ThierryD
Crew
Here We Go Again...
Sun Jan 08, 2006 4:09 am
Ok, so misty subjects are not accepted but since when are aircraft in the snow rejected!?  Confused
Any advice, especially from screeners, would be very much welcome!
http://www.airliners.net/addphotos/r...big/20060107_ra85626ELLX281205.jpg
http://www.airliners.net/addphotos/r...s/big/20060107_lxscvELLX281205.jpg
Both rejected for quality!!
"Go ahead...make my day"
martin21
RE: Here We Go Again...
Sun Jan 08, 2006 4:11 am
Do I see grain or snow ?  Wink
Martin21
At 30.000 feet, the sun always shines !
javibi
Sun Jan 08, 2006 4:15 am
Nice shots, but screeners here do not give a shit about how much you froze out there... pity.
I love the 747.
j
ThierryD
Crew
Sun Jan 08, 2006 4:56 am
Quoting Martin21 (Reply 1):
That is 100% pure snow...
tom3
Sun Jan 08, 2006 5:48 am
Hi there
Your pictures are good , can't understand the rejection reason 'Quality' ?!
Well has my snow better quality ?  laughing
Photo © Tom Mousel - Luxembourg Aviation Photography
Tom  Smile
Tom Mousel - Lap
sulman
Sun Jan 08, 2006 6:02 am
Well, I'm an absolute sucker for anything in snow, so I'm a bit biased, but I think these are wonderful, I love the atmosphere, and can imagine the whine of the engines and scrunch of the tires on the snow.
There's nothing really wrong quality-wise, the issue I expect is the fact that the subject is in a snowstorm, and therefore you can't see it as clearly as you'd like. If this was a reject, surely motive would be the category?
aviopic
Sun Jan 08, 2006 6:10 am
Can you supply your exif data Thierry ?
I am afraid it's your technic that's letting you down here.
It's probably caused by a relative long exposure given the conditions.
The trick is to shoot as fast as possible with a high ISO.
Willem
The truth lives in one’s mind, it doesn’t really exist
ThierryD
Crew
Sun Jan 08, 2006 6:34 am
Quoting Aviopic (Reply 6):
ISO 200
1/200s
F/7.1
aviopic
Sun Jan 08, 2006 7:39 am
Quoting ThierryD (Reply 7):
ISO 200
1/200s
F/7.1
That's what I thought.
In the given conditions it is better to "freeze" the snow  Smile this way the snow will be less visible leaving you with a much more crisp photo.
Try 1/1000s probably at ISO 800 or so, noise might become a problem but I don't know what camera you are using.
It works fine with a 20D though.
One last tip: do not under expose in snowy conditions that will make it very noisy, I usually use +1 exp compensation(at least) in these conditions.
Good luck,
Willem
ThierryD
Crew
Sun Jan 08, 2006 7:49 am
Quoting Aviopic (Reply 8):
ISO 800 !?? I'll probably get grains big as a canonball, no!?  Confused
But anyway, I didn't want to 'freeze' the snow (it was cold enough out there!  Smile ); but then I guess if I don't want to freeze the snow it's probably another kind of shot that I (and apparently many others) like but that won't get through the new A.net criteria... those really give me headaches  Sad
BTW: using a Nikon D200
norfolkjohn
Sun Jan 08, 2006 7:50 am
Hi Thierry,
First of all I must say good on you for going out and shooting in such hostile conditions. I certainly like the motive of these shots and it is always good to see something out of the ordinary.
I have a few comments which may or may not be of some help. The first thing I would say is that both shots look rather washed out and flat (i.e. lacking contrast) and this is not just due to the snow storm. I'm not sure what program you are using for editing but if you look at the levels histogram in Photo Shop you can bring both the light and dark sliders in a long way before they get to the edges of the graph. This increases the contrast and to my eye gives the shots a lot more punch.
I feel the aircraft look just a little soft in both shots and perhaps another kick of USM might be in order.
I also note that the shots are a non standard size and aspect ratio and it may be better to try either 3:2 or 4:3 aspect ratio with a width of either 1200 or 1024.
The last think I would say is that it might be better not to crop out the edge of the horizontal tail fin on the TU154.
These are just my thoughts.
All the best,
John
One thorn of experience is worth a whole wilderness of warning.
andz
Mon Jan 09, 2006 5:59 am
Quoting ThierryD (Thread starter):
Photo © Walter Pietsch
Airplanepics
Mon Jan 09, 2006 6:11 am
Quoting Andz (Reply 11):
Photo added: December 1, 2002
Average views per day: 5
Simon  Smile
Simon - London-Aviation.com
norfolkjohn
Mon Jan 09, 2006 7:56 am
Actually misty shots ARE accepted :
Photo © John Allan
Photo © John Allan
These two were taken last October - but I admit it does depend just how thick the mist is !
John  Wink
ThierryD
Crew
Tue Jan 10, 2006 2:43 am
Quoting Norfolkjohn (Reply 13):
Your shots show only mist in the background; planes are not concerned!
Thx John for your thourough answer!
I'm somewhat disappointed that no screener commented the issue  Sad
I'd be really interested in knowing their opinion.
gerardo
Tue Jan 10, 2006 4:21 am
I would have tried the oposite and try to have "more snow" with a longer exposure time. For example like this (exp. 2.5 seconds, F10)
Photo © Gerardo Dominguez
But perhaps this only works on night shots? Don't know...
Gerardo
dominguez(dash)online(dot)ch ... Pushing the limits of my equipment
aviopic
Tue Jan 10, 2006 7:09 am
Quoting Gerardo (Reply 15):
That's a cracker of a shot Gerardo  thumbsup
That's indeed the difference, you can't see snow when there is no light.
If you look closely at your photo there is only snow visible on the left side probably because of a light post but against the dark night sky above the flightdeck nothing is visible.
The same image taken with the same setting(most likely not possible) during daylight would have blocked out the aircraft due to the snow.
Which in it self can be very nice but probably not according A.net rules.
Willem
gerardo
Tue Jan 10, 2006 3:02 pm
I guess, I have to go out on daylight for aviation photography once it starts snowing again  Wink
Thanks Willem!
Gerardo
