andrewuber
New L Glass-But I Need Help With Settings!
Wed Apr 05, 2006 4:27 pm
Well I went spotting today with my new 70-200 2.8 IS, and the results were... not bad - but not quite what I expected for a $1,800 lens. I guess it's time to ask for help!
Here are a few samples from today - these are more or less straight out of the camera (except for a crop, resize and a LITTLE tweaking in Capture One). Sorry they are so big (1600 wide), but I wanted to show the grain and fuzz I'm getting with these settings:
I can't figure out how to copy the EXIF data in Capture One, so here is a rundown of the settings portion of it:
Canon EOS 20D
Firmware 2.0.2
EXPOSURE:
Shutter Speed: 1/1600
Aperature: f4.5
Max Aperature: f--
Exposure Program: Manual
Exposure Mode: Manual
Flash Mode: Flash did not fire
Metering Mode: Pattern
Drive Mode / Self Timer: Continuous
Exposure Compensation: 0.00
Flash Compensation: +2.00
ISO Speed Rating: ISO 100
Focal Length: 200mm
Auto Focus Mode: One Shot
White Balance Setting: Auto
Color Space: sRGB
Subject Distance Range: --
Subject Distance: unknown
File Info:
RAW, 6.585mb
3504 x 2332
I was using IS in mode 1 for all shots, in AF (far) mode. There is no filter on the lens, but I was using the hood.
OK I'm guessing I've got the camera settings all FUBAR, and honestly I still don't have a clue what I'm doing with aperature settings. Does this lens have a "sweet spot" that I should shoot for? Or is it best to try to keep it at 2.8 all the time? Was 4.5 too much?
The EXIF data above is for the UA 733 shot. The other two were had the following differences, all other settings were the same:
The BA 744 shot was at 1/1000, f5.0, focal length 78mm.
The UA 744 shot was at 1/1250, f5.0, focal length 200mm.
I tried a couple shots at f2.8, and got similar results (grainy, etc).
If anyone knows what settings I should use on the 20D, I would GREATLY appreciate it!!! I'm going back to ORD today to go spotting with Syncmaster, and would like to fix these issues before then (if possible!!)
Thanks for your help!
Drew   wave
Edit: Click on the images to see them full size...
[Edited 2006-04-05 09:28:19]
I'd rather shoot BAD_MOTIVE
sean377
RE: New L Glass-But I Need Help With Settings!
Wed Apr 05, 2006 4:36 pm
I think you maybe using the lens at it's softest spot down at 2.8 - 5.0. Most lenses are sharpest around f8 - f11.
Also, do you need IS on with shutter speeds of 1/1600th?
Edit: Where was the sun in relation to you. The photo's appear to be backlit a little!
[Edited 2006-04-05 09:39:01]
Flying is the second greatest thrill known to man... Landing is the first!
clickhappy
Wed Apr 05, 2006 4:38 pm
those look like shit  Smile
No need to shoot it so fast and wide...I would be aiming for something around 1/500 and f/8.
Also, it might help if the sun is to your back  Smile
viv
Wed Apr 05, 2006 4:40 pm
Use a slower shutter speed. This will give you a smaller aperture, therefore greater sharpness and depth of field. Try to keep the aperture around f/7.1 to f9.
With that lens at full zoom and in IS mode you can safely shoot at 1/200th of a second.
walter2222
Wed Apr 05, 2006 4:46 pm
Hi Drew,
Quoting AndrewUber (Thread starter):
On my lens (100-400mm) the IS mode1 is for steady shots, while the mode2 is for panning shots (I assume you were following the movement of the aircraft). Have you tried the mode2 as well?
I would also change the auto-focus setting to servo AF (I cannot do that on my 300D) since you have a 20D, that works much better for flying aircraft.
Walter
Canon 347d mkII ;-) - EFS10-22mm f/3.5-4.5 USM - EFS18-55mm - EF28-105mm f3.5/4.5 - EF100-400mm f4.5-5.6l IS USM - ...
jay767
Wed Apr 05, 2006 4:49 pm
1/1600 sec. is absolutely insane.1/500 for a lens without any IS.
You have IS and could go lower.I turn IS off until I go below 1/400.
DLKAPA
Wed Apr 05, 2006 4:51 pm
Quoting Clickhappy (Reply 2):
Royal I gotta hand it to you, you are full of all that is true but completely useless, and you're damn proud of it. Good job dude!  bigthumbsup
EWS
Wed Apr 05, 2006 8:42 pm
Is there any need for that? You started somewhere remember.. when you got your first super dooper lens i bet you had a few crap shots until you got used to it.. give the guy a break.. so nice to see crew members putting folks down..
JeffM
Wed Apr 05, 2006 9:24 pm
Only use that for stationary objects Drew. AI Servo is for moving objects. Also, I agree with Royal, you are way to wide on the aperture for that distance and get your shutter down to around 1/500. I'd like to know how you came to those exposure settings as well.
clickhappy
Wed Apr 05, 2006 11:37 pm
Lighten up EWS!
I consider Andrew to be a friend, so I don't think I am 'putting him down'
After all, if he would have taken my advice in his last thread, and dumped the Cannon gear for some Nikon kit, we wouldn't be having this discussion!
JRadier
Thu Apr 06, 2006 12:31 am
Quoting Clickhappy (Reply 9):
Might want to watch out with comments like that......
(especially with Canon's known for less grain then Nikons...)
vasanthd
Thu Apr 06, 2006 12:34 am
Hi Drew,
Happy Belated Bday!
I thought you would get a new Wide angle lens...  Smile
Anyways, yea... You seem to use the Manual (M Mode) in your 20D with fixed AV and TV. Change it to AV Mode and let the camera decide what shutter speed is appropriate. the 70-200 2.8L IS is an excellent lens... Narrow the aperture and set the focus point to center with AI Servo and you would see a smile pop up with every photo.
Have fun with your new glass  Smile
Vas
One Lucky shot deserves another!
mikephotos
Thu Apr 06, 2006 12:42 am
Quoting EWS (Reply 7):
That little smiley after the comment says it all. Relax!  Wink
Quoting JRadier (Reply 10):
Yeah, grain might be better at ISO6400 but who here shoots at 6400. That's like shooting approach shots at f4.5 1/1600, who the heck would do that  Wink
Mike
vasanthd
Thu Apr 06, 2006 12:54 am
Quoting Mikephotos (Reply 12):
I guess you mean 3200. I dunno if Canon bodies have ISO > 3200...
Vas
[Edited 2006-04-05 17:56:12]
mikephotos
Thu Apr 06, 2006 1:00 am
Quoting VasanthD (Reply 13):
I used 6400 as a joke, not meant to be fact  Wink
Mike
vasanthd
Thu Apr 06, 2006 1:09 am
Quoting Mikephotos (Reply 14):
Stupid me...  boggled   Wink
--Vas
andrewuber
Thu Apr 06, 2006 2:21 am
Gee Royal, tell me what you REALLY think!  yell
As I've mentioned, I already have a Motorola camera phone - which is pretty much the same thing.  duck
By the way folks, it's true - Royal and I are friends (despite his Nikon habit), so these cheap shots at each other are not a problem at all. Besides, he's just jealous (have you garage-saled your nikon shit yet Royal???).
Quoting VasanthD (Reply 11):
My 70-200 F4L is on E-Bay as we speak, it ends tomorrow. I plan to cash that in for a 17-40L. The wife authorized "any lens" I wanted, so I went for the big dawg. I did, afterall, buy her a $3,000 diamond for HER birthday last year!  bigthumbsup
OK regarding the lens issue - I went back and checked my camera settings, and it seems that my "custom functions" were out of whack. The camera was adding in some sharpness, contrast and saturation - which I set back to "zero". Also, I will try AI focus.
As for aperature, I'll try shooting in the 7-9 range, in aperature priority. I guess I always thought that a faster shutter meant sharper pictures. Appearantly I was wrong there!  dopey
Thank you all for your fast answers, I'll do some shooting today and upload some samples tonight when I return to FWA.
Drew  wave
I'm kinda surprised Jeff hasn't sounded off to remind me that only amateurs use RAW.... duck
philhyde
Thu Apr 06, 2006 2:41 am
Drew,
How do the pictures look edited? You can tell a lot from the raw picture from the camera, but let's face it almost all digital pictures need to be edited to some degree.
I concur with the recommendations for the settings. I have just recently switched from AI Focus to AI Servo, and the jury is still out. The biggest thing to get used to in servo mode is that there is no beep when it locks on (although the focus zone flashes).
Phil
[Edited 2006-04-05 19:46:21]
Canon junkie - Aviation Nut
INNflight
Thu Apr 06, 2006 3:19 am
Hey Drew,
Quoting AndrewUber (Reply 16):
And you ended up with a 70-200 2.8???  banghead   cheerful
These parameters don't have any impact on the file when shooting RAW at all.
I'm sure you'll get happy with your new toy!
F.
Jet Visuals
clickhappy
Thu Apr 06, 2006 3:26 am
Grain. Such a measurebator term.
How many of us shoot at more than 800 ISO?
Anyways it's okay that most of you shoot Cannon. After all, Nikons (like a Girard-Perregaux watch, foie gras, and Chat La Mondotte) are an acquired taste.
ake0404ar
Thu Apr 06, 2006 4:00 am
That one puts a smile of my face.....don't ya'll love those American girls!
It's all about diamands and perls!
VG.
p.s. the 70-200 f2.8 is a killer lens, try aperture prio for a while, f6.3 or f8 and check the results....you should be doing fine then!
DLKAPA
Thu Apr 06, 2006 5:19 am
Quoting Clickhappy (Reply 19):
Aviation or otherwise?  Wink
javibi
Thu Apr 06, 2006 5:29 am
If you throw the diamond AND wife in the lot you'll probably get enough for a 600mm f4 L, think about it!  devil
j
javibi
Thu Apr 06, 2006 5:33 am
Four out of my five most popular pictures are ISO 800 or 1600  Wink
j
JRadier
Thu Apr 06, 2006 7:16 am
Try very low light photography or Theather....
Staffan
Thu Apr 06, 2006 7:19 am
Question you should be asking yourself is how many of you shoot any less than ISO 200  Wink
Add some ND filters to that list  Smile
andrewuber
Thu Apr 06, 2006 11:16 am
Escargot and Haggus are acquired tastes too - and I won't be feasting on snails or lung anytime soon either.  vomit
Quoting AKE0404AR (Reply 20):
Let me say two things about her - One she's not about diamonds at all, I just enjoy spoiling her, and Two - she's not even American. In a few months she will become a US Citizen though.
Quoting Javibi (Reply 22):
A 600mm f4 L won't go down on me whenever I snap my fingers though.
Anyway, I just got home from Chicago and am sorting through a handfull of RAW files as we speak. I wasn't able to do much spotting today, but hopefully next week I will be at ATL!
Drew  wave
JeffM
Thu Apr 06, 2006 12:19 pm
Quoting AndrewUber (Reply 26):
Raw is for amateurs..  Wink
Sorry, couldn't resist. I understand why people shoot RAW, don't get me wrong...I just can't stand the extra work, and seldom need the extra lattitude you can draw out of it. When all is said and done, you have a jpeg anyway right?
...Also a member of the "buy the wife diamonds club." I have a few MkII's sparkling on her hands....  Smile
andrewuber
Thu Apr 06, 2006 1:12 pm
Quoting JeffM (Reply 27):
I soooo saw that one coming!!!
Way to go Jeff - so I'm not the only one!! Just for that, welcome to my RR list (finally)!
JAT74L
Thu Apr 06, 2006 6:10 pm
Mmmmm..... Haggis!  tongue
John
I like trains just as much as planes but trains don't like the Atlantic!
JRadier
Thu Apr 06, 2006 9:41 pm
Jeff uses Small and normal JPG quality :P
JeffM
Thu Apr 06, 2006 10:05 pm
Quoting AndrewUber (Reply 28):
Heck no, there may be a few others I would hope. I'd pick out the damn things for her myself, it's just she does such a better job.  Wink
Well thanks Drew, back at 'ya.
