JayDavis
Finding Sensor Dust Spots Using Photoshop
Fri Mar 03, 2006 9:11 am
I "tried" finding a similar thread on this subject but either I've used the wrong words for the search or there really isn't a thread on this subject.
I had recently some major sensor dust spots on my EOS 1D Mark II. Now granted, I could see some of them when I was working on the image in Photoshop, yet I couldn't see some of them when I uploaded some shots and they were rejected due to dust spots.
How do you use Adobe Photoshop CS2, to find sensor dust spots? Any particular work flow, or action, filter, etc.....???
Jay
jumbojim747
RE: Finding Sensor Dust Spots Using Photoshop
Fri Mar 03, 2006 9:21 am
Jay you can equalize the image they will stand .
Go to Image ,Adjustment ,Equalize
hope that helps
On a wing and a prayer
JeffM
Fri Mar 03, 2006 9:22 am
Quoting JayDavis (Thread starter):
Easy. Equalize!
ptrjong
Fri Mar 03, 2006 9:31 am
Note that you have to shift back to the normal view to clone the bastards out - you basically can't do that in Equalize view although there is a way around this.
It's all described in detail in Fergul's workflow which is linked to from the upload pages I think. You should probably digest the whole document.
Peter
JayDavis
Fri Mar 03, 2006 9:34 am
Well I looked for the thread and I got no reply...........
http://www.airliners.net/addphotos/PsProc.pdf
ptrjong
Fri Mar 03, 2006 9:38 am
Works fine for me, do you have Adobe Reader installed?
JayDavis
Fri Mar 03, 2006 10:34 am
I guess not.
I have everything else, it seems of Adobe software.
When I click on that link, it just acts like it is a "bad" url and it won't
open a website page.
RuudOnline
Fri Mar 03, 2006 4:11 pm
You can also increase the contrast and decrease the lightness.
You can see them even better when you 'move' the photo on your screen.
Ruud
Granite
Fri Mar 03, 2006 6:06 pm
Hi all
As Ruud mentioned, moving the image left/right quickly can spot them. Obviously this only works if the image is bigger than your screen.
This is one of the processes I use when screening.
Gary
timdegroot
Fri Mar 03, 2006 7:03 pm
An action to remove dustspots will be presented in the new rejection messages that I'm working on, hopefully this will help many people get rid of dustspots and thus reduce rejections.
Tim
Alderman Exit
JayDavis
Sat Mar 04, 2006 1:09 am
Tim,
Are you saying that you and/or someone else on A.net is making a Photoshop action to help us reduce and eliminate the sensor dust spots? That would be great.
Speaking of that, out of curiousity, are there any actions that users of Photoshop are currently using in order to process their images for better acceptance on this site? Would be curious to see what actions are out there for useage.
Jay
timdegroot
Sat Mar 04, 2006 1:23 am
Jay I shouldn't have said action, but there is a to eliminate dustspots by going through a few simple steps.
Tim
Alderman Exit
timdegroot
Sat Mar 04, 2006 1:24 am
Ok and here it is Smile
-Create a “Duplicate Layer
-Equalize the image. Image->Adjustments->Equalize
-Dustspots should now become visible. Now select the original layer (called background) to work on. Use the “clone stamp tool” or if you have Photoshop CS2 the “spot healing brush tool” and remove all dustspots.
-Delete the layer “background copy” (which we created earlier”
-You should now have an image free of dustspots.
Alderman Exit
flyingzacko
Sat Mar 04, 2006 1:34 am
I don't see how an action should work here anyways. How would it find the dustpots?
Sebastian
Canon 40D + 24-70 f/2.8 L + 70-200 f/4 L + Speedlite 430EX
Granite
Sat Mar 04, 2006 2:27 am
Hi all
No action to eliminate dustspots will ever become available.
Photographer 'pre-screening' is required for this. I know it's a pain in the ass but one of those things that digital photographers need to do now.
Always 'standard' to sharpen an image. Now it's 'standard' to check for dust spots.
Until The Boss rules out dust spot rejections we will all have to check  Smile
Gary
eddl
Sat Mar 04, 2006 2:57 am
Just keep your sensors clean. I don't want to bother with dust spots, it's annoying and time-consuming. I keep my sensor spotless and enjoy doing other things while you are playing with your cloning tool.  wave
 Wink
Phil / EDDL
walter2222
Sat Mar 04, 2006 7:02 am
Quoting EDDL (Reply 15):
Living on mother "earth", it's not always possible to keep the sensor clean (although that would be ideal...), certainly if you change lenses very often! It's of course better to prevent (cleaning the sensor) than remedy afterwards (using Photoshop). I check by just shooting a picture with high aperture number (i.e. small aperture) of the blue sky and then - if there are any dust particles on the sensor - the dust spots show up (equalizing is then in most cases not even necessary). If several show up, then it is cleaning time!! I have done it already several times myself, and it is not that difficult (I use a special fibre-brush from "Visibledust", called the "Artic Butterfly").
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
JayDavis
Sat Mar 04, 2006 9:44 am
Thanks for all the tips/hints.
Still curious if there are any Photoshop actions that people use on this forum to work their photos ??
I know Colin Wok (I think that is his name) used to have some actions when digital was first introduced. Does he or others still have actions we can download somewhere?
Jay
JeffM
Sat Mar 04, 2006 12:11 pm
Quoting JayDavis (Reply 17):
I make actions for almost everything.... Try these...
Using Actions/Masks...My Tutorial With Links! (by JeffM Aug 31 2005 in Aviation Photography)
