Cadet57
Rejected For Size, So Can I Reupload?
Thu Mar 09, 2006 10:51 pm
This just got size, so if I up it, will it get in now?
http://www.airliners.net/addphotos/rejections/big/20060309_c5pit.jpg
oly720man
RE: Rejected For Size, So Can I Reupload?
Thu Mar 09, 2006 10:54 pm
How big was the original?
Cadet57
Thu Mar 09, 2006 11:02 pm
Quoting Oly720man (Reply 1):
1000x759
flyfisher1976
Thu Mar 09, 2006 11:05 pm
Quoting Cadet57 (Thread starter):
will it get in now?
Unfortunately, the quality of this photo is below what would probably be accepted here. Most folks upload their shots at 1024 x 683 (or something similar). Unless a shot is of exceptional quality, I wouldn't bother uploading any bigger than this.
Cadet57
Thu Mar 09, 2006 11:08 pm
Quoting Flyfisher1976 (Reply 3):
Then why was it not thrown for quality and just size? Im being sincere, It really does not make sense to me..
JeffM
Thu Mar 09, 2006 11:29 pm
Quoting Cadet57 (Reply 4):
It's a one strike and your out ballgame. If the screener's were to list all the defects in a photo like that it would take quite a while. Once they have something that qualifies it as a reject, it's over. They have mentioned this probably 20 or 30 times that I remember reading.
As to the photo....the aspect ratio is wrong, it's almost square. The big glare spot is a killer. It does not appear level. It is not sharp, either you moved, or the focus was not on the right object.
oly720man
Thu Mar 09, 2006 11:30 pm
That's a screener question. You aren't the first to get a rejection then a different one after re-uploading.
I would assume bad quality was not given because the photo was obviously too small so there was no point in ticking any other boxes.
To me, too many of the instruments are blurred because the focus point is on the throttle warning plate, and there's too much flash reflection.
Quoting Cadet57 (Reply 2):
1000x759
Odd size for the original. Was that out of the camera?
Cadet57
Thu Mar 09, 2006 11:33 pm
Quoting Oly720man (Reply 6):
no, I cropped it a bit, as the Captains yolk was off center.
