B742
How Do I Edit This Photo?
Sun Oct 30, 2005 11:05 pm
I have many photo's, I have only tried a couple of times entering them to a.net, but all have been rejected!
I think they are good shots, but need the editing, which I'm a amateur at, please can someone give me some helps and tips?
Anyway here's the photo, non-edited:
http://i5.photobucket.com/albums/y167/Rob_canada/IMG_1761.jpg
Any help would be great, after all you lot are the experts
I also have Adobe Photoshop btw!
Rob!
[Edited 2005-10-30 15:14:44]
As smooth as silk
tfsphoto
RE: How Do I Edit This Photo?
Sun Oct 30, 2005 11:16 pm
Hi Rob,
You will need to post the full size version, such as 1024 wide e.t.c. Then we can have alook at it and see its true quality.
Hope this helps,
Lew
B742
Sun Oct 30, 2005 11:30 pm
Sorry, I thought photobucket would keep it as 1024 wide!
Here it is again:
http://robcanada.myphotoalbum.com/vi...&set_albumName=album02&id=IMG_1761
Could you also have a look at this one:
http://robcanada.myphotoalbum.com/vi...&set_albumName=album02&id=IMG_1759
Sad to hear your giving up photography btw!  Smile
Rob!  wave
As smooth as silk
norfolkjohn
Mon Oct 31, 2005 1:16 am
Rob,
On the 747 shot the main problem I see is that it is very soft - needs application of Unsharp Mask. Also the aircraft is not well centered in the frame - it is too low. Depending on the original shot you may be able to fix this with a better crop. There are several dust spots visible (although fairly faint). These can be seen clearly if you equalize the shot. The highlight on the front fuselage is perhaps a bit distracting but I think it would not be a major problem.
The A330 shot is sharper but could still do with a touch more USM in my opinion. However this shot is rather dark and needs adjustment to brightness and contrast. If you are using Photoshop this can be done very simply with a levels adjustment. You also need to crop in a lot closer around the aircraft as there is presently too much sky in the shot all round. This should not be a problem provided the original is big enough and of high enough resolution. Again there are several dust spots one of which is very obvious even without equalizing the shot.
I think both shots have potential provided the original files are of good enough resolution.
I would strongly recommend you look at Fergul's workflow which is linked from the photo upload page and I also, personally, like this one as well :
http://www.btinternet.com/~victoryhall/workflow/
Hope this is of some help.
All the best & good luck.
John
One thorn of experience is worth a whole wilderness of warning.
Users browsing this forum: hkg82 and 1 guest
