viv
Rejection For Jaggies
Wed Feb 22, 2006 11:05 pm
I had this one rejected for jaggies. Can someone tell me where they are? I can't see them. Maybe I need a new screen ....
http://www.airliners.net/addphotos/r...ons/big/20060221_060211oovlzv1.jpg
Rotate
RE: Rejection For Jaggies
Wed Feb 22, 2006 11:07 pm
The reg is jagged, the cheatline and the starboardtitle ...
Robin
ABC
martin21
Wed Feb 22, 2006 11:13 pm
Also the gear doors in the engine. Try reducing the USM.
Martin21
At 30.000 feet, the sun always shines !
sulman
Wed Feb 22, 2006 11:54 pm
You know, minor sharpening artefacts aside, that looks okay to me. Maybe my work monitor.
You've used 500/0.2/0 haven't you? Some moire / artefacting is impossible to avoid. You can tell I've not uploaded shots like this in a while.
James
[Edited 2006-02-22 16:22:27]
viv
Wed Feb 22, 2006 11:55 pm
Quoting Sulman (Reply 3):
Exactly. I can see the jaggies on the gear doors ...
RuudOnline
Thu Feb 23, 2006 12:27 am
The next thing is that they reject this photo of Purple Fringe (see the purple and orange colors around the frontwheel)...
Ruud
martin21
Thu Feb 23, 2006 12:42 am
Quoting Ruudonline (Reply 5):
I think this is caused by the over sharpening.
Martin21
RuudOnline
Thu Feb 23, 2006 3:58 am
Nah...its caused by a less quality lens. Which does not matter because I like the photo as it is now (even with does damn jaggies).
Ruud
tom3
Thu Feb 23, 2006 4:07 am
Quoting RuudOnline (Reply 7):
Less quality lens ?
I've in my mind that Vivion is using a Nikkor 80-400mm , and that's a high quality lens !
Tom
Tom Mousel - Lap
viv
Thu Feb 23, 2006 4:35 am
Quoting Tom3 (Reply 8):
Yes!I like my lens!
martin21
Thu Feb 23, 2006 4:37 am
Less quality lens ?
My thoughts !
Martin21
viv
Thu Feb 23, 2006 5:02 am
Thanks to all for your helpful comments. I have reworked the original with a bit less USM and uploaded it again. Let's see what happens.
pitchul
Thu Feb 23, 2006 5:25 am
Good luck viv.
Emmanuel
martin21
Thu Feb 23, 2006 5:42 am
Can you show us your new uploaded version ?
Martin21
viv
Thu Feb 23, 2006 6:20 am
pitchul
Thu Feb 23, 2006 6:22 am
Quoting Viv (Reply 14):
Quoting Pitchul (Reply 12):
http://www.airliners.net/addphotos/b...2.jpg
Ok the jaggy are now gone  Smile
EMmanuel
GVerbeeck
Thu Feb 23, 2006 6:28 am
It looks a little soft now to be honest. You should give selective sharpening a try: sharpen your photo as the original, and just remove the jaggies with the eraser brush (with different opacities).
Also, there's a dustspot in the sky down from the reg.
Giovanni
martin21
Thu Feb 23, 2006 6:47 am
Have to agree with Giovanni, although I wouldn't go with the sharpen first one like he suggests. Use the usm again and go right in between the first and second. That should do it. Good luck.
martin21
viv
Thu Feb 23, 2006 6:58 am
Thank you both. Will try again.
RuudOnline
Thu Feb 23, 2006 7:00 am
Looks soft indeed. I liked the first one better.
And sorry I called your Nikkor 80-400mm a less quality lens  ashamed
viv
Thu Feb 23, 2006 7:38 am
Quoting RuudOnline (Reply 19):
That's ok! It's lesser quality than some other lenses!
jumbojim747
Thu Feb 23, 2006 8:18 pm
Viv if you look at where the De icing boot meets with the wing on the bottom you can see some jaggies they are also highlighted due to the sharpening .
All the best with the rework
On a wing and a prayer
Users browsing this forum: shattuckb02 and 1 guest
