Chuffy
Telephoto Evidence Required Please
Sat Apr 15, 2006 6:40 am
Hello my learned friends.
Are there any pictures on a.net taken with a tripod on the ground of aircraft leaving contrails/high alt.
If so what was the lens used.
Chuffy
TS
RE: Telephoto Evidence Required Please
Sat Apr 15, 2006 6:59 am
Why do you think a tripod is necessary? When I shoot airliners in high altitude I usually have more than enough light even with ISO 100.
Photo © T Seythal
Photo © T Seythal
Taken with a Canon 100-400 at 400mm & f/8.
There are better shots of other people in the database, some with visible rego underneath the wing.
Photo © Piotr Tyranski
Photo © Janne Laukkonen - FAP
Even a broken clock is right twice a day.
timdegroot
Sat Apr 15, 2006 7:02 am
Lots of dustspots on both your shots TS, please consider a reupload Wink
I agree though, you don't need a tripod to shoot contrails. Might also not be very practical if the aircraft is exactly above you.
Tim
Alderman Exit
mygind66
Sat Apr 15, 2006 7:52 am
I agree with the problem facing when the aircraft is on top.. It's really difficult to manage this with a tripod.. In these cases a monopod can help.. but normally I use the camera without them, probably because when I see one aircraft in high altitude is a quick photo ( I'm at home and have no time to prepare everything...)
Enrique
TS
Sat Apr 15, 2006 7:58 am
Quoting TimdeGroot (Reply 2):
Those were accepted in the good old days ...
Chuffy
Sat Apr 15, 2006 5:23 pm
Thank you for your inputs.
I mentioned a tripod because I will be shooting at angles between 30 and 70 degrees as thats the flightpath over my house.
There is a mega large 600/1300mm with a 2 times converter available for cheap money, if this is its only use, is it up to the work?
I have a 300d.
Or is more money better spent on less zoom?
Chuffy
dendrobatid
Sat Apr 15, 2006 5:33 pm
I have never tried uploading one of these images, must do so one day, but the only way they are going to get accepted is when the trail forms a part of the image.
I get reasonable images with a Sigma 50-500 on a Canon 20D (aircraft at cruising altitude)
Mick Bajcar
TS
Sat Apr 15, 2006 6:10 pm
Chuffy,
With a 600mm lens you need an extra, extra sturdy & long tripod & also a professional head. We're talking about hundreds of pounds. The roof of a car mostly will do, so I'd try without a tripod first.
Thomas
Chuffy
Sat Apr 15, 2006 9:13 pm
Thanks TS.
Would you go for a more exspensive lower zoom or a cheaper big one, just for the sole purpose of photographing at high alt from the ground?
Chuffy
flyfisher1976
Sat Apr 15, 2006 11:24 pm
Wow, how did those slip by? No equalization required here!
TS
Sun Apr 16, 2006 3:45 am
Quoting Chuffy (Reply 8):
Hm, I'm not sure if I understand you correctly. If you want to shoot airliners in upper air space only, buy the longest lens you can get (afford). As a rule of thumb, prime lenses are more expensive but also much better in quality. I'm sure the Canon EF 500 f/4L IS or Canon 600 f/4L IS would be excellent choices, especially if equipped with a teleconverter, but they are out of reach for the vast majority of photographers, including me.
If you want to spend less money check out the Canon 100-400, the Sigma 50-500 or the Sigma 170-500. Both the Sigma zooms don't have image stabilizers, but that shouldn't be a major problem with exposure times of 1/500s. A lens that is mentioned again & again in forums is the Canon EF 400mm f/5.6L. Also doesn't have an image stabilizer, but it's supposed to be tack-sharp even wide open. With my 100-400 I only use f/8 or even smaller apertures. Otherwise everything looks blurry.
Quoting Flyfisher1976 (Reply 9):
When uploading a photo just type in your credit card number in the remark field. This works wonders! Big grin
mygind66
Sun Apr 16, 2006 5:16 am
What is expensive or cheap for you?
Enrique
Chuffy
Sun Apr 16, 2006 8:10 am
Quoting Mygind66 (Reply 11):
About 300 gbp
Chuffy
TS
Sun Apr 16, 2006 5:48 pm
Quoting Chuffy (Reply 12):
About 300 gbp
Let's ask this way:
1. What is expensive for you?
2. What is cheap for you?
Chuffy
Mon Apr 17, 2006 6:35 pm
Well I have found an Optica 600/1300mm with 2x converter for 170 GBP or so, an expensive lens would be anything over about 500 GBP
Chuffy
