OlegShv
Will This 732 Make It?
Sun Mar 19, 2006 7:41 am
Hi everyone!
I'm a newbie here. What do you guys think about this one. Is the lighting really that bad? Should I pull it out? Thanks for your comments in advance.
http://www.airliners.net/addphotos/big/ready/n375dl-1-olegshv.jpg
Oleg.
jetmatt777
Crew
RE: Will This 732 Make It?
Sun Mar 19, 2006 7:51 am
There are some jaggies on the tail/fuselodge at the back of the plane.
-Matt  Smile
Lighten up while you still can, don't even try to understand, just find a place to make your stand and take it easy
OlegShv
Sun Mar 19, 2006 8:01 am
Quoting Jetmatt777 (Reply 1):
-Matt
Yes, there is a slotted wall behind the aircraft to disperse the engine blast. That part of the fuselage looks kind of jaggy, but it's not from sharpening. I'm not really sure what to do about it. Should I blur that somehow?
viv
Sun Mar 19, 2006 8:04 am
You are right about the lighting being bad. The aircraft is backlit, meaning that the sunlight is falling on the far side, not on the side you are shooting.
Look at the angle of the shadows.
Backlit shots do not generally get accepted here.
GVerbeeck
Sun Mar 19, 2006 8:11 am
Hi Oleg,
Sorry to say but it probably won't make it, as it's backlit. As a result of that, the nose is also blown out. For regular shots, try going for the sunny side...
Good luck,
Giovanni
OlegShv
Sun Mar 19, 2006 8:51 am
Thanks for your comments guys. I'm pulling it.
Oleg.
