Shaggy
Nikkor 80-400mm ED VR Opinions
Thu Jan 19, 2006 5:56 am
I just wanted to see what the general view was on the Nikkor 80-400mm ED VR.
At the moment my long lens is a Sigma 170-500mm
Lee
skidmarks
RE: Nikkor 80-400mm ED VR Opinions
Thu Jan 19, 2006 5:59 am
Some would appear to dislike it Shaggy, but it works for me. Like any lens, use it within it's parameters, and it's fine.
I'm still learning what you can do with it right now. But, I love it, so..........
Andy  old
Growing old is compulsory, growing up is optional
scbriml
Thu Jan 19, 2006 6:21 am
I have this lens and have had some good results with it. I've also had some less than good results, but the % of good shots is improving.
It's the only non AF-S lens I have, so it's focus speed is slow (compared to all my other lenses). If it does lose focus while tracking a plane across the sky, it will start hunting and generally can lose you a shot in those circumstances.
In less than perfect conditions, it can be a bit soft at the 400mm end of it's range.
In my camera bag, it's competing with arguably Nikon's best lens - the 70-200VR. My preference is to use the 70-200 whenever I can, but if I need more reach, I won't hesitate to go for the 80-400.
All that said, I've got quite a few shots up here taken with it. A few recent examples:
Photo © Steve Brimley
Shaggy
Thu Jan 19, 2006 7:06 am
The shots look nice, but as mentioned some people have had bad things to say about it.
At the moment though it will be better than 170-500 I have. Are there any other alternatives?
scbriml
Thu Jan 19, 2006 7:29 am
Quoting Shaggy (Reply 3):
There have been a number of threads here recently discussing this lens. I used to have the Sigma 170-500 as well, but really couldn't get on with it. In the end I traded it in for the 80-400VR and I'm glad I did.
Shaggy
Thu Jan 19, 2006 8:36 am
Sounds like the answer I am looking for  Smile I will of course try it out first.
Lee
Kereru
Thu Jan 19, 2006 9:18 am
Yes but they cost a lot of money!
200-400mm f/4G ED-IF AF-S VR Zoom-Nikkor
http://www.nikonusa.com/template.php?cat=1&grp=5&productNr=2146
300mm f/2.8G ED-IF AF-S VR Nikkor
http://www.nikonusa.com/template.php?cat=1&grp=5&productNr=2154
Check:
http://www.airliners.net/discussions...tion_photography/read.main/212603/
Good things take Time.
UALDUDE
Thu Jan 19, 2006 10:11 am
I use this lens and have had nothing but excellent results and performance from it. I have heard so many people complain of slow auto focus, but I don't notice that at all. I have had no problem doing action shots, takeoff, landings, etc. I have not shot with a Nikon 70-200mm 2.8 VR, which is supposed to be really fast, so I don't have a comparison. This lens is as fast as any of the other lens I have shot with for the past 12yrs. I have shot with Minolta and Nikon lens and this is my favorite. I am not really wild about Sigma lenses. I looked at the Sigma 80-400mm OS lens and was not impressed, too clunky and heavy. Not that the Nikon 80-400 isn't heavy, but compared to the Sigma it feels light.
sunilgupta
Thu Jan 19, 2006 10:35 am
The optics are the lens are good but the lens is very fragile. Mine has been back to Nikon at last four times (stopped counting) for various issues and now its just not as sharp as it should be.
Sunil
IngemarE
Thu Jan 19, 2006 5:17 pm
Quoting UALDUDE (Reply 7):
Neither was I,....until I tried them, that is.
-"Heavy is good, heavy is reliable." (..said with a thick "russian" accent.) (The actor is from former Yugoslavia, however.....)
I've had the Nikkor. I preferred to sell it, rather than using it as a 1500$ door-stop. (As I've heard others on this here forum does! Big grin)
Tried the Sigma, and it did beat the Nikkor. Hands down!
Of course this is just my opinion.  Wink
In thrust I trust.
Shaggy
Fri Jan 20, 2006 8:44 pm
I called Grey's Of Westminister, probably one of the finest Nokon Dealers in the UK and asked about this lens.
There reply was.
"I am at home at the moment and am 95% certain we have an 80-400 but would
not recommend it for a D2X (my past as a lens designer leaves me with
certain prejudices). The D2X sensor would probably out-perform the
resolution of the lens and you need a lens which is future proof and which
will out perform the D2X."
And then
"It is not easy to correspond by e-mail due to work nature and pressure.
Please call for a better explanation.
The 70-200 is the finest lens in that range. 80-400 is too much of a stretch
and aberrations affect the picture detrimentally.
You can go 200-400 with a zoom which is of superlative spec state of the art
quality if you wish to go beyond the 200 focal length.
80-400 is OK for the D70 range and perhaps D200 but even so the D200 may
out-perform it and the lens may not fully utilise the resolution of the
sensor. The D2X is frankly too good for the 80-400 and you will be getting a
D70 result if you use the lens."
Any thoughts?
jwenting
Fri Jan 20, 2006 8:59 pm
If Gray (not Grey) says so I tend to believe it. He's probably the leading expert on Nikon equipment in Europe.
Of course you have to take budget into account, but with a D2x Gray will assume budget is not a real factor (you got a €5000 body, you're unlikely to be so short on cash as to be unable to afford a €2500 70-200VR).
Do note that both alternatives he mentions (and they are far superior, hardly surprising as they're at least a generation newer) cost several times the price of the 80-400, and both have AF-S which the 80-400 lacks.
If I at the moment were looking for a new telezoom and could afford it I'd likely go for the 70-200 VR myself unless I needed the extra reach of the 80-400 in which case I'd give serious consideration to the 50-500 Sigma instead for its superior AF performance.
The 200-400 for me is just too expensive, but I'd certainly not turn one down if it were offered me as a gift  Wink
I wish I were flying
Shaggy
Fri Jan 20, 2006 9:04 pm
I am going to take some test shots in a moment on the 80-400, if anything it will be alot better than the 170-500mm Sigma I am using at the moment.
And your right it is about budget. Maybe an 80-400 now and then a year down the line look at my options.
scbriml
Fri Jan 20, 2006 9:32 pm
Quoting Jwenting (Reply 11):
Join the queue buddy! smile
Now if I could just get the right 6 numbers.... banghead
Shaggy
Fri Jan 20, 2006 10:04 pm
I toom some shots at lunch time in Tottenham Court Road, pretty much under the flight path into heathrow and the results were much better than my sigma lens.
I got a nice gift of off the lens too, a nice dust spot on the sensor  Smile
Still remain undecided.
codeshare
Fri Jan 20, 2006 11:57 pm
How about a 300/4 wit a teleconverter then?
How much A is there is Airliners Net ? 0 or nothing ?
Shaggy
Sat Jan 21, 2006 12:52 am
I nearly got talken into a 70-200 with a Teleconverter, that would be a good option would it not?
Although putting all that aside, for the money the 80-400 will be a vast improvement on my 170-500
jwenting
Sat Jan 21, 2006 2:23 am
Quoting Scbriml (Reply 13):
549900 (at least that's the price here in cents for the cheapest reliable store I know).
70-200 with TC would be great as well. Gives you either a very fast 70-200 or a reasonably fast 140-400.
Shaggy
Sat Jan 21, 2006 4:09 am
Yeah, still dont know. the appeal of the 80-400 is that I dont have to frig around changing lenses Big grin
Kereru
Sat Jan 21, 2006 4:43 am
Quoting Shaggy (Reply 16):
I have the 70-200 f2.8 and it is great. The 2x converter the results are rather soft and I think the converters are best used on the prime lenses like the 300mm. I am keen to get the 80-400 as it is the best compromise as the 200-400 is just too expensive at the moment.
Colin
Shaggy
Sat Jan 21, 2006 5:13 am
Those are my feelings Colin. I had a play today and have posted some examples on another website.
Its actually an OK lens. Focus was quick, the VR really did help.
I'll save for the 200-400 Big grin
psyops
Sat Jan 21, 2006 6:08 am
I just got one a couple weeks ago - these shots are awaiting screening and were taken with the new toy...
http://www.airliners.net/addphotos/b...g/ready/CGHKWJan132006edited1A.jpg
http://www.airliners.net/addphotos/big/ready/CGPATJan132006edited1.jpg
The focus is not as fast as my 80-200 f/2.8D or 300 f/4, but it hasn't bothered me too much.
I recommend from my limited experience so far.
Pete
Shaggy
Sat Jan 21, 2006 7:12 am
Yeah i think I have made my mind up.
I will get it on Monday unless I can find one at the weekend.
