ZSOFN
Heathrow T4 Shot Rejected
Thu Apr 06, 2006 10:12 pm
Hi guys
Attempting to get my 2nd shot up here; don't really have the equipment (and in this case the conditions) to get it many shots accepted here.
This one was rejected for quality and motive; can I salvage this one? Unfortunately I cropped out the bottom of the A321's fuse when I took the shot.
http://www.airliners.net/addphotos/r...ections/big/20060406_DSCF1934c.jpg
JeffM
RE: Heathrow T4 Shot Rejected
Thu Apr 06, 2006 10:47 pm
Quoting ZSOFN (Thread starter):
I doubt it Tom.
That was the Motive part. The quality part is just not there.
Kukkudrill
Fri Apr 07, 2006 12:46 am
I agree with Jeff about the motive but not the quality. Can't see anything wrong with it that couldn't be fixed with some selective sharpening and maybe tweaking of levels. What equipment do you use? You don't have to have a DSLR to get photos accepted, though obviously it helps. I've got over 200 here that I took with a point-and-shoot.
Charles
Make the most of the available light ... a lesson of photography that applies to life
ZSOFN
Fri Apr 07, 2006 1:01 am
Thanks guys.
I'm using a Fuji Finepix S5500 with a basic UV filter. Software-wise I've got Photoshop CS2. I think I can do a better job of this in terms of quality (as you say, selective sharpening amongst other things) and the colour balance could probably be better.
Do you think the motive - which I can't do much about due to the original shot - is an instant disqualifier?
ZSOFN
Fri Apr 07, 2006 7:05 pm
Didn't want to start a new thread, so I'll post here. I'm having some monitor issues in that I edited this shot at home on what is probably not such a good screen. Now at work the image looks a little too dark. What do you guys think?
http://www.airliners.net/addphotos/big/ready/DSCF4654b_final3.jpg
eadster
Fri Apr 07, 2006 7:35 pm
I agree, the Quality looks quite ok on the first one but could improve in some spots. But I'm no pro!
The second one, levels are fine according to the CS2 Histogram. I'd try messing with the Shadow/Highlight feature without causing grain to show. It may not work but give it a go. May brighten things up a tad, but well on the way to a good shot that one.
Oh and a few jaggies starting to appear, around the tops of the engines, flap areas and cockpit windows.
ZSOFN
Fri Apr 07, 2006 11:34 pm
Thanks for that, I've had a go at those elements and re-uploaded, same link as before.
