LIPH
Flash In Cockpit And Cabin Shots
Fri Apr 07, 2006 7:47 pm
Which flash setting do you use in "normal conditions" to shoot at cockpits and cabins ?
Life sucks. Then you die. Live fast, die young.
JeffM
RE: Flash In Cockpit And Cabin Shots
Fri Apr 07, 2006 10:13 pm
What is "normal" to you?
LIPH
Fri Apr 07, 2006 10:48 pm
Quoting JeffM (Reply 1):
Not in critical light conditions.....
jumbojim747
Fri Apr 07, 2006 10:55 pm
I saw a shot on Anet only a week or so ago the runway was in sight for the pilots and the photog took a shot with the flash going off.
I'm not sure if he asked the pilots but I'm thinking it wouldn't be a good idea when they are concentrating on the job for a flash to go off.
I wont post the shot but its there.
On a wing and a prayer
JeffM
Fri Apr 07, 2006 11:57 pm
Quoting LIPH (Reply 2):
does that mean daylight or darkness?
LIPH
Sat Apr 08, 2006 12:30 am
Quoting JeffM (Reply 4):
Critical=darkness....
paparadzi
Sat Apr 08, 2006 10:25 pm
For daytime cockpit shot, there are 3 simultaneus lighting condition that need to be addressed. First, the outside, which will be very bright and requires a high shutter speed. Second, the inside of the cockpit, which will be darker. To address this 2 problems a high-speed sync flash can be used, so both the inside and the outside is properly balanced.
Photo © M Radzi Desa
The third problem is the instrument panel, either CRT or LCD. These requires a longer exposure. The problem is that this will make the exterior washed out.
I've yet to find out how to have all three situations addressed in a single photo. Any idea?
Rules are made for the guidance of wise men and the obedience of fools.
aviopic
Sun Apr 09, 2006 4:55 am
Quoting Paparadzi (Reply 6):
There is no need to.
Photo © Fabrice Sanchez - Brussels Aviation Photography
Photo © Eric Patrick
Determine the aperture you want to use, dial it in and take a reading at the brightest spot you can find.
Switch to manual mode and dial in the found value for exposure together with the same aperture.
Turn on the flash light and put it in high speed mode, use it indirect via the ceiling or so.
That's it.
The truth lives in one’s mind, it doesn’t really exist
TWAMD-80
Sun Apr 09, 2006 5:44 am
Quoting Aviopic (Reply 7):
I am not very familiar with using an external flash, but would that mean pointing the bulb at the ceiling and bouncing the flash? Also while on the topic, how is the Canon 420 EX?
Two A-4's, left ten o'clock level continue left turn!
aviopic
Sun Apr 09, 2006 6:05 am
Quoting TWAMD-80 (Reply 8):
Edit1:Yes, exactly but there are more possibilities like using a flash cord which makes the use of the floor, rear or side panels a lot easier.
I am sure it's fine..... from 10D onwards as at this time E-TTL was introduced making the "EZ" type obsolete.
It's supports "high speed mode" and is able to tilt as well as rotate, so all you need is there.
Edit2: However now I think about it I think it does not have the extra "wide angle" extension which for example the 550 does have.
For flightdeck shots I use it all the time.
[Edited 2006-04-08 23:06:48]
[Edited 2006-04-08 23:09:48]
TWAMD-80
Sun Apr 09, 2006 6:16 am
Quoting Aviopic (Reply 9):
In that case I'd guess that you have the 550 - how do you like it? I am rather curious about the different flashes. The internal flash on the 10D is not really cutting it with the 17-40.
Tim
Staffan
Sun Apr 09, 2006 6:51 am
But if the outside is too bright there's too much difference in luminance between the LCD's and the exterior to fit within one exposure.
aviopic
Sun Apr 09, 2006 7:16 am
Quoting TWAMD-80 (Reply 10):
Pretty good.
It does everything I expect from a flash light although I am thinking about getting the new 580 which supports E-TTL2, it seems to work even better.
The internal flash is nice for a snap or so but can't be compared to a serious flashlight, it simply lacks the power and can't be aimed in the direction you want.
Quoting Staffan (Reply 11):
That is why you are using a flash light Staffan, to bring the dark and light area's closer together so it does fit.
The Cessna 172 example from Eric Patrick in reply 7 is a good example, very bright outside but still the GPS is perfectly readable.
TWAMD-80
Sun Apr 09, 2006 8:35 am
When you use a flash for flight deck photos, do you use a diffuser?
Tim
aviopic
Sun Apr 09, 2006 9:12 am
Quoting TWAMD-80 (Reply 13):
Depends on the situation Tim.
Here I used a flashcord so I could keep the flash low in the cockpit and aimed in the direction of the pedals.
In this situation you don't want light to spread around and therefor no wideangle or diff devices were used, just stopped the flash down(-2 if I remember correctly).
Photo © Willem Honders
A textbook example as described in reply 7.
Flashlight is pointed upwards with the 550 wideangle device in front of it.
Working very close to the flight controls there is no room to bounce the light besides I want to show the 1958 instruments.
Flashed straight forward with the diffuser on top of the 550.
Still in the waiting list but nice anyway, working in a cramped space doesn't make it any easier.
http://www.airliners.net/addphotos/big/ready/AJSH37_51F21_MG_9809.jpg
So it all comes down to what you want and your own taste, there are many possibilities.
Just don't be afraid to try them and.................... fail Big grin
The last example took me probably 5 shots to get it right.
Willem
Staffan
Sun Apr 09, 2006 6:16 pm
Quoting Aviopic (Reply 12):
A flash won't light up a CRT, only the panel around it.
