scbriml
Is It Blurred?
Fri Mar 17, 2006 9:52 pm
I had this one rejected by a screener in training for blurry.
Would just appreciate others thoughts on if an appeal is justified - I can't see any point in reworking it if the image is indeed blurry.
http://www.airliners.net/addphotos/r...ns/big/20060317_scbriml_n308wa.jpg
timdegroot
RE: Is It Blurred?
Fri Mar 17, 2006 9:53 pm
Looks jagged not blurry.
Tim
Alderman Exit
eadster
RE: Is It Blurred?
Fri Mar 17, 2006 9:55 pm
No reason to appeal. Its very very jaggered.
Should be fixable though.
dc10tim
RE: Is It Blurred?
Fri Mar 17, 2006 9:56 pm
I'm on a laptop at the minute Steve and it looks a tad oversharpened overall (this screen does make things look too sharp), I can't see any blurred areas though.
Usually with shots like that, I find it is the edge of the rudder that gets slightly blurred, but I can't see that here.
Tim.
Obviously missing something....
Granite
RE: Is It Blurred?
Fri Mar 17, 2006 10:02 pm
Hi all
Have to say I think the image looks good!
I am finding it hard to see the jaggies.
Gary
viv
RE: Is It Blurred?
Fri Mar 17, 2006 10:20 pm
Jaggies on the U.S. flag, on my monitor at least.
Rotate
RE: Is It Blurred?
Fri Mar 17, 2006 10:51 pm
Quoting Granite (Reply 4):
 cheeky   cheeky   cheeky
Robin
ABC
p2philip
RE: Is It Blurred?
Fri Mar 17, 2006 10:57 pm
I dont think its too bad either. The flag and titles are jagged and the nose might be a bit blurry on the original compensated by a little too much sharpening. Should be fixable I believe. Otherwise nice shot!
[Edited 2006-03-17 14:57:53]
IL76
RE: Is It Blurred?
Fri Mar 17, 2006 10:58 pm
Looks ok... Some jaggies on top of the engine and where the white fuselage hits the grey belly, but nothing very serious...
E
OlegShv
RE: Is It Blurred?
Sat Mar 18, 2006 1:12 am
To add to what others have already noted, I can see some jaggies on the tail, where the dark blue meets white paint. Also a little bit on the leading edge of the wing. Otherwise it's a nice shot!
Granite
RE: Is It Blurred?
Sat Mar 18, 2006 3:26 am
Hi all
OK, can see some jaggies now.
This is the reason I screen at home and not during lunch at work.
Gary
scbriml
RE: Is It Blurred?
Sat Mar 18, 2006 3:31 am
Gary, can you do all my screening? wink
Quoting Granite (Reply 10):
Doh! banghead
OK, I won't appeal, but I'll rework it and try again. Thanks for the input guys.
Granite
RE: Is It Blurred?
Sat Mar 18, 2006 3:34 am
Steve
Process the image, duplicate the layer and then rub them out.
Apart from the minor jaggies, it's a nice image.
Gary
Users browsing this forum: JT8DJUJ, Yahoo [Bot] and 1 guest
