Rotate
Bad Center?
Wed Apr 12, 2006 2:52 am
http://www.airliners.net/addphotos/big/ready/D-AIKA-MUC-040106.jpg
I still have some 5 pics in the queque and dont want to push my rejectrate higher, before I start my new approach ...
Is the above badcenter?
thx
Robin
ABC
airkas1
Crew
RE: Bad Center?
Wed Apr 12, 2006 2:56 am
Hi Robin,
I find it a bit high in the frame.
-Kas
Airliners.net Crew - Head Photo Screener
ptrjong
RE: Bad Center?
Wed Apr 12, 2006 2:58 am
Yes I think so (too high in frame)
I'd also crop the starboard engine and tailplane a little bit more to make the picture more symmetrical and avoid cutting only a tiny bit of these.
Peter
dendrobatid
RE: Bad Center?
Wed Apr 12, 2006 3:08 am
Quoting Rotate (Thread starter):
Robin
I find it too high too and really dislike that pole at the bottom as well.
A much tighter crop would have the effect Peter is talking about as well as getting rid of the pole.
Mick Bajcar
Psych
RE: Bad Center?
Hi Robin.
Though I think you will be able to find many examples of planes centred vertically in this way, I would argue that it is too high in the frame.
I have made my argument a few times before, so I won't bore people again. But for me all that space below the plane is redundant. Much better to see more of the tail (preferably all of it in my opinion), with less excess unfilled space below.
I also agree with Peter that the crop to the left and right is very tight. I would suggest slightly more 'breathing space' either side of the engine nacelles.
All the best.
Paul
ptrjong
RE: Bad Center?
Wed Apr 12, 2006 3:28 am
Quoting Psych (Reply 4):
That would be best, but my assumption was that that is not possible and in that case, I'd cut a bit more off the starboard engine and tailplane.
Well, I'd try what that looked like.
IL76
RE: Bad Center?
Wed Apr 12, 2006 3:47 am
My thoughts exactly. More space on the left and right and a bit lower in the frame, preferably showing the whole tail.
E
Rotate
RE: Bad Center?
Wed Apr 12, 2006 3:46 pm
ciao guys,
thx vm for all your suggestions, will take it out. Crop more on the dwonside and let the engines breath a bit more  Smile
Robin
ABC
glennstewart
RE: Bad Center?
Wed Apr 12, 2006 4:11 pm
Hi Robin,
Interesting seeing an A.net regular coming to the forums for some feedback. I welcome posts like this if you're planning a change in your style/crop....
Would have liked to have seen the shot to give you my opinion as well.
Respected users.... If my replies are useful, then by all means...
jumbojim747
RE: Bad Center?
Wed Apr 12, 2006 8:04 pm
Quoting Glennstewart (Reply 8):
Speaking of opinions Glenn I'm still waiting for the reply from your request when i met you at the beach last week.?
Warning this is only meant to make Glenn aware that i sent the email not trying to make him answer quick .
Just to make things clear i asked Glenn on some advice regarding my editing techniques because I'm seeing a lot of jaggies.
He offered to have a look at an image that i see a lot of jaggies with .
[Edited 2006-04-12 13:20:10]
On a wing and a prayer
glennstewart
RE: Bad Center?
Thu Apr 13, 2006 10:26 am
Quoting JumboJim747 (Reply 9):
Doh! You're going to have to resend the email. I didn't get it (and I get thousands).
SMS me on 0410-501-074 and I'll send you a good email to get me on.
jumbojim747
RE: Bad Center?
Thu Apr 13, 2006 5:08 pm
Quoting Glennstewart (Reply 10):
Sent it get and sorry about that  Smile
Rotate
RE: Bad Center?
Thu Apr 13, 2006 5:25 pm
I am sorry Glenn, next time  Smile
Robin
ABC
glennstewart
RE: Bad Center?
Mon Apr 24, 2006 1:45 pm
Quoting JumboJim747 (Reply 11):
Whoops - wrong phone number above.
Messaged you my correct one  Smile
jumbojim747
RE: Bad Center?
Mon Apr 24, 2006 4:22 pm
Doing that now Glenn
