Rotate
Bad Double?
Thu Mar 30, 2006 12:21 am
Photo © French Frogs AirSlides
Robin
ABC
mx330
RE: Bad Double?
Thu Mar 30, 2006 12:24 am
As far as I know French Frogs AirSlides are 3 guys uploading under the same name... correct me if I'm wrong.
Juan APM
All Canon! EOS 5D mk III, 8mm, 17-40, 24-105, 70-200 f2.8, 100-400L
Rotate
RE: Bad Double?
Thu Mar 30, 2006 12:27 am
Quoting Mx330 (Reply 1):
That would make things much more difficult of course ... , I thought its only 1 guy ... , anyway, perhaps someone can clear things up.
Robin
ABC
EWS
RE: Bad Double?
I thought the rules were each photographer had to have his own account, and that accounts couldnt be shared?
Lew
lasham
Crew
RE: Bad Double?
Thu Mar 30, 2006 12:39 am
Hi Robin
I choose the rhs photo when screening and put the other shot as double. But as you can see both got on!
Will be sorted
Tony
No sun no fun
Rotate
RE: Bad Double?
Thu Mar 30, 2006 12:45 am
Quoting Lasham (Reply 4):
Will be sorted
I see, just wanted to help out, defenetely not critize or whatever ...
cheerio
Robin
ABC
Granite
RE: Bad Double?
Thu Mar 30, 2006 1:06 am
Hi all
Mistakes happen but French Frogs should know to only upload one.
Gary
tom3
RE: Bad Double?
Thu Mar 30, 2006 1:44 am
He is only one guy , as far as I know his real name is Frank Delamarre , but not sure..
Tom
Tom Mousel - Lap
TZ
RE: Bad Double?
Thu Mar 30, 2006 1:47 am
Fixed now. Seems to have been a script error.
Regular uploaders ought to know to chose only one image from a sequence, so not normally a problem.
TZ
TZ Aviation - Aeropuerto de los Banditos Team Images
