phatalbert
Advice On Photo Of A Boeing D75N1
Fri Nov 04, 2005 9:10 am
http://img78.imageshack.us/img78/5852/nov22005b9qc.jpg
I took plenty pics of this aircraft but this right here is what i have edited.. im just a "youngin" and i need advice/comments on what might need to be done for an acceptance thanks
*Isaac*
**Isaac**
JeffM
RE: Advice On Photo Of A Boeing D75N1
Fri Nov 04, 2005 9:38 am
Quoting PhatAlbert (Thread starter):
It won't get accepted at that ration (H x W) no matter how nice it is.
It is grainy and soft in a few areas as well.
Pretty plane though.
phatalbert
Fri Nov 04, 2005 9:43 am
Quoting JeffM (Reply 1):
what you mean? can yah give me a example or anything?
**Isaac**
JeffM
Fri Nov 04, 2005 10:22 am
Quoting PhatAlbert (Reply 2):
Sure. The sky is grainy, and the aircraft appears soft, and has halos in multiple areas. Look closely.
Change the aspect.
F9Widebody
Fri Nov 04, 2005 10:46 am
Quoting JeffM (Reply 3):
Just to translate from JeffM to english, in case you aren't familiar, a halo is characteristic of oversharpening, and is a "halo" that will be visible around the fuselage. In this case below the wing and around the supports on the far right.
YES URLS in signature!!!
DLKAPA
Fri Nov 04, 2005 4:36 pm
Quoting F9Widebody (Reply 4):
In laymans terms, it means there's a white outline around the plane.
GPHOTO
Fri Nov 04, 2005 4:47 pm
The horizon is also not level, note especially how the left horizon curves up towards the edge of the photo. If you are shooting close up (i.e. wide angle), you may not be able to make the horizon level (it is called barrel distortion), but then you should try to make the amount of upward bending the same at the left and right edges. This should mean that the horizon in the centre of the picture is straight. Bendy edges are allowed here as long as the centre of the photo is level.
Jim
Erm, is this thing on?
