Airimages
What's The Difference?
Fri Jan 27, 2006 2:37 am
Hi,
What's the difference between the following shots
Photo © Simon Wong
Photo © Ivan Coninx - Brussels Aviation Photography
Photo © Fabrice Sanchez - Brussels Aviation Photography
Photo © Rez Manzoori - FlightLineImages
Photo © Ralph Duenas - Airplanespotters
Photo © Christel JS - Female Spotter !
Photo © Jerome Zbinden
and my shot, which was rejected today because of "bad motiv"?
http://www.airliners.net/addphotos/r...s/big/20060126_ZbindenThaiA346.jpg
Silver1SWA
Crew
RE: What's The Difference?
Fri Jan 27, 2006 2:47 am
Wish I could tell you. I fell victim to this a few months ago.
linco22
Fri Jan 27, 2006 2:51 am
I would say, and I may not be correct, but the others show a little more than just the engine, with other parts of the aircraft or its surroundings. I think you have a great shot there but just too tightly cropped.....
You can try and appeal
Colin  Smile
MarkJBeckwith
Fri Jan 27, 2006 2:55 am
Quoting Linco22 (Reply 2):
 checkmark
Your rejected shot is a much tighter crop.
Mark.
One day, I might be good at this...
Airimages
Fri Jan 27, 2006 3:06 am
I can crop it out and show a "bit" of the wing and I believe I would get the same rejection or a new reason like "bad distance"
Jerome
[Edited 2006-01-26 19:06:40]
Rotate
Fri Jan 27, 2006 4:06 am
Quoting MarkJBeckwith (Reply 3):
Yep, Engine shots are very hard to get accepted. I think I only have 2 of them in the DB. Same goes basically for "ultra closeups" and "nightshots".
Robin
ABC
vasanthd
Fri Jan 27, 2006 4:58 am
Compare:
Photo © Simon Wong
and
http://www.airliners.net/addphotos/rejections/big/20060126_ZbindenThaiA346.jpg
Bad Crop? No...
Wait for a valid reason from the screeners and decide on appealing.
Edit: Whats the dark spot on the top left corner?? Could be bad motive...
--Vas
[Edited 2006-01-26 21:00:51]
One Lucky shot deserves another!
INNflight
Fri Jan 27, 2006 5:04 am
Quoting Vasanthd (Reply 6):
Compare:
The Dragonair logo on the engine makes it appealing. Your shot is "just" a white engine without anything special, that's why rejected I guess.
A shadow?!?
Jet Visuals
vasanthd
Fri Jan 27, 2006 5:10 am
I just noticed that the top left corner is also part of the aircraft reflecting a shadow(looks like an alien's shadow Big grin ). Maybe that maybe a cause for the bad motive.
--Vas
manzoori
Sat Jan 28, 2006 2:53 am
They may be equally tightly cropped but one does have a bit of aircraft in the frame whilst the other has concrete in the frame... just a thought.
Rez
 Big grin
Flightlineimages DOT Com Photographer & Web Editor. RR Turbines Specialist
Airimages
Sat Jan 28, 2006 8:02 am
Hi all
The dark spot in the left corner is just water on the ground  Smile
Jerome
ptrjong
Sat Jan 28, 2006 9:05 am
While a few shots like this have their place in the databace, - a few for each engine type maybe - nobody would want to see a million shots like this, so most of them get rejected for badwedon'tlikethemotivethatmuch really. So if you upload them you'll have to accept that screening for this kind of shots is a bit of a lottery. I think that's fine.
Just my view.
Peter
3DoorsDown
Sun Jan 29, 2006 1:48 am
I agree with the others that said it is too tightly cropped. Most of those shots you show were shot at the same level and show a lot more aircraft. Yours is shot looking slightly down and all you see is engine and not enough strut. Plus it's a solid white engine.
If you can, crop it less close so you get some wing in the shot. I think it would probably fly.
3DD
