flyfisher1976
USM Is Going To Be The Death Of Me...
Fri Oct 28, 2005 11:01 pm
Well I have to thank Fergul for his great workflow. Since I have been using it my acceptance ratio has improved dramatically.
However, there is a problem...
USM! (or my monitor?)
Why is it that my monitor seems to display all images with jaggies before any USM has been applied? I have a very difficult time getting the sharpening just right because I am always starting off with something that already appears to be jagged. Is my monitor too low of a resolution for this type of work even though it was touted as being such high quality (and I paid so much $$)? Most of the time when applying USM I am really guessing at it.
Is my monitor set up wrong?
Is there anything I can do to remedy this?
Does anyone else have a problem with an lcd like this?
Any input or suggestions would be appreciated...I am really getting frustrated. I have a lot of shots that I would like to upload, but am really having a difficult time mastering the USM technique (using any method, including Ferguls')
Please help!
fergulmcc
RE: USM Is Going To Be The Death Of Me...
Fri Oct 28, 2005 11:21 pm
Joseph, can you link some of the originals so that we can have a look, along with some info, Type of camera and your settings.
Are you filling the frame with the a/c?
Fergul  sun
Zambian Airways, Where the Eagles fly free!!
viv
Fri Oct 28, 2005 11:24 pm
Are you using in-camera sharpening? It's generally not a good idea, because it can cause jaggies before you even start with USM...
flyfisher1976
Fri Oct 28, 2005 11:42 pm
Quoting Fergulmcc (Reply 1):
Sure...Here's one:
http://img425.imageshack.us/img425/7987/20051017img2169pvd0yw.jpg
INFO:
Camera ModeI Name
Canon EOS DIGITAL REBEL XT
Shooting Date/Time
10/18/2005 05:52:24
Tv(Shutter Speed)
1/320Sec.
Av(Aperture Value)
F9.0
Metering Modes
Evaluative metering
Exposure Compensation
-1/3
ISO Speed
100
Lens
100-400mm
FocaI Length
100.0 mm
Image size
3456 x 2304
Image Quality
RAW
FIash
Off
White Balance
Auto
AF mode
One-Shot AF
Parameters
Tone Curve : -
Sharpness leveI : -
Pattern Sharpness : -
Contrast : 1
Sharpness : 1
Color saturation : 1
Color tone : 0
Color matrix
Color Space
sRGB
Original converted to jpeg and resized to 1024X683. No other processing...
I see uneven lines on top of the right wing, small jaggies on the tail, and around the logo lettering (on my screen).
sulman
Fri Oct 28, 2005 11:58 pm
Joseph,
For starters, the image is a bit blurred, so USM will only aggravate the quality issues.
As for jaggies, there will always be some, unfortunately. In resizing down (and resampling the image) some aliasing of the pixels will occur at edges, giving the 'stepped' look.
Nothing you can do, and some images are worse than others.
James
MarkJBeckwith
Fri Oct 28, 2005 11:59 pm
Looks kind of soft on my screen - I don't see too much in the way of jaggies in this image.
Mark.
One day, I might be good at this...
fergulmcc
Sat Oct 29, 2005 12:00 am
I don't see any on the tail, except the US logo stripes. The cheat lines you will always get them there. The right wing yes I see a few but again they are small and would be normal for that setup and camera. Not saying that mine is any better, I still get them with my 20D. Jaggies are part and parcel of digital you will never get rid of them and yours are quite normal, well, I mean they are not that bad.
Fergul  sun
YANQUI67
Sat Oct 29, 2005 12:07 am
I noticed your shutter speed is 1/320 that is too low to capture a sharp picture of a fast moving jet. Bump up the speed to at least 1/800 and watch the pictures get sharp. The saturation looks a little high also. I dont think that your monitor is bad. I think you are trying to oversharpen an image that is already too soft to begin with. Hope that helps.
Kukkudrill
Sat Oct 29, 2005 12:34 am
Flyfisher what sort of monitor have you got? Sounds almost like it's too sharp not the other way round.
Make the most of the available light ... a lesson of photography that applies to life
LGW
Sat Oct 29, 2005 3:32 am
Hi all,
"I noticed your shutter speed is 1/320 that is too low to capture a sharp picture of a fast moving jet. Bump up the speed to at least 1/800 and watch the pictures get sharp. The saturation looks a little high also "
Sorry, I can't agree with those statements. I, and I am sure many others have got good sharp images at much lower than 1/320!
Secondly the saturation looks great, always nice to see well saturated and vivid colours as opposed to washed out, pale colours although saturation is competely a personal view point
Ben Pritchard
dc10tim
Sat Oct 29, 2005 4:55 am
The only place I see jaggies on that image is on the small white line towards the bottom of the fuselage, underneath the rear door. That is most likely as a result of the downsizing and I've certainly seen worse. One way I have found to partially get around the problem is to upload at 1200x800, which doesn't produce the effect to the same extent on resizing.
Tim.
Obviously missing something....
flyfisher1976
Sat Oct 29, 2005 6:59 am
Quoting LGW (Reply 9):
Thank you! I was about to say that...you beat me to it.  Smile
Quoting Sulman (Reply 4):
Is it? Keep in mind that no post-processing has been applied.
Quoting Yanqui67 (Reply 7):
I don't see how the saturation could be "off". No adjustments have been made to the image.
So how do I distinguish between slightly oversharpened (rejection) and "just right" (accepted)?
If anyone would like to have a go at the image and give me one example of each, be my guest!
Thanks all!
-JD
