walter2222
Help Request For Quality Rejection?
Sun Jan 22, 2006 1:45 am
Dear All,
What should I do to make this picture acceptable, it was rejected for "quality"?
http://www.airliners.net/addphotos/r...178_EBFN_20050902_IMG_2284_WVB.jpg
Thanks for your advise and regards,
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
waketurbulence
RE: Help Request For Quality Rejection?
Sun Jan 22, 2006 2:54 am
First I'd downsize from 1600 pixels to 1024. The quality at that size is not there. It also looks soft as well. And has a dull appearance in the color. It would be easier to see if the shot can make it if we saw the original file.
-Matt
JeffM
Sun Jan 22, 2006 3:55 am
Quoting Walter2222 (Thread starter):
Soft and grainy for sure. Almost looks like too much crop to fill the frame, or not focused. I'm not sure you can "Fix" it enough for here.
walter2222
Mon Jan 23, 2006 7:53 am
Thanks for your replies (JeffM & Wake Turbulence)!
As soon as I have my own PC repaired (it crashed on Friday, 13th), I will follow your advise (starting again from the original - which is on my PC - and limit it to 1024pix - then have a look again!). I am currently working from the kids' PC, which lacks my originals and which has a lower quality screen... so, I will refrain from uploading from this station! (I had the idea that at 1600pix, more detail from the original would remain, but I see now that rejection is also more likely at that size!).
Walter
Users browsing this forum: Majestic-12 [Bot] and 1 guest
