vasanthd
Pre-Screen Needed
Tue Nov 15, 2005 6:55 am
Hello all,
This picture of mine is getting near to be screened...Any thoughts whether to pull or retain it from the queue?
http://www.airliners.net/addphotos/big/ready/aa_n941an_110605_DFW_1.jpg
--Vas
One Lucky shot deserves another!
Ander
RE: Pre-Screen Needed
Tue Nov 15, 2005 7:07 am
Personaly, I would downsize to 1024 x ....
Other than that, the photo looks pretty good.
Born to tri.
Granite
Tue Nov 15, 2005 7:09 am
Quite nice but could be a little more centred and sharpened.
Gary
jay767
Tue Nov 15, 2005 8:10 am
I would resize it down,it looks a bit blurry to me,just my  twocents
glennstewart
Tue Nov 15, 2005 8:24 am
At work with a crappy LCD screen instead of my screening beast at home... but I concur with Gary...
* Centre: The centre should be around the aircraft as a whole. A lot of people make the mistake of centering the fuselage, but depending upon angle the shot is taken and the type, this can cause the whole shot to be un-centered. In the case of this shot, you probably want to bring the aircraft down just a little...
* Sharpness: Should be pin-sharp without going to the point of creating jaggies. This is especially true for Digital SLR's, which often require slightly more sharpening that non DSLR's by default (later model DSLR's are more often being configured with slightly higher internal sharpening settings - e.g. 10D vs 20D)
Everything else looks fine... especially the colour.
Respected users.... If my replies are useful, then by all means...
DLX737200
Tue Nov 15, 2005 8:59 am
Is it me or this shot unlevel? It looks like it may need some CCW rotation. Not much, just a little. Notice how all the towers in the background seem to be leaning to the right. Just my 2 cents
-Justin
vasanthd
Tue Nov 15, 2005 11:08 am
I am taking it down...thanks for your advices...will post after a rework...
--Vas
vasanthd
Tue Nov 15, 2005 1:26 pm
Hows this one guys?
Fixed Center, Angle, Sharpness and Size...
http://www.airliners.net/addphotos/big/ready/aa_n941an_110605_DFW_2.jpg
The old one was ...
http://www.vasanthdharmarajan.com/airliners/aa_n941an_110605_DFW_1.jpg
--Vas
Psych
Tue Nov 15, 2005 3:58 pm
Hi Vas.
For me the key here is still the centering. I am in full agreement with Glenn that the whole aircraft should be centered for it to look right. In this case that means that there will be roughly the same amount of space above the top of the tail as there will be below the nosewheel. At present - even in the new version - there is still a lot of 'dead' taxiway beneath the plane that is not balanced by sky above the tail.
In your position I would be anxious about a rejection for this here.
Cheers.
Paul
vasanthd
Wed Nov 23, 2005 7:42 am
Accepted after a looong wait.......
Thanks everyone...
Photo © Vasanth Dharmarajan
