fuairliner
Rejection Help
Thu Jan 19, 2006 11:56 pm
Hi everybody,
I just got this photo rejected for centered and soft. Although I can't really see where the photo is soft, some additional sharpening is not a big deal. However, I have no clue about how I should center this photo differently ...
http://www.airliners.net/addphotos/r...19_n34315_xx_733_ham_09-jan-06.jpg
Any hints & tips are appreciated.  Smile
Frank Unterspann - Hamburg, Germany
flyfisher1976
RE: Rejection Help
Fri Jan 20, 2006 12:06 am
Too low in the frame
martin21
RE: Rejection Help
Fri Jan 20, 2006 12:16 am
Quoting Flyfisher1976 (Reply 1):
How can you tell.... the plane is centered in the middle, unless you don't count the tail. But the average off the plane including tail is centered good !
Martin21
At 30.000 feet, the sun always shines !
linco22
RE: Rejection Help
Fri Jan 20, 2006 12:17 am
And i think its a little soft around the nose too. A bit of selective sharpening should do the trick!
Colin  Smile
vasanthd
RE: Rejection Help
Fri Jan 20, 2006 12:47 am
Vertical centering includes the tail. Mathematically speaking this picture is perfect. But Aesthetically speaking its low in the frame. Maybe some screeners can shed some light on this.
--Vas
One Lucky shot deserves another!
flyfisher1976
RE: Rejection Help
Fri Jan 20, 2006 8:22 am
Quoting Martin21 (Reply 2):
Exactly...If you browse through similar side-on shots in the database, you will see that they are centered using the fuselage (not including the tail) for vertical reference.
ptrjong
RE: Rejection Help
Fri Jan 20, 2006 9:10 am
I'm a pretty lousy photographer in some other respects, but I feel very confident on this issue.
You should not center on the fuselage, nor on the fuselage + fin.
Your subject is (usually) the fuselage + fin. However, the fin is much smaller than the fuselage and does not run its full length. Therefore, the fuselage is more prominent than the fin and you should account for that by moving the fuselage up a bit, moving the 'centre of gravity' of your subject up to the dead centre of the picture.
Quoting Vasanthd (Reply 4):
Right.
Well, that depends on how you calculate. I believe that one could actually calculate the aesthetic centre of a photo's subject, by measuring the areas of the different parts of the subject (in this case, fuselage, fin and a tiny bit of engine and landing gear). Then you could actually calculate the 'centre of gravity' of the subject.
Peter
ptrjong
RE: Rejection Help
Fri Jan 20, 2006 9:13 am
By the way, I don't think this picture was rejected for its centering - that would be a bit harsh, and I don't think the screeners are harsh in centering matters at all. It was rejected for the other issue, and you're asked to improve the centering as well.
fuairliner
RE: Rejection Help
Fri Jan 20, 2006 10:23 pm
Quoting Ptrjong (Reply 7):
That would explain why I never had problems with my centering in the past although I haven't changed anything over the past years. Thanks for your comments, everybody!  Smile
http://www.airliners.net/addphotos/r...19_d-aknm_4u_319_ham_09-jan-06.jpg
Rejected for soft only ...  Confused
jid
RE: Rejection Help
Fri Jan 20, 2006 10:54 pm
Quoting FUAirliner (Reply 8):
Yep because its soft !!!
A touch more USM in a few places should sort it.
Jid.
G7EPN is back after 15 years! Operating all Bands 80mtrs -> 70cms QRZ DX
fuairliner
RE: Rejection Help
Fri Jan 20, 2006 11:04 pm
Quoting Jid (Reply 9):
Hi Jid,
thanks, that's what I planned to do.  Wink
I'm just confused because the centering in this shot seems OK although it is centered exactly the same way as the first shot which was also rejected for this reason beside the softness.
flyfisher1976
RE: Rejection Help
Fri Jan 20, 2006 11:58 pm
Quoting FUAirliner (Reply 10):
I'm not sure what's confusing about this...When I opened the file the first thing that hit me was that it appeared too low in the frame. The vertical stabilizer is only a small piece of the aircraft, the fuselage of which is much larger in comparison. The fact that the vertical stab occupies such a small part of the frame makes the entire shot seem unbalanced. The majority of the frame is occupied by the fuselage and should be centered vertically:
Photo © Joseph A. Del Guidice
jid
RE: Rejection Help
Fri Jan 20, 2006 11:59 pm
It would be a touch lower than I would crop it but really the crop looks fine. Having the image so large will not help you with your sharpening process, if you reduce the width to 1024px you should find the overall process easier to handle.
Good luck .. Jid
ptrjong
RE: Rejection Help
Sat Jan 21, 2006 12:25 am
Quoting Flyfisher1976 (Reply 11):
Frank says he's confused because his latter shot was not rejected for centering. However, like I said, the screeners are not harsh in this matter, and you just can't expect every one of them to come to exactly the same conclusion in every one situation. They're human.
Joseph, I don't want to defend my point to death, but I personally think your planes are slightly high in the frame, because you ignore the fin completely when centering.
This is how I do it, somewhere in between, but giving the fuselage a greater say than the fin:
Photo © Peter de Jong
Peter wave
fuairliner
RE: Rejection Help
Sat Jan 21, 2006 1:43 am
I am confused that one shot (the ex-Continental 737) was rejected for centered while the other one (the Germanwings A319) seems to be alright (like many before), although they are both centered in the exact same way.
Btw, in your shots the planes look to high in frame to me, in both cases the whole picture looks slightly unbalanced.
I have reuploaded both pictures with additional USM and with the plane placed slightly higher in the frame, hopefully they get accepted now.
Users browsing this forum: Google [Bot] and 1 guest
