brilliant and they are so willing to help out too. We organize so many outings and each photographer has his own field. One photographer organizes a lot of trips to places like Iran, India, Cuba to name a few and he specializes in photographing people, there is a name for that type of photography but it escapes me now. Another organizes trips around the countries. You'd be bankrupt if you went on them all but they are there if you want to join. I'm gonna miss it when I move down the country, but I am in line to join another camera club there.
LOL, Me too!  Smile
Take care
Fergul
[Edited 2005-10-28 17:02:42]
nirmalmakadia
Sat Oct 29, 2005 12:04 am
Thanks Guys.....all of you where great help.....let the tips keep coming....
Nirmal
mikephotos
Sat Oct 29, 2005 1:05 am
Though I do like to chimp the display...
You're not a pro unless you master the fine art of chimping  Wink
Mike
