flyfisher1976
This Must Have Been A Mistake...
Fri Mar 03, 2006 11:30 pm
I have a suspision that this rejection reason was erroniously applied...maybe the wrong box was checked?
How can you reject this photo for "motive"...
http://www.airliners.net/addphotos/r..._3299_2006_02_16_BOS_N925UA.jpg???
I'll just assume that this was a mistake. Can I get the real rejection reason from the screener?
Also, this one was rejected for soft:
http://www.airliners.net/addphotos/r...IMG_3281_2006_02_16_BOS_N505AU.jpg
This was one of the many times where a personal message from the screener would have helped a lot. Was it soft in some areas, or the whole image? Image sharpening is one area that I have a lot of trouble with despite using suggested workflows. Any help would be appreciated.
Thanks.
tom3
RE: This Must Have Been A Mistake...
Fri Mar 03, 2006 11:35 pm
Hello
For the first one I think it's Bad Motive because the tail is cut off !
And for the second , a little more sharpen and then it should be ok IMO !
Tom
Tom Mousel - Lap
flyfisher1976
Fri Mar 03, 2006 11:45 pm
Quoting Tom3 (Reply 1):
Thanks for the input, but I hardly think that is the case. I don't think I need to post examples to show that this "motive" has many other accepted examples in the database. Had to be a mistake. I will appeal this one, unless anyone has any other suggestions.
As for the second one, it was processed using the same workflow as all the others that were accepted. So why would it be rejected for soft? Was it soft just in some areas?
sulman
Fri Mar 03, 2006 11:47 pm
Joseph,
It's a great shot (nice lighting) but these things are subjective - I've had similar angles rejected. Appeal by all means but don't sweat it.
James
airkas1
Crew
Fri Mar 03, 2006 11:48 pm
Well, I agree that it looks rather weird with the tail cut off like that.
Airliners.net Crew - Head Photo Screener
flyfisher1976
Sat Mar 04, 2006 12:02 am
Quoting Sulman (Reply 3):
I just don't understand how a particular crop could be so widely accepted, then suddenly rejected for motive. I mean, what's fair is fair, and this certainly is not.
ThierryD
Crew
Sat Mar 04, 2006 1:01 am
Quoting Flyfisher1976 (Reply 5):
I don't think that this kind of crop is widely accepted here on A.net; at least I don't recall having seen shots here in the near past where entire parts of the tail were cut off.
You might mistake the crop with crops that have stabilizers cut off but on your shot the entire rear part of the aircraft is gone and that's quite clearly stated as badmotive here on A.net.
If possible re-upload the shot with the tail in and it should work out ok.
Thierry
"Go ahead...make my day"
Lindy
Sat Mar 04, 2006 1:05 am
Evidently you didn't read the Airliners.net Upload Page rules. You can find it here: http://www.airliners.net/addphotos/
One of the points states:
- Upload shots showing the whole aircraft with no part covered or cropped out.
Take it easy, its not end of the world.
Rafal
BWIADCA - Nikon D100
ptrjong
Sat Mar 04, 2006 1:07 am
You cut only 10% off the aircraft and that doesn't look good at all in my opinion. We shouldn't declare our pictures equal to others so easily.
Peter
AdamWright
Sat Mar 04, 2006 1:17 am
The bar has definately been raised. The screeners are getting more picky.
Can anyone help me with this rejection? Rejected for "BLURRY"
http://www.airliners.net/addphotos/r...s/big/20060303_Picture182edit1.jpg
Adam
Newark777
Sat Mar 04, 2006 2:23 am
Quoting Adamwright (Reply 9):
Looks like motion blur, especially noticeable around the engine. Probably nothing to do about it, unfortunately.
Quoting Lindy (Reply 7):
There's plenty of shots on here with something cropped off, so that's not a steadfast rule, which leads to this confusion.
Harry
flyfisher1976
Sat Mar 04, 2006 2:32 am
Give me a break!   This is just another case of selective application of the "rules". Many pictures with portions of the aircraft cropped out were accepted in the past and on an ongoing basis...Sorry, but your reply is a cop-out.
Quoting Newark777 (Reply 10):
 checkmark
Thanks for the condescending commentary. I hardly see it as the "end of the world". Just pointing out another batant example of screening inconsistency on this site.
[Edited 2006-03-03 18:34:36]
edoca
Sat Mar 04, 2006 3:14 am
I disagree that it is blatant screening inconsistency. In my opinion, this crop is not esthetically pleasing. Other crops are (in general) better. That I guess was also what the screener thought. There is no inconsistency in that. Just think by yourself - would this pic be better if I had not cropped it? If the answer is no, by all means appeal, if it's yes, try to rework it... Just my 2 cents...
Stealthz
Sat Mar 04, 2006 5:15 am
Hi,
I would have gone with grainy as well but as no one else picked up on that the problem may be with my monitor.
Motiv, I am going to agree it is not an especially pleasing crop, should have cropped more or less of the tail.
I was going to link other photos to illustrate but you 2nd one is a decent example of a crop that works better.
C
dendrobatid
Sat Mar 04, 2006 5:25 am
Quoting Flyfisher1976 (Reply 11):
I can't remember exactly where it was in the rules but there is something about well motivated crops being acceptable and that is my way of doing things. I like tight crops and a good many of mine have bits missing. I crop at the taking stage rather than on the computer. Hopefully they are well motivated and as others have said, your example here looks awkward. I would have to say that I consider it bad motive too.
Mick Bajcar
9VSPO
Sat Mar 04, 2006 5:28 am
Quoting Dendrobatid (Reply 14):
 checkmark  Me too.......well I try lol. Big grin
Lindy
Sat Mar 04, 2006 5:43 am
I just had 2 pictures rejected  Smile LOL in this very moment. I didn't get rejection email yet so I don't know the reasons.
Just laugh about it. I had many pictures rejected for bad crop  Smile
Rafal
PS - On this forum I'm not speaking for airliners.net, just for myself like regular users (so please don't think that a.net don't care about you)  Smile
flyfisher1976
Sat Mar 04, 2006 6:08 am
Lindy, sorry if i took your comment the wrong way...
Will try a different crop, thanks for all who gave input.
flyfisher1976
Sat Mar 04, 2006 6:21 am
Is this crop any better?
http://img331.imageshack.us/img331/4765/img329920060216bosn925ua20ai.jpg
Thanks, JD
jumbojim747
Sat Mar 04, 2006 6:36 am
JD that looks a lot better in my opinion.
Good luck with it its a lovely shot.
On a wing and a prayer
Morvious
Sat Mar 04, 2006 6:59 am
Quoting Flyfisher1976 (Reply 18):
IMO it does look better, but it still isn't perfect.. (In my oppinion that is)
A crop closer to the left engine could look better..
Now it looks bad centered!
Stefan van Hierden
have a good day, Stefan van Hierden
LGW
Sat Mar 04, 2006 7:08 am
JD,
If it were me uploading I would crop it like this:-
http://img132.imageshack.us/img132/791/7375226no.jpg
Also, not sure if it is me or my monitor but the image looks like it could do with a small kick of contrast, I have added a touch to my link
Ben
Lindy
Sat Mar 04, 2006 7:16 am
Quoting Flyfisher1976 (Reply 17):
No problem here  Smile
Rafal
ptrjong
Sat Mar 04, 2006 7:17 am
I agree with Stefan and Ben. Horizontally center the fuselage for this shot, ignoring the wings and engines.
flyfisher1976
Sat Mar 04, 2006 8:02 am
Quoting LGW (Reply 21):
JD,
This crop does look more balanced. Thanks, I'll probably give this one a try.
psyops
Sat Mar 04, 2006 1:24 pm
I played with this crop forever before settling this version. I think having the whole vertical stab in makes it more pleasing, also less space in front of the nose.
Photo © Peter Nickerson
I like your revised crop, seems to work better.
Pete
eadster
Sat Mar 04, 2006 7:47 pm
It's a great shot with the new crop there but I have the feeling that it'll go for having too much noise.
Quoting StealthZ (Reply 13):
Not your monitor Chris, there's a fair bit there.
